Question about Pioneer SD-532HD5 53" Rear Projection Television
Pioneer SD-532HD5 Projection Screen TV won't turn back on.
I have a Pioneer SD-532HD5 Projection Screen TV and it just shut itself off. I heard it click and the green power light toggled back to the red standby light. I figured I had accidentaly pushed the power button on the remote, so I tried to use the remote to power it back up. The remote's batteries are fresh, but it did nothing. I tried turning off the Master Switch (the red light went off). Now, whenever I turn back on the Master Switch, the TV tries to turn on. I see the green light click on - then it immediately clicks back off and the red standby light comes back on. Any suggestions?
  • 5 more comments
  • cleckert Nov 18, 2007
    I have the same TV and mine cuts off with a loud pop after watching it for a while, but the screen stays lit - just no pix. I notice if I leave the lit screen up for a while (15 mins) the TV will actually "pop" back on. It's very annoying.
  • bg3161 Jan 11, 2008
    i have the same exact problem as stewbra.
  • Anonymous Jan 24, 2008
    I am experiencing the exact same thing and am very frustrated in attempting to get any type of assistance to resolving the issue. If anyone finds out what need to be done... outside of purchasing a new LCD, please let us know. oneburningheart@aol.com
  • Anonymous Apr 27, 2008
    I have the same TV, SD-532HD5 and same problem. I can watch it for days, hours and sometimes only minutes before it shuts off. The picture and sound cuts out but the green light stays on. I have to turn the TV off and let it sit for awhile. It never happens if my house is kept cold, so I believe it's overheating. Does anyone know how much it would cost to fix this issue?
  • Anonymous Apr 28, 2008
    Yes, I am having the same problem. After the inital failure, the TV would work, during the cold winter months. As spring approached the TV will not turn on and does make a popping noise. It will only remain in standby, and will not turn on at all anymore.
  • Anonymous Oct 03, 2008
    same deal here, won't turn on at all., manual switch goes green for half a second, and nothing... new power supply maybe? or junk?
  • Anonymous Jan 07, 2009
    I have the same problem - Any way to fix this problem ?
    Problem Solver:
  • 7 Answers
The problem with pioneer projection tvs is that when they made the boards they never used enough solder for the circuits and you get cracks in the runs. thats why heat and cold will effect it. I had the same problem and I took out the board and resoldered every track I could and it works good now but my remote wont work if anyone has any info or prints to this tv please post on here
Posted on Sep 15, 2010
    Problem Solver:
  • 7 Answers
I just posted this in another thread, but mine would turn on then right back off, and it was a burnt/bad/cracked solder joint on the power supply board on the big transformer. Resoldered it and it works again.
Posted on May 30, 2009
The problem is the power supply components over heating. The power supply is on the back side right hand. supply extra cooling via a fan and it will stop shutting down. This is just a cheap and simple fix that wil tie you over for a while. cheers mates.
Posted on Mar 09, 2008
NEW POWER SUPPLIES DO NOT NECESSARILY FIX THIS PROBLEM. OURS STARTED ABOUT 5 YRS AGO. WE LEAVE THE TV ON AND HIT THE MUTE KEY WHEN WE LEAVE.
Posted on Jun 20, 2011
I had same problem, I bought a new power supply problem fixed.
Posted on Dec 29, 2008
  • 3 Answers
Right now i am having the same problem with mine but the first thing you need to do is check all the fuses. make sure that they havent blow. also check the fuses that are soldered onto the board. the are usually green or orange in color. you can buy new fuses at radioshack. they are about $2.00 for a bag of 4. if the fuses are not the problem try looking at the power supply they tend to overheat in these tv's very often. if you cant figure it out it would be best to call a technician it is a lot cheaper than getting a new tv. while the technition is there ask him what was wrong so in case it breaks again you will already know what to do. hope this helps...
Posted on Nov 01, 2008
I sorry, i don't want a propuse a solution, i want a solution, my tv pioneer sd-532hd5 have the same problem, but some body tell me that the voltaje regulator are bad, so he try to change the Q101 ( sk1554) , but when buy the part number, in the store change the cross refernce and give us a diferent part number, so , the board and same components burns and i can find the schematics to repair , so , please i apreciate the fact to help to repair my tv.
Posted on Apr 30, 2008
Resolder the power supply
Posted on Aug 03, 2008
I HAVE A SD-532HD5 RED LIGHT STAY ON....IT USE TO TURN OFF BY ITSELF ONE DAY IT WENT OFF AND NEVER CAME BACK ON ......THERE IS A RED LIGHT ON THE POWER BOARD
This model and others close to it have all sorts of soldering problems on the power board----fixed a lot of them by removal of power board and aside from fuses solder the ENTIRE board--every connection---bad connections develop with age and heat.
Oct 14, 2012 | Pioneer SD-532HD5 53" Rear Projection...
Pioneer sd-582hd5 shuts off while watching
internal components probably need to be cleaned.... sounds like a problem with t.v. overheating
Jul 11, 2009 | Pioneer SD-532HD5 53" Rear Projection...
SD-532HD5 TV shuts off when watching
Its is a cold solder joint on the board. The board is the one located at the bottom right of the tv when looking at the rear. Mine did the same thing. After refreshing mose of the large solder pints on the board, it stopped. Hope this helps!
Nov 11, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
When tv is turned on green light comes on then goes to standby
had the same problem on mine.
Found loose solder terminals on the main power transformer, resoldered fixed it up about 5 min.
Nov 01, 2008 | Pioneer SD-532HD5 53" Rear Projection...
Pioneer projection blurry picture
Sounds like you lost the converigence. Have you tried to realign the convergence through the user menu? Try that first and see what happens.
Jul 20, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Possesed awesome tv
the clicking noise is probably just the relay. I gyess it makes the same noise if ou turn it off manually with the remote? Does your TV have a sleep timer function? Check to see if this is enabled. You might also check the batteries. If they are old, or the battery compartment is dirty (leaking barteries etc) you might get strange behaviour. My remote lives a life of it's own, changes channels etc if the batteries are weak.
May 17, 2007 | Pioneer SD-532HD5 53" Rear Projection...
Pioneer SD-532HD5
it is time to buy a new one,,,sorry
Aug 23, 2006 | Pioneer SD-532HD5 53" Rear Projection...
Pioneer SD-532HD5 53" Rear Projection Television Logo
2,323 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
