Question about Sony 32IN TV Stand Designed for Model KV-32FS120
TV WILL NOT COME
I HAVE A SONY TRINITRON ''32'' WEGA MODEL KV32FS120 AND IT WILL NOT TURN ON . THE LCD RED LIGHT KEEP' BLINKING
  • sevine Feb 01, 2009
    THANK YOU FOR THE SOLUTION IT WAS VERY HELPFUL.I APPRECIATE IT VERY MUCH.
    EVINE
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
The blinking LED light indicates that the auto protect mode has kicked in. This signifies that the TV's built-in diagnostics sensed an internal fault. Often this would be a hardware failure and depending on the number/sequence of blinks could be from power supply, vertical or HV (horizontal). Pls post back the sequence/number of blinks.
Additionally, this of course would require opening the unit, perform voltage measurements,determine faulty component and subsequent part(s) replacement. Further, a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron would be required. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings.Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Good luck and Thank you for using FixYa.
Posted on Jan 29, 2009
  • 11,896 Answers
This model is known for having power supply issues. I suspect from the information you have provided the power supply is causing the problem. I never reccomend replacing any part unless it is tested and proved to be defective and that the other circuits in the TV are verified not to have caused the original part to fail.
  • 32 Answers
The problem is most likely a shorted horizontal output transistor. Another thing this could be is a bad CRT.
I suggest you take it to your local TV repair shop and see if they can repair it.
If you still have waranty on it try calling sony to see if they will fix or replace it for free.
goto www.sony.com to get contact info for sony (I cant give you the info because I dont know what country you are in)
I hope this helps
Have a great day
    Brigadier General:
  • 8,619 Answers
Looks like the lamp needs to be replaced. Has the lamp been replaced or would this be the first time. Usually what occurs for lamp replacement is the TV dies no video or sound after being turned on for 10 seconds to 2 minutes. But yours turns right back on after being turned off automatically which is odd. Normally after it dies, it starts a red blinking action. I think replacing the lamp will fix this issue. Also, replacing the lamp is very easy to do.
    Sergeant:
  • 221 Answers
Its the power supply board problem in your tv.it has to be checked and faulty components has to be replaced.
KV-32F BLINKING 3 TIMES
KV32FS120 or 32FV120 etc as codes vary by model number.
Apr 10, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My sony wega model KV32HS420 tv wont turn on.The tiny red light next to power button is blinking,I think its a timer or issue with the lamp.
I have a 60" Sony Wega LCD projection...not sure if it will work for your model, but ours would not turn on this morning and was blinking the 3 light error code. Which indicated that the lamp cover was not on. The lamp cover was on, but when you remove the lamp cover there is a small metal piece below where the screw goes to tighten the cover on. That piece needs to be pushed in so the sensor will not go off. This saved us potentially many hundreds of $$ in calling a repair person which is what all forums and threads suggested we do. Hope this helps.
Nov 23, 2009 | Sony FD Trinitron WEGA KV-32HS420 32" TV
STANDBY LIGH BLINKING 9 times...
I have a Sony SRS BBE Trinitron (WEGA). The last few days when I tried to turn it on using the remote the Red Light would go on but the TV did not turn on. I would have to press the power button again to turn it on.. I tought the remote battery was just low.
Today when I tried to turn it on nothing is happening and the Red Light is blinking 9 times ??? I tried to unplug it and try it again, still does the same thing ???
We need help...
Lori Nall
Jun 19, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
MY SONY
how many blinks do you see or count on the red led
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-36HS500 blinking red light 6 times
smack it on top a couple of times, it works for me :)
if ya cant duct it, smack it...
seriously...
Jun 29, 2008 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Model KV-32FS120
your set may have shorted hori output transistor NTE2324.or bad capacitor by hori.
Jan 17, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
