Question about Kenmore 62872 Electric Dryer
Trying to service Kenmore 80 Series Electric dryer. Dryer runs but does not produce heat. Have Fluke Meter. OHMS 9-11....
  • Jackie H Jan 29, 2009
    Yeah I tested everything and it was all fine...so I'm assuming it's the element too. Luckily I'm moving soon and it's my landlords dryer, so I can let her know and she can pay to have it fixed. lol. Thanks though.
  • Anonymous Jan 30, 2009
    KENMORE 62000 ELE DRYER HAS NO HEAT
    President:
  • 1,214 Answers
Follow the wiring diagram on the back access service panel or inside the control head.
I suspect the element is bad, but it could be the overtemp stat or thermostat.
Let me know if you have any further questions.
Posted on Jan 29, 2009
Dryer was not getting hot. Pulled it apart element seems fine but it looks like it may of been overheating at one point. wires look slightly melted
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
Mar 28, 2015 | Kenmore Dryers
My gas kenmore 80 series is not heating?
ELECTRIC Dryer no heat or little heat:
May 20, 2014 | Kenmore 80 Series Heating Element -...
Kenmore dryer 80 series does not heat
May 17, 2014 | Kenmore Dryers
70 series
Check venting and lint basket. blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
May 16, 2014 | Kenmore Dryers
I have a Kenmore Electric Dryer Model 66812. The motor runs, but the heat doesn't come on ... so it's not drying. What's wrong? Is it worth fixing? Estimate to fix?
May 12, 2014 | Kenmore 62802 Electric Dryer
OUR KENMORE 80 SERIES DRYER DOES RUN BUT DOESN'T HEAT AT ALL. PLEASE HELP!
If it was the fuse the dryer would not run.
I suspect the smaller limit at the top of the heater chamber
Number 1 in this photo.
clean her up
Service manual
Mar 15, 2011 | Kenmore 62802 Electric Dryer
10 year old Kenmore dryer Series 80 suddenly has stopped producing heat. Vent is clean. What else can I try?
On a gas model dryer those coils seem to die when heated when they have a little age on em. So if the ignitor works and the dryer does a little bit of heating then fails and it is gas then those coils are the problem. On an electric model the element will get brittle with age and die but if your dryer is suffering from air restrictions it may have had a limit trip on it.
I have a service manual and more of a Kenmore /whirlpool style dryer HERE
Jan 18, 2011 | Dryers
I have a Kenmore, 70 series, Electric dryer,the dryer runs-but no heat, Ive cleaned out all lint vents & dryer exhaust hose of all lint (there was a clog of lint there), I have a ohms/volt meter i just...
Hello, firstly you have it set on volts not OHMS. You need to test the actual part. However I can tell you that from what you are discribing and personal experiance it sound like your heating element is gone. Please if you have never done this before be carefull, electricity is dangerous and doent discriminate as to whot it zaps. I hope thi is helpful.
Nov 07, 2009 | Whirlpool LER5636P Electric Dryer
Kenmore 80 series Heating Problem
Most of these issues will need an ohm meter, unless you want to just take a guess.
For Gas dryers.
1. See if the ignitor glows, if not, check the thermal fuse. (if the lint screen is on top, the fuse is accessed behind the back panel, it's small and white, next to the bulkier thermostat. If the lint screen is in the front panel, the thermal fuse is mounted on top of the blower wheel housing, accessed behind the bottom-front or "kick" panel. The fuse should read 0 to .2 ohms at the most, technically is should be zero. If that checks ok, check the ignitor itself, which has a wire harness that connects about 6" from the ignitor. Should be around 50 ohms... a faulty ignitor would read infinite ohms (open).
2. If the ignitor does glow, and you hear a click, but there is no flame, replace the valve coils, (two small cylindrical objects mounted on the valve) Part # 279834. This is assuming your gas is ON.
If Electric, it would not be the fuse, as on electric dryers it is also in the motor circuit, and the dryer would not run at all. Check the heating element, should be around 9-11 ohms. If good, check all thermostats (operating, hi-limit, thermal cutoff). Infinite ohms is bad. Hopefully it's not more complicated than this, or it can get weird..... Hope this helps.
Sep 15, 2008 | Dryers
Kenmore 62872 Electric Dryer Logo
120 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
