Question about Sony FWD-32LX1 32 in. HDTV-Ready LCD Television
Connecting an S-Video and Audio Cables from a DVD player to a TV
I connected an S-Video cable from my DVD player to my TV, then connected the Audio cables (red and white) as well.  Both sets of cables are connected to the Video/Audio OUT on the DVD player and the Video/Audio IN on the TV.  I am not getting any sound.  The picture works fine, but no sound not matter how many different ways I plug stuff in.
4 Suggested Answers
circuitcity
  • 137 Answers
SOURCE: yellowish color from DVD
Hello Tsmith4,
Have you tried another source such as a HD cable box on the same component input (Y Pr Pb) By doing this you will eliminate the TV or the DVD player. If the picture shows great using the cable box on that same input then we will assume that the TV is ok for now. You may want to also check the DVD menu under progressive scan that it is set to progressive scan. if the picture is still not good, we would want to look at the I/O board on the TV. The red path after the Video switch maybe open. If this is the case we will have to go to board replacement. I will tell you what board to change.
Best regards
circuitcity
Posted on May 28, 2008
skotkolr
  • 558 Answers
SOURCE: Which component cables to use
the cables are fine labeled as they are you notice cr =pr, cb=pb and y is still y
the cables are fine and will deliver up to 1080I capabilities
Posted on Dec 09, 2008
virp123
SOURCE: connect dvd home theatre system to bravia lcd digical tv
Amongst 3 audio and 3 video options on DVD, use only one for displaying picture on TV and one for getting sound.
Yellow Wire is for picture.
Red Wire is for sound.
White Wire is for sound.
Connect Yellow from TV to yellow at DVD
Red from TV to Red at DVD
White from TV to White at DVD
Hope this help.....
hometheaterstore.com
Posted on Feb 17, 2009
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
I've tried connecting a Sony DVD player to my TV using Pb Pr V cables. I get a picture, but no sound.
The cable u are using it is the S-video cable?Yes,this cable dosen't support audio.Must used a RCA component cable like R,W cable connected between the tv and the DVD player to get sound.
Mar 14, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Get video but not audio.. may have cables connected improperly??
It's either cables not connected correctly, or the TV that you are connecting it to is muted or the audio source isn't correct (for example running thru an external audio system). Try connecting it to another TV in the house and if it works, then you'll know if it is or if it's not the DVD player itself. Also try a different audio cable. If it's RCA plugs (typically, the older style with Yellow, Red, and White colors on the connections), it's odd for them to fail, but not sure the connections you have.
Nov 04, 2010 | Toshiba SD-3980 DVD Player
How to connect dvp 3356 t0 samsung 29 inch tv with crt tube.
Please check the connection. If you are connecting the 3 RCA cables to DVD component input/output, you need another pair of RCA cables to connect to audio out (FL&FR rear of DVD player) and Audio in (L&R) in your TV set. Else connect 3 RCA cable in 1-Video out & 2 Audio out of DVD player and 1-Video in & 2 Audio-in of TV.
Dec 15, 2009 | Philips Televison & Video
Tv built-in dvd player wont play thru surround sound
use your t/v audio out with RCA cables to your reciever input like(vcr in, dvd in, dtv in)
Dec 20, 2008 | Yamaha HTR-5930 Receiver
Trying to connect sony dvd player to hdtv
You will need some cables first. It's really not that difficult once you know what each cable does.
Since you're only connecting from the DVD player to a receiver, this should be simple.
There are 4 solutions depending on what cables you have.
Composite - Yellow, Red, and White ended connectors.
S-Video - Black 4-pin connectors.
Component - Green, Blue, Red and sometimes extra Red, White for audio.
HDMI - heavy cable with a wide/flat connector.
Composite connection - Connect the yellow end to the yellow Video Out of the DVD player and to the DVD Video In on the receiver. Connect the Red audio connector to the Red Audio out of the DVD player, the White connector to the White Audio out of the DVD player, and then connect those to the Red and White Ins for DVD Audio on the Receiver.
S-Video Connection - This is the same as the Composite video connection, but connect the black 4-pin cable into the S-Video out of the DVD player and into the In for DVD on the back of the receiver instead of using the yellow video cable. The S-Video cable is a video only cable and uses the same audio cables (the red and white ended cables) for audio.
Component Connection - On the back of the DVD player, connect the 3 video cables that are Red to Red, Blue to Blue, and Green to Green. These will be labeled Y for Green, Cb/Pb for Blue, and Cr/Pr for Red. Connect these video cables to the inputs of the receiver the same way Y for Green, Cb/Pb for Blue, and Cr/Pr for Red. The audio connection is the same as composite and there should be a place on the DVD player that will tell you what audio is for Component. This is also the same on the back of the receiver.
HDMI Connection - This one is the easiest to connect as your audio and video are in the same cable. Plug in your HDMI cable in the back of the DVD player (there should only be one) and then to the HDMI connection for DVD on the back of the receiver.
Now...once you have your connections made, turn on your DVD player, set your receiver to DVD, and enjoy.
If your receiver does not have video inputs, you will need to run the video lines directly to your TV while the audio lines go to your receiver. This will mean you will need to set the receiver to DVD as well as change the channel of the TV to the input you have the DVD player plugged into.
I hope this helps.
May 12, 2008 | Sony DVP-NS725P DVD Player
Audio, but No video when connecting DVD player to TV
Try checking the AV cable. Just interchange the Audio and Video cables, and if now you get video, and no audio, problem is faulty cables. Replace.
Apr 15, 2007 | Toshiba CZ27T31 27" TV
Connecting DVD Player to tv with RF Modulator
Well this could be a loaded question but what type of cables you using?? are there a red one a white one and a red one?? Ok then the yellow one goes to the video output on the DVD player and the other end goes to the video input of the tv. The red white cables are your right and left audio cables and red goes to red and white goes to white on the tv as well as on the DVD NOW make sure the cable on the dvd player are on the output!!!!!! Good Luck
May 05, 2006 | Cyberhome DVD Recorder - DVR1600
Sony FWD-32LX1 32 in. HDTV-Ready LCD Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
