Question about Koss C928 System
Sound but no video
I have sound and the dvd is playing, but i have no picture. i have the red and white plugs hooked up to the audio out but the yellow video plug isnt working. i tried the 2 options for video out ( one says "rec" and the other says "mon" ) there is also a digital out that says coaxial. that also didnt work. do i need a differant or additional wire?
  • 64 Answers
Run your yellow cable from the DVD player directly to the TV in the port connected to the red/white cables. If this is already done or doesnt, work, let me know
Posted on Jul 26, 2007
  • Leo Bas
    Leo Bas Jul 27, 2007
    We did the live chat and you didnt pay. I solved so please set as solved thanks!
We have no sound when we play a disc..picture is on.
How are the DVD player and the TV connected?
Coax cable? (Carries both audio & video.)
Composite output? (Red & white for audio, yellow for video)
Component output? (Red & Blue & Green for video, White & Red for stereo audio)
DVI output? (Video only)
HDMI output? (Carries both video & audio)
Feb 14, 2015 | Televison & Video
Hook up to dvd player
There are more than two methods of hooking up the DVD player.
1) Get a 5pin component cable with Red, Green & Blue pins. Connect the DVD Player's RGB out pins to the TV's RGB in socket. This will take care of the picture. Then for sound you will need the secondbobhifi_4.jpg set of Red & White cable. Connect the Red & White pins to the DVD players audio out socket (Red for right channel and White for Left channel ). The other end of the cable you can connect to the Red & White socket next to the RGB socket where you have connected the Video. Play a DVD and scroll through the inputs slowly. You will see the picture appear on one of your selections.
Mar 10, 2011 | Daewoo DP42SM 42 in. HD-Ready Plasma...
DVD plugged into red, white and green(Yellow) TV imputs, results
Yeah no color coz its black and white. Color coding commonly yellow wire for video, red and white wire for audio. It should also be from DVD to TV, video out and audio out going to video in and audio in. And switch the TV to play video and the audio inputted. Maybe TV/Video Switch or button.
Hope it helps
Apr 06, 2009 | Jensen TS2750J TV
Dvd/vcr hook up to sony tv, not playing picture on sony tv
The simplest is Video out an the DVD to Video in on TV, Yellow, red and white. If the TV has component input this is better. That is Green, blue and red for the video plus red and white for the audio.
Apr 01, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
DVD is playing in black and white
check the norm pal or ntsc,or video format
Feb 17, 2009 | Pioneer DV-333 DVD Player
No Sound when playing a video game on Coby Pertable DVD player
Do you have the audio plugs in the proper spot? The red & white audio plugs from the PS 2 need to be plugged into the audio in jacks on the portable dvd player in order to get sound. Should match up red to red; white to white for sound, yellow to yellow for video. Hope this helps.
Feb 03, 2009 | Coby TF-DVD1023 Player
Dvd playing blue picture
if it is hooked up with componant, thats the red blue green cables for video, and red white for audio, then you probabily eather dont have the red pluged all the way in, or you have the red audio, and red video---reversed, make sure to check them on the dvd player, and on the tv, if there correct, try using the composit input, that is the yellow red and white
Jan 11, 2009 | Samsung Televison & Video
Hooking up a d.v.d player to a vcr/tv combo?
RCA plugs (the yellow, red, and white outlets you speak of) consist of a video plug (yellow) and stereo plugs for audio (red and white). Just match the colors from the DVD RCA colors to the RCA hook-ups on the TV (ex. Yellow the Yellow, White to White).
You don't need to worry about the red one, it just makes the DVD player play stereo audio. Instead, you'll have mono, which is fine, and most modern players can detect mono and switch it for you so don't worry about changing settings and what not (unless you're missing sound on one side.)
Sep 13, 2008 | Optical Coating Model 108 VHS VCR
Can't get my dvd/vcr to tape and play back
Color codes for A/V cables:
Yellow: Composite Video
Red: Right Audio Channel
White: Left Audio Channel (mono)
Does your TV have a video & audio OUTPUT on the back of the TV?
If so, will need another set of audio/video cables and you need to connect the yellow cable from the video OUTPUT of the TV to the video INPUT (yellow) of the DVD/VCR and connect the Red cable from the right OUTPUT of the TV to the red INPUT of the DVD/VCR. Then connect the white cable from the left OUTPUT of the TV to the white INPUT of the DVD/VCR. If your TV is not in stereo, just connect up the white cable for mono audio.
If your TV set does NOT have audio/video OUTPUTS, then you will still need another set of audio/video cables and connect the yellow cable from the video OUTPUT of the cable box to the yellow video INPUT of the DVD/VCR and connect either the red or white (or both if possible) to the red or white audio INPUTS of the DVD/VCR.
You need two sets of cables because you want to watch DVD's & tapes on your TV (Path #1) and you want to record the TV channel shows back to your DVD/VCR (Path #2).
Please let me know if I can be of further assistance to you.
Good Luck!
- Jim
Feb 21, 2008 | Televison & Video
DVD VHS recorder
It sounds like your cables are connceted ok, but what you neede to do is to be able the switch from one video mode to the other so lets go through the cable and vrc conncetions again just to make sure. From your cable set top box connect your component video (RGB) video out to your TV (RGB) video in via the (RGB)cables. From your VCR connect your composite video (yellow) out to your TV composite video in withe the composite video (yellow) cable. From your VCR (Left & Right audio out)connect your left and right audio connections (White and Red) to the Audio in of the TV (Left and Right). Whith this setup you should be able to use the TV to switch between the two A/V inputs using the remote control.
Sep 03, 2007 | Philips Magnavox 27MS343S 27" TV
Koss C928 System Logo
104 people viewed this question
Top Koss Audio Players & Recorders Experts
Steven Wander
Steven Wander
Carlos L. Burgos
Carlos L. Burgos
Michael Galve
Michael Galve
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
