Question about Kenmore 74602 Gas Dryer
My kenmmore dryer screen is reading pf and i want to nkow how to solve the issue?
  • 360 Answers
Pf indicates a Power Failure, press start to resume cycle (if in operation at time of fault) or turn off for 5 seconds and turn back on, error code should be cleared.
please take the time to rate this solution
Posted on Jan 29, 2009
LG WASHER/DRYER COMBO PF Issues
pf is power failure,, need to replace main board... there should be a parts/repair manual inside unit.. usually bottom panel...
Aug 15, 2016 | LG Washing Machines
"PF " on screen and delay start light on
it's a power failure, the unit should go back on just by setting it to a load cycle.unless you had a surge then the board is fried
Apr 24, 2013 | Kenmore 62602 Electric Dryer
Kenmore Elite Oasis Electric Dryer - no power (PF code)
Press and hold the "Start" button to restart the dryer cycle if the "PF" (power failure) error code appears. This code often appears when a cycle is interrupted before it completes. You may also check the breaker or household fuse, and ensure the machine has not come unplugged.
Read more: How to Repair Kenmore Elite Oasis Dryer Error Codes ' eHow.com http://www.ehow.com/how_7703883_repair-oasis-dryer-error-codes.html#ixzz1u
May 12, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
Frigidair galaxy electric dryer comes on for a few seconds and shuts right back off error code reads PF
PF means Power Failure,try unplugging the unit for 20 minutes to possibly clear the computer control inside the unit,then try starting it again,if this doesnt help try unplugging and replugging in all connections in case theres a bad connection,lastly if this doesnt solve it,replace the control board
Feb 12, 2012 | Frigidaire Dryers
Start dryer and it quits and displays pf on screen?
The pf is for power failure .If the voltage is correct going to the unit 110 to 120 volts on each leg of the circut. then the issue is with the machine control board not sensing the voltage correctly. and the control board will likley have to be replaced...
Hope this helps with your concern..
Aug 14, 2010 | Frigidaire GLEQ2152ES Electric Dryer
What does PF mean on the lcd screen of the whirlpool duet dryer?
PF means "power failure". This could be caused by an actual power failure, a loose conection, low voltage, or even a bad board. If you have not had a power outage, check the power cord in the recepticle to make sure it's secure. Voltage at the outlet should be 120VAC +/- 10%. If the voltage drops below 108VAC, it can cause you PF display.
Apr 27, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool gas dryer doesn't run. error code pf shows on lcd
pf usually means power failure. Try to clear the screen or hit the off button to clear pf and then see if it works.
Nov 16, 2008 | Whirlpool GGQ8831L Gas Dryer
The PF symbol
pf is power failure but may be caused by a control bd issue or bad connection in incoming wiring ,plug or even breaker
Jul 20, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 74602 Gas Dryer Logo
66 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
