Question about Kenmore Elite 45986 Front Load Washer
Dead washer at first washer would power up but not start; now the power button doesn't even work.  Outlet will operate a hair dryer so it's not a power issue.
  • 1 more comment
  • onfire4jeez Jan 29, 2009
    Same problem. Did a couple of loads yesterday. Then was doing some vaccuming and apparently threw the breaker. Flipped power back on but washer will not work. Don't know if this is a coincidence or if it blew something in the unit. Not sure whether to call an electrician or an appliance repair person.
  • franksstuff Feb 17, 2009
    This was finally fixed when we replaced the motor control. This washer is only two years old and should not have failed. Sears repair quoted us a parts cost of $571.56. The Sears website had the part at $480. The part can be obtained at many on line stores between $240 and $320.
  • 15,935 Answers
It appears your main controller board has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 13, 2010
Have sv2000 dvd/vhs player and the power won't come on
1. Make sure outlet plugged into is working. Test it using another electrical device..such as hair dryer that you know works. If outlet is dead..circuit breaker may be tripped. Have qualified person check electrical box.
2. Some units have a reset button that is tripped and you usually push it in to reset it. Check owners manual for instructions..see if this model has one.
3. Try calling mfg customer help line..some are 24hrs. Should be a listing in owners manual. Hope this helps.
Nov 04, 2017 | Televison & Video
Is there a reset button
First, plug a fan or hair dryer into the plug to make sure it has power, if not, check to see if the GFI plug hasn tripped. All electrical plugs that are near water have to be on a dedicated electrical line that has a trip-breaker (GFI) built into the plug. Try unplugging the washer for several minutes to reset the electronics. Those are the only two quick fixes I can think of. If you have an electric dryer, it will have its own 220v plug and won't be affected like the washer. If the dryer is gas and is plugged into the same outlet, try unplugging the washer to reset first before you call a repairman for the washer. If you have homeowners insurance, they may cover the damage.
Jun 21, 2014 | Amana Tandem 7300 Washer and Dryer Stack...
Kenmore Quiet Pak 2 dryer wont start.
what's the model number if you have a dryer with even heat and it will say it on the top console most likely you have a bad even heat board located in the top console,also there's a motor and heat relay in there that could be bad but usually it's the even heat board.go here
http://fixitnow.com/wp/2009/03/17/easy-fixes-for-two-common-problems-with-the-whirlpool-even-heat-dryers/
hope this helps
Feb 13, 2014 | Dryers
My washer want start
see this steps and fix it. God bless you
Check Power
Check the outlet by plugging an appliance into the same outlet the washer was plugged into an running the appliance a hair dryer works good for this it will draw some amperage. If it works fine move on.
Control
To check the control remove the top panel and then remove the console to access the wiring to the control. Find the wire feeding the control from the main power cord. If you cannot visually see this refer to the tech sheet or service manual. Connect voltmeter to the 2 wires feeding the control if it is recieving power and it does not respond replace the control
Jul 09, 2013 | Frigidaire GLTF2940ES Front Load Washer
Displays PE ON START will not operate
see this causes and fix it. God bless you
Check Power
Control
Oct 05, 2012 | Washing Machines
Woke up this morning and the fridge was not working, It is like there is no power on to it. I checked the breaker and it was not tripped I did reset it to check but still nothing.
If there is not lights or anything in the refrigerator, then you aren't getting power. Start out checking the outlet - if you don't have a multimeter to check it, use a hair dryer plugged in to that outlet to see if it will work. If it doesn't then it is between that outlet and the main circuit breaker box or even a bad circuit breaker.
If it does work or you have lights in your refrigerator it is probably either the starting capacitor, start relay or compressor.
LG refrigerators are more sensitive to power fluctuations than other models and we have had to replace a lot of starting caps and relays - but sometimes it is the compressor.
Hope this helps!
Jun 22, 2011 | LG Refrigerators
The dryer wont show any sign of power. The plug works fine
Press and hold start button for 4-5 seconds.Make sure that the start button has been fully pushed down or turned far enough to activate the dryer.
After that plug something else into the same outlet. If it works, you know you have power to the dryer. If it doesn’t work, you’ll need to check for any blown fuses or tripped circuit breakers.
If the power is there, you need to check door switch, thermal fuse, thermostats, and start switch to see if one of these is faulty.
Make sure that the control settings are appropriate, and that any buttons are fully depressed.
Good Luck and have a nice day.
Jun 21, 2010 | Frigidaire Electric Dryer
No power up in washer
I have the same problem with my GW52F, i have checked the power supply and it works fine with other appliances, any ideas?
May 03, 2010 | Fisher and Paykel GWL11 Top Load Washer
The washer works no power tp driver
First check out your fuse or breaker box to make sure you have proper power to the outlet.
If the outlet provides 220 volts I would check the door switch and then the high limit found in the very upper rear of the cabinet above the heat element.
the high limit is a non resetable heat sensor if it blows the dryer will be dead until you replace it.
Bear in mind that this is no easy machine to work on, getting to the high limit is extreme but even checking the door switch will be difficult.
Good Luck
Quentin
Oct 07, 2009 | Frigidaire FEX831CS Top Load Stacked...
The timer runs but dryer does not heat or drum will not turn .
hi friend,
Is your washer getting power? The first things to check if your washer suddenly stops working are your circuit breaker, lid switch, or fuse box. After making sure there is power to the appliance, you can start troubleshooting other problems. To verify there is power at the outlet, try plugging in a small electric appliance such as a hair dryer or radio.
Sometimes the motor will overheat and then requires a cool down period before it will restart.
Is the machine in a pause cycle? Is the lid up? Washers will not spin or agitate if the lid is up. There is a lid switch probe that can sometimes become dislodged. This is generally a little plastic piece that is in the hole under the lid on the washer. This probe activates the lid switch when the lid is put down. Manually advance the timer if the pause is too long.
There are some washer models out there that will not run at all until the water is filled to the level that has been selected. Sometimes the mechanical timer knob on certain washers doesn’t exactly line up with the graphics on the control panel. You can try advancing the timer slightly and pull the knob out again to see if it will start.
hope this helps u
thank u for using fixya
please rate me.......................
regards
sivaranjini
Sep 14, 2009 | Kenmore 62602 Electric Dryer
Kenmore Elite 45986 Front Load Washer Logo
23 people viewed this question
Sal De
fordexpert
Robert Rankin
