Question about Beverage-Air MT45 Beverage Cooler Commercial
Need part number
I need to know the part number for the left side light holder / fixture inside the cabinet Not the front panel for a MT45 double door cooler and where I can get one ordered? Thankyou...
  • 410 Answers
I found this site that sells parts for the beverage air http://www.4emweb.com/search.asp this link is directly to beverage airs web site I'm not exactly sure which lamp holder you need they actually list 4-5 holders but look under the lights tab. thx peyton
Posted on Jan 29, 2009
    President:
  • 1,214 Answers
I am pretty certain that Beverage Air is owned by Sanyo.
Take a look at their website and see what you find.
But isn't the light holder just a standard florescent or other type of bulb holder?
Powerwindows not working, back ones left gos down not up, right gos up not down, i think relay,front l and r does nothing
you need to check the wiring harness on the drivers side front door where it comes from the inside of the car to the inside of the front d/s door....the best way to do this is remove the left kick panel and remove the left door panel.....then unplug the harness inside the kick panel and feed it out to the outside of the car and then to the inside the door panel.....untape and pull back the rubber around the harness and start checking for broken wires and also double check all of them by pulling on them.....these will break over time by opening and closing the door so much and always right in the bend of the door......this is a common problem on these cars....let me and fixya know if i was able to help you and a thumbs up and a comment would be appreciated......if i can help in any other way let me know.....thanks and have a blessed day.......
Jul 31, 2011 | 1993 Toyota Camry V6
Tip
How to get help so you can fix you own appliance
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Your model number is needed in order for someone to help with the diagnosis or your appliance. There are lots of different parts and each model is different. Post this number in the description of your problem and you'll be much more likely to receive the help you need .
It's usually stamped on a small tag in a visible location on your appliance.
On your refrigerator look
Behind the lower toe kick-plate, Behind the lower crisper drawer, On the face frame of the refrigerator body, Inside the refrigerator of freezer on the left or right side wall.
On your oven look Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} on the back side of the door at the bottom or edge. On the vent trim behind the center of the door.
Washer-Dryer
behind or on top of the control panel. Behind the door. On the lower front or side of the cabinet.
Dishwasher-
Inside the doorjamb on the top, left or right. On the door edge top left or right. Portable models on the back.
Microwave-
on the face frame behind the door or on the back.
on Jan 31, 2010 | Dishwashers
I bought it in 2003 neptune dryer and the 3 bar inside the dryer broke and the dryer is not working right . we have to dry them 3 time before they are all dry
Instructions
Things You'll Need:
* Phillips-head screwdriver
* Replacement belt
1. Disconnect the power cord of the Maytag Neptune dryer from the dryer electrical outlet.
2. Open the dryer door, and locate the four screws on the inside lip of the door opening. Use a Phillips-head screwdriver to remove the four screws. This will disconnect the front panel from the shroud assembly.
3. Grab the front panel on each side with your hands. Lift up on the front panel to unhook it from the retaining tabs on the side panels. Remove the front panel, and set it out of your way.
4. Use a Phillips-head screwdriver to remove the four outside perimeter screws that secure the shroud and tumbler front to the dryer cabinet. Pull the shroud and tumbler front away from the tumbler while lifting the top panel partially up.
5. Reach both of your hands underneath each side of the tumbler. Use your left hand to grasp the idler pulley, and pull it to the left while using your right hand to slip the belt off the motor pulley. Pulling the idler pulley to the left releases tension on the belt. You can now slip the belt off the back of the tumbler.
6. Take the old belt with you along with the model number of your dryer to purchase a new belt. Most appliance repair shops will have replacement belts in stock. Make sure that the new belt matches the old one by comparing the two.
7. Slide the new belt over the rear of the tumbler with the ribbed side pointed to the inside. Using both hands under the tumbler, route the belt around the motor pulley and idler pulley. Pull the idler pulley to the left while routing the belt, and carefully allow the idler pulley back to the right to apply tension.
8. Reattach the tumbler front and shroud to the front of the cabinet using the retaining screws. Place the front panel over the side retaining tabs, and push it down to lock it in place.
9. Open the dryer door, and secure the front panel to the shroud using the retaining screws. Close the dryer door, and plug the power cord back into the dryer electrical outlet.
Feb 28, 2011 | Maytag Neptune MDE5500AY Electric Dryer
PRPH toilet paper holder. the fixture attached to the cabinet and supports the toilet paper holder has a broken post. The post goes into the toilet paper holder and supports it. During remodeling, I...
Without more specific information or a product number difficult to assit; here is the website for the manufacturer where you can search for more information or find a parts supplier near you.
http://www.robern.com/info/documentation.rbn
Trust this is helpful.
