Question about Vizio L30WGU 30 in. HD-Ready LCD Television
Picture goes black, but audio stays on ????
Have a vizio 30"... its about a year and a half old. Just today it starting acting up. after about 15 or 20 minutes of being on, the screen would just go black. The sound would remain on. the unit is not hot or making any strange noises. Have been told it could be my cable box (comcast), so I resent it as I was told.... Still happens. Any suggestion ??? Don't want to just replace it without trying all options. Thank you to all.
  • 10 more comments
  • frank2198 Nov 13, 2007
    while watching my visio, i changed channels and suddenly picture went black but audio stayed on. Even after connecting the cable directly, still picture was black, audio on. Called vizio, given a phone number that is always busy. I would like to find a repairman in new york city.
  • Negron59 Nov 16, 2007
    This VIZIO L30WGU 30" LCD is about a year and a half old, I used it as a TV for a while then moved it to my PC when I bought a 42" Lcd for TV Vewing. wll, all of the sudden the TV went Black, came back a couple of times then went completely blank but I hear the sound from my pc playing music. I opened it to find the PS Module had a slight burn in the 120V input but not enough to loose contact or power, the on and off of the sound is suggesting that the PS is trying to operate but finds a dead short, or that a transistor in the PS is bad, eitherway I cant find anyone in Florida to fix it (afraid at an unknown brand) or find a service center for these Clowns at Vizio. so much for what $1000.00 can buy you these days
  • Liberalpercy Dec 17, 2007
    Same problem - screen went off and on for about a week - now it won't come on at all. Called Vizio - talked to a very nice tech support guy who said it sounded like a power transistor on the main motherboard. Working to see if I can get the part myself (I've done a lot of PC repair over the years.) Mine is about 2 1/2 years old and has been great up to this point.
  • grizou Dec 20, 2007
    The screen is black. The audio is still on. The L30WGU is 3 years old.
    Could be the lamp?
  • Obed1213 Feb 25, 2008
    I've got a 42" Vizio about 1 1/2 years old and the screen is just black as I turn it on. there's sound, but no image. I've been told is the lamp that projects the image
  • greida Mar 13, 2008
    I have a Vizio L30WGU The tv has sound but no picture. The technician that try to repair the tv said thaat was the inverter, I buy a new inverter (V144-301) in Moniserv, but the tv continue with this problem, I'm thinking to return the inverter to Moniserv. The technical support said maybe if the inverter was damage is possible that the Power Supply is damage too. How can i know is that the problem of my tv. The tv has 21/2 years of use. Please let me know the possibility of to repair the tv.
  • jupiter4hp Aug 25, 2008
    I have the same problem. took it to a tech, Of course it worked fine for him.
    Now I get a faint flash when I turn it on, then black.
  • twowheelin
    twowheelin Nov 07, 2008
    My VisioL30WGU is about 2 1/2 years old and the picture is going black while the audio stays normal. If I turn it off an back on after about 5 minutes the picture is back for a few minutes but then goes black again. Looking for local repair shop or may do repair myself if I can find a schematic...
  • look421 Nov 14, 2008
    I Have a L30WGU30 and the Black screen problem. I just bought a new inverter, I go and hook up the inverter and the screen is still black, but like one of the previous articles I can see the outline of the menu {(when you hit the menu button on your remote while the black screen is up you can see the outline of the menu on the screen) So they said this means that its the inverter but I just installed my new one} So from here what is the better choice . Should I buy the MainBoard or the PowerBoard, or could it be a smaller chip. Ya I should get a new one but I really want to get this tv running again, and I really want to solve this.
  • kthomas21 Jan 03, 2009
    I have the same problem. I have a 50" LCD Vizio. First the picture comes and go. Then, the picture went all together leaving just the sound. Finally, the sound went. Now I only have sound if the DVD player in on.
  • ronald borick Jan 13, 2009
    i have the same problem. this tv "sucks"!!!!
  • dave184 Jan 27, 2009
    I have the same problem with my L30wgu
Well i have the same tv , and when i took it apart i switched a few wires around and i managed to get it working again, i can send some pictures of what i did because, i really had no clue what i exactly did by switching the wires.
Posted on Jul 26, 2008
  • Pugnadroid Dec 09, 2010
    Yes i want some pics.
Vizio service said problem was in inverter board and they had no replacement part. The did offer me a new 32" TV for $300. I took old TV apart and confirmed the inverter board (which drives the lamps) shut off after a few seconds despite the correct power coming from the power board.
