Question about HP OfficeJet 6210 All-In-One InkJet Printer
I went to Walgreens to refill my black ink cartridge. When I put in in my printer, it keeps saying "remove and check right cartridge.......whats the problem????
  • cbsjimi Jan 29, 2009
    exact same problem and have had it before. Very annoying!
  • 55 Answers
unfortunately when you use refilled cartridges you some times get a bad one if you have a new one try it and take the one back that is giving you problems.
good luck
Posted on Jan 29, 2009
My lexmark X5410 will not accept the black and colored refilled ink cartridges from walgreens. It keeps reporting that the right cartridge is missing.
If you have refilled the cartridges 28 and 29, it's pretty normal that your printer won't print. Those cartridges are not for refill (they can be refilled, but won't work once the printer says they are empty). If you have refilled a 28A and 29A and it doesn't recognize the one of the cartridges, try removing them and clean the electric contacts with a dry cloth. Put them back in. If that doesn't help, I suggest you buy a new cartridge.
Apr 11, 2010 | Lexmark X4530 InkJet Printer
Office jet 5510 keeps saying wrong black cartridge.
Look on the right side where the cartridge goes, if the spring on the right is hanging loose it might have poked a hole in the ribbon cable at the rear near the contacts. If so it's time for a new printer, if OK, check the exp. date on the ink cartridge and if it's been refilled or a generic ink you may just need another one.
Jan 30, 2010 | Office Equipment & Supplies
Refilled ink cartridges at Walgreens, printer won't recognize
Hello!
28 and 29 are not meant to be refilled. They can physically be refilled, but they won't work. That is because Lexmark has put in a smart chip that doesn't allow refill.
You need to buy 28A and 29A or 34 and 35, those cartridges can be refilled with no problem.
If you find my answer helpful, please vote. Thank you!
Aug 05, 2009 | Lexmark X2550 All-In-One Printer
Estimated ink levels are incorrect
The simple solution is to buy the HP cartridges. Often times,.. MOST times, aftermarket ink cartridges and refill kits are an inferior product. The difference is not always noticeable right away, but almost always rears it's head in the end. This is usually due to the ink being of a different viscosity than the original ink. Which leads to sloppy prints, sensor errors, leaky or dead jets.
Personally I recommend everyone buy Laser printers. With prices where they are these days, there is no reason for anyone to buy an inkjet printer. Lasers will cost more up front, but are much cheaper per page and generally longer lasting.
Feb 15, 2009 | HP PhotoSmart C4280 Laser Printer
Ink cartridge
you may check your ink cartridge
long time less using cause 3 color ink chanel(holes) a little dryer, could not print well even refilled.you may take out the color ink cartridge and put it's surface of bottom (just touch ) in the clean water 1 -2 Hrs, then set back and test it. still not fixed, you also need to do same thing if your print head is separated from your ink cartridge
Jan 20, 2009 | Lexmark X75 All-In-One InkJet Printer
Refill ink not printing Lexmark x4550
take the cartridges out and clean them also clean where they go with a lint free cloth then replace them.
Jan 08, 2009 | Lexmark X5150 All-In-One InkJet Printer
Unable to print with new ink carts
Usually, that message means that your cartridge is dead. Try removing it, clean the electric contacts on it and the ones on the cartridge carrier. Put it back in. If that doesn't help, you will need to buy a new color cartridge.
If you do not have a replacement cartridge, you can still print in, what HP calls "ink backup mode". Simply remove the problem cartridge, and print with the remaining one, in this case, the black one.
  • If you remove the tri-color cartridge, printouts will be in grayscale.
Dec 23, 2008 | HP Deskjet D4160 InkJet Photo Printer
My Hp does not recognize my color cartridge?
Sometimes the color bleeds over. Did you wipe down the contacts and clean the heads? Also, most of the cartridges have low ink sensors in the. Even if you have them refilled, they will still show as low ink. The only solution is to buy the new ones.... $$$$$$.
Dec 12, 2007 | Dell 922 All-In-One InkJet Printer
Cartridge error
How I solved this problem was, I took out the color cartridge (which seem to be the one giving the error message) and worked only with the black ink (and chose print black and white )
My color ink cartridge had been refilled at Walgreens. The Black ink cartridge is an original Lexmark
Oct 22, 2007 | Lexmark X3480 InkJet Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
90 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
