Question about HP Pavilion dv2000t Notebook
My screen will not turn on. I had this problem before, fut after taking out the battery and restarting it, it would work. This trick does not work anymore.
  • leetimmerman Jan 29, 2009
    I have the same problem on DV2000 laptop. Turned it off at night and next day it would not turn on again. Per HP, I made sure memory was well seated, tried each battery separately, tried only AC, tried a new hard drive, tried CD; tried external monitor, still....nothing but blue light around AC and power lights but no action. Apparently this occurs often with DV2000 and DV6000 but I have yet to see solution. HP said take it to Best Buy!!
  • Joshua Hansen May 11, 2010
    Do you get any power at all?
    What model is the laptop?
    Can you get past the initial splash screen?
  • 218 Answers
This sounds like a known problem with these computers. HP is repairing them under a special warranty extension, but apparently not all of their tech support people are aware. Follow this link and read all about it. If you think your situation is covered, then call the special HP phone number and see if they agree. Good luck!
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us
Posted on Jan 31, 2009
My maytag washer epic Z started out with an F 21 code. I opened it up after I turned it off and water started coming out. I turned it off and waited about 20 min and it did start and I fut it on Spi
That error means that it is taking too long to drain. Check the pump filter under the unit and remove any debris that may be in it. Be warned that when you take the drain plug out to clean it, you will get water on the floor.
Jan 22, 2015 | Maytag Washing Machines
Which is the best method for hair transplant? FUE or FUT?
Different Between FUT and FUE Hair Transplant Method
1- FUT there is a linear long cut is given on the back side of the head to harvest a skin strip. The wound is closed with sutures. After healing there is a long liner cut which is covered by adjacent hair. This scar will show after shaving. FUE Method means follicular unit transplant in which individual hair follicles are harvested without giving any linear cut and no suture is put after surgery. There is a circular punch which is mounted on the motorized handle. The head is completely shaved. After giving local anaesthesia grafts are harvested.
2- The general population does not like a long linear scar and they feel it is a surgery or operation in which head is cut. So more or less it is a fear factor.
3- As far as technical aspect is a concern the FUE done by the untrained surgeon than chances of follicle damage is much more as compared to FUT. But much of work is done by an assistant in FUT so it is very important to have a well-trained assistant for FUT Method.
4- The harvesting of follicles in FUE and strip harvesting in FUT is done by the surgeon and also surgeon makes slits while implantation is done by assistants. In both a good trained qualified surgeon and assistants are mandatory.
5- Chances of scar widening, hypertrophic scar painful scar is there in FUT while chances of these are much less if done properly.
Read More -
Hair Transplant Technique Difference Between FUT and FUE Method
Jul 19, 2013 | Hairart Health & Beauty
My phone's touch screen will not let me press any thing at all, even the buttons wont work, i have to take the battery out to turn it off. the power button works to turn it on but then i cannot enter my...
which phone you use?
if it's a winmo device, press and hold call [the green one] button _together_ with end-call [the red one] button while restarting the device.. after restarting, you shall be greeted by a white screen telling you whether to reset the device or not. choose reset. you should see the device back to what it should. if this trick doesn't work, you might get another one, because your device is broken.
dunno about other devices.
Apr 21, 2011 | Cell Phones
Should the compressor be going fut fut fut? I got mine out of a box new after keeping it unused for three years. It makes a fut fut fut sound rather than a continuous pressure release. Is this normal?
I have heard some belt drive compressors make that fut fut fut sound you describe, Its not a problem in my book as long as the pressure builds and the motor is not straining. I have even heard that sound come out of direct drive compressors, so I don't think you have a problem here.
Jan 22, 2011 | Mammoth 300 PSI Air Compressor 12 Volt
THE FAN ON ADVENT 6441 DOEST NOT WORK NO SCREEN OUTPUT. POWER COMES ON HARD DRIVE WORKING CD ROM DRIVE WORKING, THERE IS NO SCREEN DISPLAY AND NO FAN. WOULD THE MAIN CPU IF BLOWN CAUSE ME NO SCREEN DISPLAY...
take the bottom cover off and take out the cmos battery, i had the same problem turned out to be a power problem, check that all the cables for the screen are inserted, an maybe try it on an external monitor, if stil no output chances are its the motherboard,
Jan 18, 2010 | Advent Netbook
It wont turn back on.... turned it off, shut it, now the screen is blank and its making some kind of dinging sound.
open cover/screen remove the battery, put in ac charger, press power button to turn on when it does start beeping press and hold down power button till it restarts, should do the trick if not you may have a bad cpu that is the prosseor has fried. Goodluck!
Jul 17, 2009 | Acer Aspire 5315 Notebook
TI 83 Plus won't turn on after battery change
I was having the same problem...I found the info below on another blog and it helped me fix my calculator problem. Take out all the batteries, hold the DEL button and put the batteries back in (keep holding the DEL button until all batteries are put back in). This will restart the calculator and restore it to its default settings...but it makes it work again!
"Reflashing the OS is probably the thing to do now. I think there's some trick that throws the calc into OS receiving mode. Hold down DEL while putting the batteries in? I don't remember if that's it. Go to 1-800-TI-CARES/ti-cares@ti.com if you need specifics on getting the calc to take an OS upload given the state it's in."
Feb 24, 2009 | Texas Instruments TI-83 Plus Calculator
My tomtom one 3rd edition(1g) keeps freezing up and restarting
I was having a similar problem where i would go through the setup screens until I was selecting the map and then it would restart.  What worked for me was to connect it to my computer and choose Operate My Device from the third page of options in TomTom Home.  This let me progress through the remaining set up screens and get to the point where I could enter an addres again.
Don't know if this will work for everyone, but it seems to have done the trick for me.
Nov 10, 2008 | Tomtom ONE GPS Receiver
M527
my camera lens doesnt work every time i turn it on the screen stays on and then the lens error: M527-22 error comes up can you help me
thanks
Feb 25, 2008 | HP Photosmart M527 Digital Camera
Phone keeps freezing at sony ericsson screen
Try taking and leaving out the battery overnight. If that doesn't help, then try flashing your phone with the Sony Ericsson Update Service.
Dec 30, 2007 | Sony Ericsson W200i Cellular Phone
HP Pavilion dv2000t Notebook Logo
35 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