Posted on Jan 03, 2008
    Problem Solver:
  • 10 Answers
To make sure it's the cable box, hook up a DVD player and see if the TV still blacks out. If the TV still blacks out, then TV is faulty. When the TV has blacked out, can you still see outlines of the images. To see this, get really close to TV. If you press Menu, you will see the outline of the menus options box. If this is the case, Inverters are faulty. Otherwise, Main board is the most likely culprit.
Posted on Jul 29, 2007
    Problem Solver:
  • 7 Answers
Thanks I'll Try Calling, Offer not bad at all
Posted on Jan 04, 2008
  • 3 Answers
Sen Alagic fixed my problem- TV works great- email him plasmatech@gmail.com
Dave184
Posted on Feb 20, 2009
    Habit-Forming:
  • 166 Answers
Boards are also available from tigerdirect.com. The inverter board is over $300 and the power board about $105. The main board is over $400. I'm hoping my problem is a power board, or I'll get a new TV....
Posted on Nov 07, 2008
  • twowheelin
    twowheelin Nov 10, 2008
    Because of the mixed reviews on the success of Inverter board repair, I brought my Visio L30 TV into a repair shop. My problem is not the inverter board, but the main board. At a repair cost of over $400, I'll be buying a new TV!
  • twowheelin
    twowheelin Feb 20, 2009
    I had the same problem and had it evaluated at a reputable repair shop. It turned out to be the main board and was over $400 to repair. My problem history is recorded in this area.
  • 51 Answers
Hi everybody!
GOOD NEWS!
Refurbished Inverter board that will fix Vizio "no picture has sound" problem is available.
Please contact Sen on plasmatech@gmail.com
Posted on Jan 11, 2008
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
Dec 30, 2015 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
I have had my 55" Vision for a year and a half. Today I was watching a movie and the picture went dark and audio stayed on. If I turned the TV off and then back on it would light up with no Vision logo...
Sounds like you have a backlight problem. To verify this, turn on the set and dim the lights in the room. Take a bright flashlight and shine it on the screen. If you see a faint picture, you either have a back inverter or a bad backlight bulb.
Sep 02, 2013 | Vizio GV42L 42 in. LCD Television
Vizio TV has purple haze and colored stripes on the sides of the picture.
You possibly have a failing hi-voltage module or fly-back transformer going bad. If it has a fly-back transformer, It's not worth the trouble. Some repair shops will sell you a module. Call a repair shop for help.
May 09, 2017 | Vizio Televison & Video
No picture when on for approx 15 minutes
It sounds like you are saying the "video looks scrambled but the audio keeps playing OK"
Normally this is a Video Processor Problem that requires a Board to be replaced.
When the problem happens, can you see the TV menu or the TV's On Screen Display clearly.
I suggest checking to see if the problem happens with the video inputs like, Composite(yellow/red/black), component(RGB/yellow and black), HDMI and S-video. If it happens to all inputs then you need to replace a board.
May 21, 2009 | Vizio VW37L 37 in. LCD HDTV
17 yr. old 35" RCA loses color intermittently. Picture & sound ok
Three guns Red Blue and Green in the picture tube of an old CRT set. If one of the guns goes out it effects that color. Sounds like one of the guns inside of the tube is going out, To costly to replace for such an old antilog set that will have to have a convertor box next month anyway.
Jan 12, 2009 | RCA 15L500TD 15 in. TV/DVD Combo
Visio LCD TV - Partial Picture blacked.
Hello! I have a 32" Vizio LCD...within 30 minutes of the tv being turned on, black lines start running through the bottom half of the screen and eventually blacking out the bottom half of the tv screen. It also doesn't have anything to do with the ratio as I have tried that. HELP!
Jan 06, 2009 | Toshiba 42HP66 42 in. LCD Television
My Sony comes on then both sound and picture goes black.
After being on a little while, the screen goes black (no audio as well) for 20 to 30 seconds. Green light stays on. Then, picture comes back on and takes a couple of seconds to get up to full brightness. About 5 seconds or so after the video comes back, the audio returns.
Until this morning, has only happened a couple of times a day, now happening more often. About 3 times in last 20 minutes.
KDF-E55A20 is about 3 years old.
May 03, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Vizio L30WGU 30 in. HD-Ready LCD Television Logo
4,810 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
