Question about HP Photosmart 2410 All-In-One InkJet Printer
HP 2410 printer won't boot up, just makes a clunking sound.
I have an HP 2410 all-in-one printer that starts to boot up and then I hear something moving inside the printer and it starts going clunk clunk clunk clund etc. After ten or so clunks, it shuts down. It makes no difference whether it is connected to the computer or is not connected. It does the same thing every time I try to start it. It is operating with a computer running XP and I have used it for a long time without any problems. Recently I have had to turn it off and on several times and it will stop the clunking sound and print but now it just goes into the clunking sound no matter what it do to it. Is there anything I can do to fix it???
  • 1 more comment
  • chillasgifts Feb 27, 2009
    hp 3330 all in one printer makes clunking sound also. Today it won't stop, even after leaving unplugged. Thank you for any help!
  • Anonymous May 04, 2009
    printer starts to boot up and then starts making clanking and clicking sounds and then just shuts down. Tried unplugging for a few hours and didnt work. Thanks if you can help.
  • David
    David Oct 30, 2014
    Mine doest this also,,unplug and let transformer cool down for a couple of hours...plug back in and it always runs fine again...If you can say an hp2410 is fine of course.
    New Friend:
Unplug and let the transformer cool down for a coule of hours replug and the system works again...very frustrating until you find a fix.
Posted on Oct 30, 2014
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 544 Answers
Someone just had a similar problem.
Unplug your printer for a few hours.
Plug it back in and the problem clear.
Posted on Jan 29, 2009
Whilst just starting ti print there was an unexpected noise form the printer, like loud clunk. Now it won't print - it says there is paper jam but there isn't. Press OK to clear jam, then it does...
Sounds like one of the gears has probably broken
check out the HP website for suitable alternatives .if your in the uk try http://h40059.www4.hp.com/uk/printers/ otherwise start at http://www.hp.com/
Sep 02, 2011 | HP PSC 2355 All-In-One InkJet Printer
My HP 2410 Photosmart printer is making a clicking nose on start up. In the past I was instructed to unplug it and everything attached to it, including the computer, for 15-30 minutes and it would reset...
Uninstall the printer completely starting from the software.
Go to Start Menu, Control Panel, Add/Remove Programs, select the HP Photosmart software and remove it.
Then, go to Start Menu, Control Panel, Device Manager (usually under Administrative Tools/Computer Management).
Select under "Printers", the HP Photosmart 2410 All-in-One InkJet Printer and remove it.
Restart your computer and follow the instructions from your HP manual to setup your printer again.
Apr 06, 2010 | HP Photosmart 2410 All-In-One InkJet...
HP psc 2410 photosmart all-in-one not piking up paper
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Sep 16, 2009 | HP PSC 2410 All-In-One InkJet Printer
Hp 2410 just clicking
When you power on the printer.
See if the scanner light move to the right and then keep on clicking.
If this happen, the scanner head is unable to find home position.
You will have to clean the strip under the glass.
If this only start to happen recently, you could unplug the printer and wait 1 hour.
Replug in the printer will at times stop the clicking.
You can go to http://h10025.www1.hp.com
Enter c00553775 into the search block.
Click on Hp All in one how to clean scanner glass.
This will bring you to the HP document.
Jan 27, 2009 | HP PSC 2410 All-In-One InkJet Printer
2410 photosmart all in one
unplug the power cable
Press and hold # and 6 on the printer while keeping these tow buttons on hold plug the power cable back in . when the screen goes off release the buttons and press the power button to turn the printer on. it ll perform a semiful reset on the printer .
if the issue still persists then unplug the power cable again
Press and hold OK and CANCEL on the printer while keeping these two buttons on hold plug the power cable back in . when the screen goes off release the buttons and press the power button to turn the printer on .
it should fix the issue else call HP CARE and they ll replace it for u
May 22, 2008 | HP PSC 2410 All-In-One InkJet Printer
This is a common problem. You did the correct procedure. Lubricating the rail is what I would do. What you need to do is find the best type of oil to use. Some may actually make it worse. Start by cleaning the rail with alcohol. Saturate your rag and move the rail back and forth to make sure you get all of the old lubrication out of the rail bushings. Really do a good job at this because the old stuff is actually creating the problem. Next is lubricating the rail. I use 3 in 1 sewing machine oil. It is a very thin oil that will last longer for you. Never use teflon or wd-40 this will build up and make it worse. Give it a try. I also have seen the rail where it is worn because of lack of lubrication and it was not worth fixing but that is the extreme case. Thank you for your question, Bill
Mar 31, 2007 | HP Photosmart 2410 All-In-One InkJet...
Machine won't boot up
I found this suggestion on line and it worked. After turning on my hp psc 2410 photosmart all in one, it just started making a peculiar sound and wouldn't boot up. It was useless. What I did to correct the problem (as per suggestion from cdpena@sbcglobal.net) was to hold the cancel button down before I turned the printer on and hold it down through the start up process. The thing works now. The problem may have been caused by a power outage. Thanks cdpena@sbcglobal.net. I almost bought another printer.
Sep 04, 2006 | HP PSC 2410 All-In-One InkJet Printer
HP Photosmart 2410 All-In-One InkJet Printer Logo
591 people viewed this question
Seeker5211
Seeker5211
