Question about Meade LX200R 8 in. (600 x 203mm) Telescope
Problem with start up on telescope
I have a meade lx200 emc telescope that i have a problem with when everything is level on scope and on zero and you turn it on it does self diagnostic test.tube moves to facing ski ,andreads telescope object libary ,but motor on side keeps running what may be the problem?can you help?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 17 Answers
Most probably, flat batteries. Autostars go berserk when batteries are even a little low. Try it with a mains power adaptor instead.
Otherwise, maybe its a dodgy curly cable, broken Autostar, broken control panel or Autostar firmware needs reloaded
Posted on Aug 15, 2009
Ime looking for a meade LX200 users manual that comes with the scope
Most Meade manuals are available on their support site: http://www.meade.com/support/manuals/ . Scroll down through the list for the LX200 series manuals (in the Telescopes section). The LX200 manual is listed as the LX-200 Classic. The current link to this manual is http://www.meade.com/downloads/dl/file/id/10/product/0/lx200_classic_manual.pdf .
I hope this helps.
Feb 26, 2017 | Meade Optics
10" LX200 runaway motor, right ascension.Mead
The very first thing to try is new cables. Including the DEC cable. If this does not repair it then it has an internal circuit board issue.
Buy new cables first--
www.scopestuff.com sells them. Call them and order everything new.
Also a low power supply can also cause this-- and would be the second thing I would check. You are using a separate 12volt power pack -- correct?
www.telescopeman.org
www.telescopeman.info
www.telescopeman.us
Jul 24, 2011 | Meade Optics
10" LX200 runaway motor right ascension.Mead
Already answered your question.
10"LX200 EMC that will not
This model LX200 classic has weak capacitors that blow out with age. Go to the Yahoo LX200 group-- post a message with the problem for "Ron Sampson" he can repair the board if it is broken. Also Dr. Clay and Andrew also post to this web site--- they know a lot about LX200 electronics.
www.telescopeman.us
Jul 14, 2011 | Meade LX200GPS 10 in. Telescope
The motor on my Meade LX200 caught fire. How do I take it apart to send it for repair? Thanks
Meade will want the entire scope back for repair-- contact them here--
http://www.meade.com/support/index.html
Jan 22, 2011 | Meade LX200GPS Telescope
I have an LX200 12",the main circuit board (on base of scope) is blown.Where can I get a new one?
Usually these must come from Meade-- call their customer service department here:
Also you can contact Ron Sampson on the LX200 Yahoo group and he will repair the board if you can remove it and send it to him.
Oct 14, 2010 | Meade LX200GPS Telescope
Meade LX200GPS 16" out of calibration?
Before you panic I would update the firmware/software on the telescope. With an LX200 interface cable you can upgrade the software in your telescope from your PC by going to Meade's web site at www.meade.com
Download Meade's ASU (Autostar Update Utility) and the latest software for your Autostar II absolutely free. You can also use the ASU to add Comets, Asteroids, Satellites, and User Objects to your Autostar II with a few simple clicks of the mouse.
I believe you can get the manual here.
Jun 04, 2010 | Meade LX200GPS Telescope
Hello. I just bought an older, used Meade LX200 18...
The scope will run just fine on 12 volts. www.scopestuff.com sells the cigarette lighter cord for that telescope.
Call them here:
www.scopestuff.com
May 16, 2010 | Optics
Recently acquired a used Meade 8" LX200 EMC. The unit presents very well cared for by previous owner. Upon receiving it, I followed the manual's instructions in assembly and then operation. Upon turning...
I have a LX200 EMC 10". I had a similar software problem and solved it by downloading AstroFinder, bypassed the onboard software of the telescope, and controlled the telescope via my laptop. This was a more user frriendly method and allowed easy alignment of the telescope.
Apr 21, 2010 | Optics
Bolt holding dec drive motor on 16 loosens.
You have a LARGE Meade telescope. This should be an easy fix if you can disassemble the fork arm and get inside.
First I would contact Meade customer service to see if they have a manual that shows disassemble instructions. If not I would join the Yahoo LX200 forum and look for help there with an owner of the 16 inch model.
Just search in Yahoo Groups for the LX200 forum.
On smaller scopes the DEC motor is held on by two spring loaded bolts, probably one has become loose?
Nov 04, 2009 | Meade LX200GPS Telescope
Meade LX200R 8 in. (600 x 203mm) Telescope Logo
174 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Greg Cann
Greg Cann
Are you a Meade Optic Expert? Answer questions, earn points and help others
