Question about Dell Latitude D600 Notebook
My Toshiba Satellite A135 was working then started to freeze so I ran the reset computer disc like they said, now it doesn't work at all, you can't turn it on cause it doesn't run right. My dad's friend said that it is probably the motherboard, any help?
  • 5 more comments
  • Aron Jan 29, 2009
    Well, it does not work at ALL. It will just freeze if I try. The Restore Disc by Toshiba to reset your whole system.
  • Aron Jan 30, 2009
    It will freeze while I'm using it but now it doesn't freeze because it don't work, it would freeze while I was using it regularly, just sitting on my bed.
  • David Shaub May 11, 2010
    If you were using it just sitting on your bed, it was probably originally a heat related issue. Now, since you ran the restore disks, you have other issues. Take the battery out for about 30 seconds. This will actually clear some errors that might be holding you in limbo. Put the computer on a table and try to run the disks again. Put the first disk in and try to boot up the machine.
  • Randall  Trahan
    Randall Trahan May 11, 2010
    It was probably overheating...either the powersupply that has the fan is broken or it was not on a flat even surface so that the air could circulate and overheated and burnt something out.
  • Joshua Hansen May 11, 2010
    Where does it freeze? At the initial splash screen?
    He is referring to the restore disc that came from the manufacturer.
    When you say it "doesn't run right" do you mean while IN windows it doesn't run right?
    You can't turn it on AT ALL? Or just after powering it up, you get errors?
  • Randall  Trahan
    Explain exactly what you mean by "reset computer disc" its not your motherboard I can guarantee it.
The recovery on my Toashiba Satellite A130/A135 doesn't work
Try to boot the machine in safe mode by pressing F8 as the computer starts up, if will let you boot into safe mode as it sounds like there could be some bad sectors on the drive causing it to hang on boot.
To check this right click on the C drive and select "properties", then select "tools" tab, in the tools option check the volume for errors.
This can take some time to perform so please be patient.
If you can't get the machine to boot into safe mode please post back
Jun 22, 2009 | Toshiba Satellite A130 A135 Notebook
Toshiba a135-s2276 will not boot
First try to reset bios by make short in cmos battery. If it doesnt work turn it off then remove battery, connect adopter power then turn it on, also if doest work press number one hold then turn it on.
Apr 20, 2009 | Toshiba Satellite A135-S2276 Notebook
My laptop not working Toshiba Satellite A135.
ok i got it as u said that u can hear the fan and it powers up but u cannot see anything on the screen iin that case what u can do is that disconnect the ac adaptor and then take the battery out of the computer and then without the power cord and the battery press and hold down the power buttoon for one minute and then connect the adaptor and the battery and the try and turn on the computer and then still if u do nnot see anything on the screen then turn on the computer and then connect the external monitor and if u see the display on external monitor then the lcd screen has gone bad and if u do not see the display oon the external monitor also then the video card of ur laptop has gone bad replace it ....good luck
or what u can try is that try lkgc (last known good configuration) and then try and boot the computer or try in safe mode....good luck
Jan 29, 2009 | Toshiba Satellite A135-S4527 Notebook
Toshiba A135 Satellite not working.
i dought it is the motherboard. it sounds like you either have a bad hard drive or some bad RAM.
Jan 29, 2009 | Dell Latitude D600 Notebook
Laptop does not work anymore. (Toshiba A135 Satellite)
Do you get power?
If not, when you remove the battery do you get power?
If there is absolutely no power to the laptop (and you know the AC adapter is ok) then it's hardware failure. If its new enough, get it warrantied through whoever sold it to your grandma, or Toshiba.
Application error when running recovery disk
hi
Did you create any partitions on the HDD?
Obviously the HDD or some partitions on the HDD are corrupt.
In my opinion, you should firstly try to format the whole HDD and delete also whole partitions.
Then insert the recovery CD and try to install the Toshiba image
villival
Dec 15, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satelite a135 s2386 USB problems...
I have a toshiba satellite a 135 s 2386....my all usb ports are not working and whenever i attach any of the accesories on it i get a message USB DEVICE NOT RECOGNISED...i have formatted my computer and instaled new windows through my recovery disc but i m still facing the same problem....please help me out.......thnx
Jul 05, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba A135 S 4527 ......some times freezes
Virus information and help Below is a listing of some of the different properties a computer virus is ... Alter the system time / date. Cause system to hang or freeze randomly.
Computer questions and answers listing 700 - 800 CH000700, What should I do when a computer freezes?
Good Luck, Please dont for get to Vote, Thank You
Nov 28, 2007 | Toshiba Satellite A135-S2276 Notebook
Dell Latitude D600 Notebook Logo
650 people viewed this question
Alun Cox
