Question about Sova DSV32P112 32 in. LCD Television
No sync detected (sova dsv32p112 troubleshoot)
Hi all,
I am looking at a sova dsv32p112, which I have had plugged into my pc for about 6 months now via the DVI connection with no trouble.
Last week my girlfirend wanted to see lost, and I plugged an antennae in to watch t.v..
Now my DVI connection reads on the screen as "no sync detected"
any ideas as to what i should do?
thanks so much for your help.
Rob
  • robrichert Jan 29, 2009
    uhhh so for those out there with this problem. I ended up unplugging everything. replugging it all together and turning it back on and everything worked again.
    yay computer magic
    (i blow into the nintendo cartriges in my dreams)
4 Suggested Answers
SOURCE: Need a stand for tv
I got my own stand at walmart
Posted on May 24, 2008
SOURCE: Need Screws for SOVA LCD TV
i need a borad for my sova 32' lcd tv
Posted on Aug 29, 2008
SOURCE: Parts for Sova DSV32P112
My uses a regular standard computer cord
Posted on Sep 23, 2008
SOURCE: DVI to HDMI problem please help
So have you found a solution to connecting your PS3 through the HDMI-to-DVI cable? I am also getting the "Invalid Mode".
Posted on Mar 09, 2010
How do I hook cable up to my sova tv TYPE#DSV32P112 MODEL#LT32D1P1
Please follow guidelines given in operation manuals of both.
Jul 29, 2012 | Sova DSV32P112 32 in. LCD Television
LOOKING FOR A AC ADAPTER FOR SOVA LCD 30" TV
lcd paylessi found a place to replace power adaptors for sova 32 in lcd.
Nov 15, 2009 | Sova DSV32P112 32 in. LCD Television
Does anyone know how to reset a sova 26 inch lcd tv.
Sure. There is a switch located on bottom of the TV.
Jul 12, 2009 | Sova DSV32P112 32 in. LCD Television
26 inch sova lights go on but no picture or sound.do i throw away this lemon?
No. There is a switch located at the bottom that allows you to reset the TV.
Jul 04, 2009 | Sova DSV32P112 32 in. LCD Television
Sova LCD 32" with no Picture
since i do my stuff by trial and error, sometimes its just a matter of making sure you dont have a video cord plugged into an audio plug that is supposed to be for the tv signal to go out and not come in or that where you have the left/right audio plug is good, but the video plug is broke.
i just move from one slot to the next trying different a/v (out) spots
Sep 12, 2008 | Sova DSV32P112 32 in. LCD Television
Need a stand for tv
Apr 30, 2008 | Sova DSV32P112 32 in. LCD Television
Mar 26, 2008 | Sova DSV32P112 32 in. LCD Television
Jan 14, 2008 | Sova DSV32P112 32 in. LCD Television
Pc and lcd tv
that's really easy. just plug in a VGA or DVI cord from the PC to the Sova TV (those are both regular cables that normally would go the computer monitor). then press the source button on the remote (not too fast, it takes a second to detect the signal), until you see VGA or DVI, and your computer screen should show up. use the display settings on your computer to get the best resolution on the tv. depending on your computer, you may have a program that can save different screen resolution profiles for you (since the Sova TV resolution and the computer's optimized resolution using a different screen (such as the built in screen on a laptop -- or a different monitor with better resolution than the Sova TV), this way you can easily toggle between settings depending on what monitor you use.
Jul 29, 2007 | Sova DSV32P112 32 in. LCD Television
Sova DSV32P112 32 in. LCD Television Logo
161 people viewed this question
Top Sova Televison & Video Experts
olayoju victor
loony2ns
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Sova Televison and Video Expert? Answer questions, earn points and help others
