Question about Dryers
Whirlpool Dryer LEL8858EQ1
I put a new door switch, New on/Off switch and a new Thermo fuse. My problem is that it heats up with the door open when the timer is on any min. spot, if the timer is in the off spot the heater is off. I just did a load today and I get heat but not enough to dry cloths.
  • mbwarner Feb 07, 2009
    There is only one way the door switch can plug in. One side is flat and the other side is round. Thanks
    President:
  • 1,214 Answers
If the door switch was a 3 terminal device, and all three terminals had a wire going to them, did you get the NO and NC wires connected to the right place?
You should be able to follow the circuit that can be found on the back service panel or inside the control head.
Let me know what you find or if you have any more questions.
Posted on Jan 29, 2009
Dryer was in cycle and shut off and will not turn back on. I turned the cycle off and tried to restart and it still will no go on. This is a new dryer, only 3 weeks old.
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. To determine if the door switch has failed, watch this part testing video. On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Aug 27, 2011 | Whirlpool WED4900XW Dryer
Dryer does not start. I can hear the hummof it receiving power and have changed the motor and door switch.
Hi, I would check the white thermo fuse to see if it's blown. If the thermo fuse it bad it will keep the motor from running. Without a model number it's hard to give much detail, but here is a video that should be similar to your whirlpool dryer that shows you how to replace a thermo fuse. Most all Whirlpool Dryer thermo fuses are white in color. They show the most common one in the video, but your could be a little different shape too.
Aug 07, 2011 | Whirlpool Dryers
My dryer whirlpool still blow cool air but do not heat please tell me what the problem henry le
Bad heating element or bad thermo fuse.
You will have to unplug the dryer and remove the back to access the heating element. The thermo fuse is located on the side of the heating element.
If you don't have a meter to test the element and thermo fuse or just don't know how simply remove them from the dryer and take them to your local appliance repair shop and they can test them for you.
Aug 03, 2011 | Whirlpool LER4600 Electric Dryer
Whirlpool LGR6634B no heat
When you say no heat, do you meen like no heat, only blowing air or no heat as in some heat but not enough? If its compltely no heat what so ever only aor is blowing, Its is probably your thermo fuse. Disconnect power cord first. Go to the back of you dryer panel and take of all th screws around back panel that hold it up, once you take it out you will see wires and fuses....the thermo fuse is the small white skinny oval shaped fuse. i think its on a slant..bit its small white skinny ovel shaped fuse....If you have a a multi meter ohm it out. Put the meter on the ohms setting and out the 2 leads on the each of the fuse terminals. if it read "OL" you need a new thermofuse. If it reads 0.0 ohms then its good. But you dont have a meter, go ahead and change it out anyways, its probably bad. hopefully this helps
Jul 29, 2009 | Whirlpool LGR5636L Gas Dryer
Whirlpool LEQ9030PQ0 electric will not start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
Jun 03, 2009 | Whirlpool LER4634J Electric Dryer
Dryer wil not run, buzzer does not buzz?
If it is whirlpool--Make sure it has power. Then:Check the door switch. A little lever sticking down through top rightof door opening. If it is not there you will need new doorswitch(sometimes the little lever breaks off). If it is there and doesnot click when you press it in you need a new door switch. if it clicksand clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuseis an oblong white plastic piece with 2 wires attached.
May 20, 2009 | Whirlpool LER4634J Electric Dryer
Dryer will not start
Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks and clicks when you close the door then you have a bad thermal fuse. The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406107
May 17, 2009 | Whirlpool LEQ9858L Electric Dryer
Whirlpool Ele. dryer Model # LEL8858EQ1
You have a bad timer that is allowing your heating element to come on.
UNPLUG YOUR DRYER......NOW!!!! BEFORE YOU BURN THE HOUSE DOWN.
Call a whirlpool tech or service company to come out and service your dryer.
Do not use until serviced.
Jan 25, 2009 | Whirlpool Dryers
Whirlpool electric dryer
either you are pushing the dryer back to far and crushing the exhaust vent hose .your exhaust vent going outside is stopped up , or your low temp thermo will not let the dryer cycle and it is over heating.
Feb 27, 2008 | Dryers
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
