Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door opener transmitter/receiver compatibility
I replaced 53000SRT Sears opener with 315MHz Security+ unit. I cannot get my car Homelink transmitter to program from the new transmitter nor can I get any old SRT transmitters to program the new receiver.
  • mayes77612 Jan 30, 2009
    What you said worked. I pressed the "learn" button on motor receiver and then pressed the open button on the car homelink, which I thought was not programmed. I guess this gets the rolling code business to work. Thanks
Press and hold the homelink button and wait till the red light flashes slowly,but don't release it. Now hold a working remote 3 inches away,press the remote button and hold it.When the red Homelink buttom fllashes quickly, release both buttons. Now go to the opener and push the learn button. Now go back to your car and press and hold the Homelink button. You will see the lights on your opener flash. Now your Homelink button should operate your garage door.
Posted on Feb 09, 2009
  • 118 Answers
The old transmitters are 390 mhz and will not program. I need more info on what you are doing to solve the homelink problem. Your vehicle's owners manual should show how to program. Then press learn button and within 20 sec press and hold homelink button that you programmed.
Posted on Jan 30, 2009
The light in my Homelink system does not come on. Therefore it cannot be programmed.
The following are steps to programming a rolling code door opener to the Homelink transmitter in the Touareg.
The instructions in the owner's manual are correct, but after following them, my garage door installer and I discovered a few quirks and fixes for them.
It is important to park the Touareg in front of the garage door. Be careful not to park underneath it. rolleyes.gif
If your remote garage door transmitters are already programmed to your door opener, you need to do the following steps:
1. On the garage door opener itself, there is a learn button. Press and hold down the learn button until the learn indicator light goes out (approx. 6 seconds). (The learn button is near the antenna on your door opener.) By doing this, you have just reset the codes. At this point your remote door transmitters will most likely not work. This is o.k.
2. In the Touareg, press and hold whichever homelink button you want to program until the light above the homelink buttons slowly blinks. Continue to hold the button in and at the same time, hold your remote transmitter underneath the map lights and press the button. Continue to press both buttons until the homelink light rapidly flashes. Let go of both buttons.
3. You now have 30 seconds to press the learn button on your garage door opener. Press it once. The light will start to blink.
4. Go back to the Touareg, press and hold the homelink button you just programmed for 3 seconds until you get a blinking light. Repeat again. This time, it should open or close the door. The homelink button is now programmed.
5. Now that the homelink button is programmed, you now have to re-program your remote transmitters. Take the transmitters with you.
6. On the garage door opener, press the learn button, the light will blink. Now press the button on the remote transmitter. The light should stop blinking. Repeat the step if you have more than one transmitter. You should be all set. The homelink button should work in the Touareg and your remote transmitter(s) should also work.
In summary, the rolling codes in the door opener receiver have to be reset. For some reason, the Touareg has to be programmed FIRST. Then the remote transmitter units. If the remote transmitter units are already programmed, you will most likely not be able to program the homelink in the Touareg for a rolling code door opener.
Original Launch X-431 DIAGUN III
Mar 14, 2013 | Cars & Trucks
I can't get either one of my remotes to learn to open the garage. I have followed the instructions and still neither one works. I even clear the codes after each unsuccessful time. Please help.
Hi, the Liftmaster 371 remote control operates on the 315MHz frequency, ensure your receiver works on this frequency, some Liftmaster remotes and receivers operate on 390MHz.371 remote is compatible with models manufactured from 2005, and all Chamberlain Liftmaster and Sears garage door openers with a purple learn button and purple antenna.
You can find further details here chamberlain-liftmaster-garage-opener-parts
Aug 25, 2011 | liftmaster 371 Remote Transmitter
I don't have the owner's manual for my 2002 GMC Yukon XL Denali. Do you know how to program the garage door opener?
I hope this helps.
Programming the HomeLink Transmitter
Do not use the HomeLink Transmitter with any garage
door opener that does not have the stop and reverse
feature. This includes any garage door opener model
manufactured before April 1, 1982.
Be sure that people and objects are clear of the garage
door you are programming.
It is recommended that a new battery be installed in
your hand-held transmitter for quicker and more
accurate transmission of the radio frequency.
Your vehicle's engine should be turned off while
programming the transmitter. Follow these steps to
program up to three channels:
1. Decide which one of the three channels (one of the
HomeLink buttons) you want to program.
2. Press and hold the desired button on HomeLink
through Step 3.
3. When the HomeLink indicator light begins to blink
slowly (this may take up to 30 seconds), hold the
hand-held transmitter about 1 to 3 inches (3 to 8 cm)
away from HomeLink and then press and hold the
transmit button on the hand-held transmitter.
Continue to hold both buttons until the indicator
light on HomeLink begins to flash rapidly (this may
take up to 90 seconds).
If you have trouble programming HomeLink, make
sure that you have followed the directions exactly as
described and that the battery in the hand-held
transmitter is not weak. If you still cannot program it,
move the hand-held transmitter to the left or right or
forward or backward or flip it upside down. HomeLink
may not work with older garage door openers that do
not meet current Federal Consumer Safety Standards.
If you cannot program the transmitter after repeated
attempts, refer to "Training a Garage Door Opener with
Rolling Codes" later in this section or contact the
manufacturer of HomeLink at 1-800-355-3515,
or on the internet at www.homelink.com.
Be sure to keep the original hand-held transmitter in
case you need to erase and reprogram HomeLink.
