Question about Samsung UpStage SPH-m620 Cellular Phone
Samsung keypad locked
Help, my keypad is locked i only get a black screen that says keypad locked. cant flip it either
  • emmav Feb 13, 2009
    my phone has done this too, did you find a solution?
UNLOCKING YOUR KEYPAD
theirs a button that you slide up and down. ... (you may try to push it but it wont work... you need to slide the button.) I had to go to my sprint store to figure this out.. :)
Posted on Feb 15, 2009
Tip
How to lock a Samsung Intensity cell phone
Unlike flip phones, cell phones like the Samsung Intensity are subject to accidental keypad-pressing and dialing when they are in your pocket, purse, or even a holster. To avoid unintentionally using up voice or data minutes, you can lock your phone and temporarily disable the keypad.
There are two ways to lock a Samsung Intensity - the standard keypad lock and the security lock.
- To use the standard lock:
You can lock your phone at any time from the main screen by holding down the "0" key for about two seconds. The keypad will immediately lock, and you won't be able to use any functions or make any calls (except for calling the local emergency number). To unlock the phone, press the right option button (in the upper right corner of the keypad, next to the End button) followed by the Menu or OK button.
You can also set up Auto Key Lock, which will automatically lock your keypad after the backlight turns off. The Auto Key Lock setting can be found in the menu under Settings & Tools > Phone Settings > Auto Key Lock.
- To use the security lock:
The security lock also prevents your keypad from being used, but it requires a code to be entered in order to unlock the phone. To enable the security lock, go into the main menu and select Settings & Tools > Phone Settings > Security > Lock Phone Now. (You'll need to know your phone's security code in order to access this setting -- by default it is typically the last four digits of your phone number.)
To unlock the phone, press the right option button and then enter your phone's security code, followed by the OK button.
You can set your phone to go into security lock mode as soon as you turn it on by enabling Phone Lock Setting under the Security menu. Every time you turn your phone on, you'll need to enter the security code in order to unlock it. However, once you unlock it, it will remain unlocked until you either manually lock it or turn it off and then back on.
on Mar 04, 2011 | Samsung SCH-U450 Cell Phone
Tip
How to lock or unlock a Samsung Intensity
Many people like the Samsung Intensity because of its slide-out QWERTY keyboard. However, one drawback to the phone for some users is that, unlike a flip phone, the numeric keypad is always exposed. When the Intensity is kept in a pocket or purse, this can result in accidental phone calls, multiple all-black pictures, and sudden activation of the voice command feature.
Luckily, you can lock the phone's keypad to keep it from engaging any functions when you're not using it. Locking the keypad is easy. Just hold down the 0 (zero) button for about two seconds, and a message will pop up telling you that the keypad has been locked. While it's locked, you won't be able to use the numeric keypad.
The standard way to unlock the phone is to press the upper right options button (the one that you would typically press to bring up your Contacts list) and then press the center OK button. (You will see prompts for both of these buttons when the phone is locked.)
However, there is also a quicker way to unlock the phone -- just slide the keyboard open. Sliding the keyboard open will unlock your numeric keypad immediately, and even when you close the keyboard the phone will remain unlocked. If you want to lock it again, you'll have to hold down the zero button to re-lock it.
You can also enable Auto Key Lock mode, in case you think you'll forget to lock your phone. With Auto Key Lock mode turned on, your phone will automatically lock itself when it's not in use and the backlight goes off. You can turn Auto Key Lock mode on or off from the Phone Settings menu.
on Jun 28, 2010 | Cell Phones
I have a myphone T23 duo i cant get back to the home screen once i unlock keypad! it's not phone lock, it's keypad lock.. pls help!
"on screen lock, lightly touch the soap inside the bubble, then move it outside the bubble, you'll see that the bubble will pop back yer main screen." nasc780@yahoo.com
Oct 08, 2010 | Kitchen Ranges
WHITE SCREEN ON SAMSUNG E250 FLIP FONE
change ic. it cost 250rs in india. now calculate your money.
Tenzin
May 12, 2010 | Samsung SGH-E251 Mobile Phone - Black
Frozen motorla razor phone
most carrier retail stores have cellbrite machines and can retrieve your numbers so long as the phone powers on
Mar 24, 2010 | Motorola Mobility V620 Cellular Phone
Unlock pantech c3b
Lock or Unlock the Pantech C3b Goal:
Lock or Unlock the Pantech C3b Fact:
Pantech C3b Fix:
Pantech C3b Keypad Layout
Keypad Lock
The Pantech C3b does not have a Keypad Lock feature. When device is not in use, close the flip to guard buttons from accidental contact.
Lock the Phone
  1. From the standby screen, press Menu.
  2. Scroll to and select Settings.
  3. Scroll to and select Security.
  4. Scroll to and highlight Phone Lock.
  5. Press the directional pad left or right to select Enabled.
  6. Press OK.
  7. Enter the Password.
  8. Press OK.
Unlock the Phone
  1. From the standby screen, press Unlock.
  2. Enter the Password.
  3. Press OK.
Aug 26, 2008 | Lands Phones
Screen is Black
You can replace you flip that should fix the problem...
Once you locate one here is a tutorial to remove the flip..
http://www.nextelmodz.com/forums/showthread.php?t=19073&highlight=i870+housing+tutorial
Apr 10, 2008 | Motorola Mobility i870 Cellular Phone
Keypad Locked on Samsung SGH-E250
my upper key pad not functioning except call and power keys what should i do? and some times hanging on white screen. pls tel me the solution
Jan 17, 2008 | Samsung SGH-D900 Cellular Phone
Keypad lock
You cant lock the keypad of an sgh e570 it is locked as soon as you close the flip on the phone
Nov 18, 2007 | Samsung SGH-E570 Cellular Phone
Samsung UpStage SPH-m620 Cellular Phone Logo
244 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
