Question about Mitsubishi WS-55809 55" Rear Projection Television
Where do I get the cheapest convergence amps for my mitsubishi 55" rear projection tv?
    Genius:
  • 1,139 Answers
Hello
your set uses the STK392-570 which costs $23.99 each at www.electronix.com or on ebay for $8.99
I hope this helps,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Jan 29, 2009
  • Henry McKelvey
    Henry McKelvey Jan 29, 2009
    Ebay would be the cheapest for these ICs
We can set the convergences great but after about 10 to 15 minutes ithe reds lines start moving a little again will not stay in position. It's a widescreen Mitsubishi rear projection tv ws-55857.
The problem - you're setting the convergence settings, but you're not saving them, you're
simply exiting the menu screen. Be sure to save your convergence setting for each
of the three colors. It sounds like you're setting RED last, and not saving its convergence setting,
whereas the GREEN & BLUE are holding their convergence settings, since you're saving them
correctly before proceeding on to RED....
Mar 15, 2011 | Mitsubishi WS-55857 55" Rear Projection...
My Mitsubishi HD 1080 Model WS-55809 - the colors are distored. The picture is like double vision. For example the menu words all have yellow & red shadows.
Ur convergence it dead.U know how to solders?Buy a convergence kit.These websites have the kit.Tv repair World.com,Tv repair kits.
Dec 12, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi TV VS-55601S Convergence Problem
Convergence it dead.Must replaced convergence,know how to solders?Tries these websites for convergence kit.Tv repair World.com,or Tv Repair Kits.
Nov 17, 2009 | Mitsubishi VS-55601 55" Rear Projection...
55 inch mitsubishi rear projection tv red lamp out of adjustment
Have convergence IC's replaced. I believe this unit uses STK-392-570 convergence IC's Only one has gone bad but replace them both, because if one has failed then the other is not far behind, for Blue and Green. One handles Red, One handles BLUE and Grn. There are only two of them in the set, They are the two largest IC's in the entire set.
Oct 01, 2009 | RCA HD52W59 HDTV Projection Television
Mitsubishi WS-55819 TV Wont turn on.
code stands for loss of vertical. I had one of these if you can check pico fuses, check the ones on the main power board the one with the 2 convergence amps if any of them are blown then most likely the convergence amps have shorted out.
Aug 10, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Warped 3-D LOOK COMES AND GOES
resolder the convergence ICs . Common problem with mitsubishi rear projections
Jun 16, 2009 | Mitsubishi WS-55859 55" Rear Projection...
I have a Mitsubishi 55 inch rear projection tv, ws55819 on which the convergance is gone bad. I'm getting a concave picture with multiple colors. Repair shop estimates are $340-420.00 Can I replace the...
Yes you will need to replace both of the STK392-570 Convergence ICs and the two 5 amp pico fuses. You can get the parts at the following link and they provide instructions with pictures that show how to do the repair. Heres the link'
http://servicemanuals.vstore.ca/
Jun 14, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Double image looks like a convergence issue
This is a Convergence issue, bad solder connections on the convergence IC's.
Nov 20, 2008 | Mitsubishi WS-55313 55" Rear Projection...
Mitsubishi ws65813
HACKER-PROBABLY BAD CONVERGENCE AMP IC CHIPS,TEST AND SEE IF YOUR CONVERGENCE FUNCTION IN YOUR MENU WILL WORK,IF NOT CHANGE THE 2 STK CHIPS INSIDE TV.IF YOUR NOT A GOOD REPAIR GEEK I,D CALL ATV GUY OUT,EST.AROUND 300.00. JOE TV
Dec 12, 2007 | Mitsubishi WS-55513 55" Rear Projection...
TV wont stay on
you may have a convergence problum if your convergence ic,s are shorted, you will need to check the convergence fuses in the power supply.
May 06, 2007 | Mitsubishi WS-55413 55" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
85 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