Oct 26, 2010 | Robern Prph Projects Toilet Paper Holder...
I have a Maytag MDE4700A electric dryer. It quit working (turning) but still heated up. I took the cabinet apart and found that the belt was broke. Need some assistance on beginner steps for replacing...
Disconnect power to the dryer then open the door and remove the center screw of each hinge secured to the inner flange of the front panel in the door opening. Grasp the door with both hands and lift the door in the hinge area then draw the door assembly away from the dryer to disengage the hinges from the slots in the front shroud.
Remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top cover lip.
Disconnect the wires from the door switch, sensor bar, and the lamp holder then unsnap the lamp holder wire harness from the front shroud wire retaining clip.
Remove the four perimeter screws holding the shroud and tumbler front assembly to the cabinet. Remove the lowest outside screw at each corner then the top screw on each side.
Pull the shroud and tumbler front assembly out and away from the tumbler while slightly lifting the top cover.
Kneel near the front of the dryer and reach your left hand inside the dryer at 8 o'clock position and your right hand under the tumbler as close as possible to the blower then grasp the idler puller with your left hand and pull the idler upward and to the left.
Slip the belt off the motor pulley and the back of the tumbler then pull the tumbler out of the cabinet while lifting the top cover.
Place the belt onto the outside of the tumbler and position it 1 1/2 inches in front of the rear baffle mounting screws with the ribbed side facing the tumbler.
Position the tumbler into the rear felt seal and resting it onto the rear rollers then lower the front of the tumbler onto the blower housing.
Kneel near the front of the dryer and reach your left hand inside the dryer at 8 o'clock position and your right hand under the tumbler as close as possible to the blower then locate the belt and create a small loop with your right hand, ensuring the belt is free of twist.
Position the open end of the loop onto the motor pulley with your right hand. Grasp the idler pulley with your left hand then pull the idler upward and to the left to clear the drive belt.
Relax your left hand and allow the idler pulley to rest down onto the belt. Grasp the baffles with both hands and rotate the tumbler clockwise for the belt to align itself.
Reinstall the shroud and tumbler front assembly in reverse of the removal steps. Lift the front inner edge of the tumbler to allow the front of the tumbler to rest on the teflon bearings on the shroud and tumbler front assembly. Check the felt seal to ensure that it is outside the lip of the tumbler.
Secure the top cover with the hold down brackets then push the front panel posts against the clips in the cabinet until it engage.
Insert the door hinge tabs into the slots in the front shroud and secure the hinges with the screws removed previously to complete the procedure.
Aug 22, 2010 | Dryers
Right signal lights front and back do not work, I have changed light bulbs on front and back still does not work. Left side works. 2005 H2
Look in the fuse panel by opening the driver;s door and removing the panel on the side of the dash. There is a fuse specifically for the right and left sides. Double check that fuse. This is most likely. Let me know if you need anything else.
May 05, 2010 | 2005 Hummer H2
Left turn signal flashes faster than the right turn signal. how do i remove the bulb?
It depends on if its the front or the rear bulb. In the front the screws are mostly on the out side of the car. The baco screwa ar in side the trunk inside of the truck liner. You have to remove the hole light fixture from the car and then turn the bulb holder out to change the bulb
Dec 13, 2009 | 2006 Dodge Grand Caravan
Dryer won't heat. I need to check the thermal
need model number,if filter is on top,pull it out and take out two screws.get staight blade screw driver and put it in seam between the top of dryer and the cabinet and pop up on left and right side,{there are two clips holding the top on,one on the right the other on left side}, unplug door switch wires on right side and you'll see two 5/16 screws one on left and other on right around 4 inches down from the door switch,now grab top of front panel and pull up,there are two clips on bottom of cabinet that panel clips into,you'll see the fuse on the top of blower wheel housing,the fuse could also be located in the back of dryer too that's why you should send model number,hope this helps,while your in the dryer see if it needs to be cleaned out,that's what usually pops the fuse,check the lint filter duct,vac the inside of dryer and blow out the vent line,make sure the flapper is blowing open outside
Nov 07, 2009 | Dryers
My dryer does not heat up. I need to take panel off in order to replace. How do i do that?
Nov 04, 2009 | Kenmore Dryers
Freezer is working good but the fresh food side is warm.
I will need to get a little more information to help you better. Sounds like the defrost timer is bad but I will need a number like for example 915.125869
Let me know, Thanks Sea Breeze
Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
Feb 27, 2009 | Kenmore 53642 / 53644 Side by Side...
Beverage-Air MT45 Beverage Cooler Commercial Logo
193 people viewed this question
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
