I have a CD Portable radio for which I cannot find the manual, I am having a problem with the CD player. When I insert a CD and press play nothing happens. What am I doing wrong? Thank you.
    Problem Solver:
  • 16 Answers
1) Unit is Defective,
2) Hold Button is on.
3) Power Button is not On. (or Batteries are not in proper position or weak. Or Corrosion on Battery Contacts)
4) Dirty Lens (Clean the laser lens with swobbies gently)
-These are the only things that User can do. If this does not help, then Replacing would be better.-
Posted on Jan 29, 2009
My Sony CDX-M610 will play radio but not CDs
THE CDX-M610 LIKE ALL OF THE CDX-M630, M800, M850MP SHOULD ALL SIMPLY START TO PLAY THE CD WHEN INSERTED. BECAUSE YOU ARE ABLE TO TUNE RADIO STATIONS AND HEAR THEM PLAY SHOWS THAT YOU HAVE EVERYTHING IN PLACE AND ARE DOING EVERYTHING RIGHT. SO IF IT IS NOT PLAYING, THEN IT WILL NEED TO BE SERVICED. AS FOR THE REMOTE, IT IS NOT REQUIRED OF ANY OF THE CD PLAYERS IN ORDER TO PLAY CD OR TUNE RADIO STATIONS. RATHER THAN INVEST IN REPAIRING, I WOULD LOOK FOR ANOTHER MODEL ON EBAY USED AS IT WILL PROBABLY GO PRETTY CHEAP. ALSO HAVE CHANCE TO GET A HIGHER MODEL LIKE THE ONES I MENTIONED ABOVE. I HAVE SEVERAL OF EACH IN MY COLLECTION AND THERE ARE NICE PLAYERS. OK. HOPE THIS HELPS.....V
Jan 04, 2017 | Sony CDX-M610 CD Player
How to turn it on to play CD?
Personal CD Players usually have a on/off button or sometime a play and stop button. links below,
press the helpful button
Playing portable CD player
Rio Portable MP3 CD Player
Sony Portable DVD player teardown repair
Top 10 Portable Cd Player
Feb 04, 2016 | Audio Players & Recorders
CD player doesn't work on Timex Indiglo Radio Sounds CD player. No manual available. Can't use.
I never have seen this model but guess it's similar to any other CD-Radio model. You can download a manual from here
https://timexaudio.com/media/uploads/product/files/T618_IB59176_84.pdf
It should have a switch to select CD player.
Once you select CD player, open CD lid, insert a CD and play
If won't play, CD player is defective and if you don't know how to repair it you should take it to a repair service and evaluate if it's worth to reapir.
Aug 07, 2015 | Timex Audio Players & Recorders
I have a cd stuck in the radio & it won't eject it (states no cd), makes a clcking sound. how to fix it?
Usually there is a hole in close to the cd slot, where a pin can be inserted in order to push out a cd manually or a similar manual override.
Which CD player/ radio are you using?
Jul 01, 2017 | 2004 Chevrolet Avalanche
IBOUGHT MY PHILIPS SAA7130 TV TURNER/FM RADIO THE MANUAL STATES THAT I MUST INSERT THE CD KEY FOR THE FIRST TIME WHEN ISTALING BUT I DIDNOT SEE THE OPTION WHEN INSTALLED MY CARD AND IT SAYS FM RADIO...
BOUGHT MY PHILIPS SAA7130 TV TURNER/FM RADIO THE MANUAL STATES THAT I MUST INSERT THE CD KEY FOR THE FIRST TIME WHEN ISTALING BUT I DIDNOT SEE THE OPTION WHEN INSTALLED MY CARD AND IT SAYS FM RADIO OPTIONAL BUT NOTHING IS PLAYING FROM RADIO
Mar 04, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
Trouble Ejecting CD. CD not playing
One thing have you tried to pull the CD out?
Dec 09, 2009 | 2001 Dodge Caravan
Radio works ok, nothing from the cd player its like there is no power to the unit, nothing happens when you insert a disk or press the disk button just dead, any ideas. cheers Nick. ps its a standard...
If the radio works but the CD player doesn't it's something internal to the unit. The radio and CD player get their power source from the same wire that goes into the unit.
Nov 29, 2009 | 2003 Toyota RAV4
Will not play any DVD
Turn off and disconnect power from unit. Check laser shuttle worm gear, look for dirt or hair (as I found). Remove with tweezers carefully. Check lubrication of worm gear shaft. If gone or worn, use white lithium grease to lube (very little). Play music CD 2 - 3 x. Than DVD. Worked for me.
Jun 01, 2008 | Mintek DVD-1710 Portable DVD Player
24 people viewed this question
 Grubhead
Grubhead
