Question about Toshiba Satellite M35-S320 Notebook
Replacing M35-S359 motherboard with one from S320?
I have a wonderful Toshiba Satellite M35-S359 computer (upgraded RAM, etc) that I dropped a month ago - the shop told me that I had a bad motherboard. I bought a not-perfect used M35-S320.
Anyway I want to take the motherboard from the M35-S320 and put it in my M35-S359, restart with my Toshiba startup disk and reset. WIll this work???
(the S320 comments that the display has problems, probably a "bad Inverter Board" based on message board comments, so I want to use my S359.).
  • Toshiba Master
  • 32,281 Answers
If the M35-S320 case is OK and the M35-S359 screen is OK and will fit the M35-S320 then I would swap the LCD screen lid and inverter over to the M35-S320 including the hard drive from the M35-S359.
It would be less work and with luck it might boot up, if not you might be able to do a system repair, worst case, you will need to reinstall Windows. Plus you have a spare drive from the M35-S320 which you can use as an external hard drive with an USB hard drive adapter case.
Posted on Jan 29, 2009
How can i tell were the graphic card is on my toshiba m35-s357
The graphic-card is "integrated" into the motherboard.
This is unlike many desktop PCs, which have a separate video-adapter.
Trace where the VGA connector (3 rows of holes) where the "data" cable from your monitor connects, and look "inside" your computer to see the "other" side of that VGA connector.
Dec 24, 2010 | Toshiba Satellite M35-S359 Notebook
How can i hook my laptop to my tv with a s-video cable? a toshiba satellite m35-s359
Yes usually with an S-vid cable with the RCA outputs.
Some laptops have DVI output which is top quality so if it has that port then get that cable.
Ensure it also matches the TV If DVI is fitted.
May 18, 2010 | Toshiba Satellite M35-S359 Notebook
Toshiba M35 S359
This code sound like a power supply or battery depleted code.
Your Power adapter may not be charging the battery. The battery made have reached "end of life".
Mar 28, 2010 | Toshiba Satellite M35-S359 Notebook
Toshiba Satellite M35-S359. No audio. Sound
Modem chipset on systemboard is bad most likely.
Jan 04, 2010 | Toshiba Satellite M35-S359 Notebook
How to obtain windows xp install cd to restore to factory setting
hi
regarding battery u need new battery
and regarding battery u can buy it from market or u can download it from the following link http://www.softwarepatch.com/windows/xpsp2.html
Jun 25, 2009 | Toshiba Satellite M35-S359 Notebook
Toshiba Satellite M35-S359 powers off and occasional crashes
This solution worked for me go to laptop101.com and youwill see the solution to this problem there was a recall on the m35 and there is a electic discharge from the speakers and the mouse pad i fixed mine with foil tape from the local big lots if you can't find the link http://www.ask.com/bar?q=laptop+repair&page=1&qsrc=178&ab=1&u=http%3A%2F%2Fwww.laptoprepair101.com%2Flaptop%2F2006%2F01%2F04%2Ftoshiba-laptop-overheating%2F
Mar 23, 2009 | Toshiba Satellite M35-S320 Notebook
Looking for Toshiba HDD for M35-S320
you can buy the HDD in your laptop at computer shop, but check first if it is SATA or IDE...under your laptop,there are 2 screws remove that and remove the HDD and check what type of HDD you have..here is the idea, with 40pin its indicate IDE with small flat connector its SATA..remove and check and go to computer shop,they will ask you also how many GB you want...80,120,160 whatsover..buy and replace the HDD.
Nov 03, 2008 | Toshiba Satellite M35-S320 Notebook
Toshiba Satellite M35-S320 Notebook Logo
302 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