Training a Garage Door Opener with a
"Rolling Code" Feature (If Equipped)
If you have not previously programmed the hand-held
transmitter to HomeLink, see "Programming the
HomeLink Transmitter" listed previously. If you have
completed this programming already, you now need to
train the garage door opener motor head unit to
recognize HomeLink.
1. Find the "Learn" or "Smartbutton" on the garage
door opener motor head unit. The exact location and
color will vary by garage door opener brand. If you
have difficulty finding the Learn or Smart button,
refer to your garage door opener owner's manual or
contact the manufacturer of HomeLink at
1-800-355-3515, or on the internet at
www.homelink.com.
Because of the steps involved, it may be helpful
to have another person assist in programming
the transmitter.
2. Press the Learn or Smart button on the garage
door opener motor head unit. An indicator light will
begin to flash when the motor head unit enters the
training mode.
Following this step, you have 30 seconds to
start Step 3.
3. Return to HomeLink in your vehicle and firmly
press and release the programmed HomeLink button
three times.
The rolling-code garage door opener should now
recognize HomeLink. You may either use HomeLink
or the hand-held transmitter to open the garage door.
If after following these instructions, you still have
problems training the garage door opener, contact the
www.gmcextendedwarranty.com
Dec 19, 2010 | GMC Yukon XL Cars & Trucks
Craftsman 1/2hp garage opener Homelink must be under unit to work
Have you tired reprogramming the remotes to the opener?
The opener receiver board may have failed, which happens. You can order a new one from Sears or other places on the Internet, and they are fairly easy to replace.
Once replaced, you will need to program the receiver to you remotes again.
Dec 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
I am not able to program my Homelink (car) opener using the Learn button on my Liftmaster Formula I. I used the Rolling Code program. I went through all the steps, indicator light flashed rapidly, I...
  1. Clear out anything previously programmed into the in-car system from the factory by holding down on the 2-outside buttons simultaneously, until the in-car LED starts flashing rapidly. This may take up to a minute (in most cases, the key should be on auxilary, and/or the car door must be shut).
  2. Decide which button you want to make to be your in-car garage door transmitter. Hold your transmitter up near the selected button, pressing both the garage door remote and the selected in-car transmitter button simultaneously. Hold down on the buttons until the in-car, LED light flashes rapidly. This sets the in-car remote transmitter to be your garage door openers make transmitter, but you are not done. You now need to make this in-car transmitter your personal transmitter.
3. Go to the Learn Button on your garage door opener. The button is usually next to the area where the floppy antenna is connected to the motor head. With Genie it is most often behind the light lens, and an indicator light flashes red when pressed. With Sears or Liftmaster (Chamberlain) it is near, or part of, the terminal screw board, and is a red, green or purple square button with a green, amber or purple indicator light. Press this learn button momentarily. The indicator light will turn on and blink if Genie or otherwise stay lit. For Genie systems, go back to the in-car transmitter button you programmed and press this button 3 or 4 times, or until the door starts moving. This should set your in-car transmitter to your garage door opener. For Liftmaster, Sears, or Linear Megacode press and hold the in-car button you programmed until the garage opener light flashes. Your in-car is now programmed to operate your door.
If this doesn't work your car and homelink may not be compatible.
Nov 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
My Homelink wireless remote is stuck on fast flashing red light. I can't seem to clear my remote to program any of the buttons to my garage door opener. This is the second one I purchased, I had no...
Try this.
HOMELINK PROGRAMMING
Nov 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
Program garage door opener in 2005 rx 330
There are 3 programmable Homelink buttons you can use for different remotes. Just to the right of the buttons there is an indicator light.
Decide which button you want to program. Point the none battery end of your remote 1"-3" away from the Homelink panel and press both the remote and desired Homelink button down and hold them down at the same time. After about 20 seconds, the Homelink indicator light will change from a slow flashing to a rapid flashing. You can then release both buttons,
If the garage door responds to the Homelink, your done! If not, your garage door uses a rolling codes transmitter and must be trained.
Find the training button on your garage door opener's transmitter (usually mounted on the ceiling). Press the training button and within 30 seconds press and release the programmed Homelink button twice. If the garage door opener operates, you're done! If not, press and release the Homelink button a third time and the garage door should respond. If it still does not, you may have a very old garage door opener with a none digital transmitter (like I did). In that case, you either need to buy a new opener or try to replace the transmitter with a modern digital unit (as I did). Advantage: cheaper than a whole new garage door opener.
Disadvantage: The newer openers incorporate safety features that my old opener does not have.
Apr 16, 2009 | 2005 Lexus RX330
Remote/homelink and touchpad problem
Your keypad is not the same "generation" as your remotes. You operator will work with your security plus remotes or your old keypad but not both. Yor cheapest solution is to replace your keypad.
Feb 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
I can not hook up Honda odissy 2007 Homelink system with LiftMast
Yes. But you need a remote transmitter that is programmed to open the Lift Master. Then you just follow the instructions in your home link and it should work.
Press the homelink outside 2 button at the same time and hold till fast blinking (all erased). Then press homelink button1 and hold while aiming the transmitter (2 inches away) and pressing appropriate button on the remote. Continue to hold both till fast flashing seed on the homelink. Release both. Then hold the next button on the homelink you want to program, aiming the remote again, and pressing and holding the appropriate button on the remote, until fast flashing, and then releasing again, ......
Feb 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,406 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
