Question about Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television
Mitsubishi 55 in. WS-55315
Suddenly a black box pops onto the lower portion of the screen. If you press the volume on the TV remote it goes away but will pop back on sometimes right away other times after a few minutes and sometimes, on a good night not at all. Also goes away if you go through the screen formats until you get back to standard.
  • 398 Answers
Go into the menu and see if your closed captions are on and set to "TEXT". Setting the closed captions to "OFF" should solve your problem.
Posted on Jul 26, 2007
6ya staff
SOURCE:
Everytime ichange the channel ; a big black box pops onthe screen and the only way it can be removed is by clicking a volume button ; what can i do?
Tv still have it Closed Caption functions is on.U have the tv original remote wright?Yes.Look at ur tv remote control look for a button that said CC,push that button a couple times make sure like all CC1,2,3.. all to off.Closed Caption functions will turn off should have no more black boxes pops up onto the tv screen.Also used the tv remote control go into the tv menu go into Closed Caption funcions look for functions like Text 1,2,3... turn it all to off too.Should stop it for good,if Text also on too.If u don't have the tv original remote.Try website like Remotes.com to buy the tv original remote.
Jul 09, 2011 | TruTech T2000D TV
I have a vs-60609 60"
Sounds like a Picture in Picture screen popping up, but if you do not have a signal from another tuner, it will be blank.
Try hitting the PIP button on your remote to see if it turns it off and on.
Plus go into the tv menu and find the PIP settings.
Apr 15, 2011 | Mitsubishi VS-60609 60" Rear Projection...
TV is about 1 year old. Started yesterday having a black rectangle in the middle of the screen. Can press any button and it goes away but come's back in just a few seconds. Tv is a Element ELCHS321
most times a black rectangle pops up when closed captioning is on. sometimes there will be gibberish in it sometimes not. See if you have button on remote labeled "CC" . Also if you have a cable or sat box make sure closed captioning is switched off there too.
Jan 21, 2010 | Televison & Video
My rca truflat tv will get a black box pop up on the screen. It covers most of the picture. Sometimes there will be text in the box. If I adjust the volume it will disappear for a few seconds then come...
It is a Text or Description box that operates like Closed Captions. Cycle through the options by pressing the Caption button on the remote or go to the Caption menu and turn it off.
Jan 17, 2010 | RCA TruFlat 27F520T 27" TV
I have a remote control TV. It is an old unit.
Hold in vol.up and vol. down at the same time. OR Channel up and channel down at the same time for 5 seconds. If you still have the same problem.Go into the menu and goto cc or close caption or text and turn it off. One of them should do it.
Sep 25, 2009 | RCA Televison & Video
RCA HDTV MENU AND VOLUME CONTROL POPS ON AND OFF SCREEN.
My TV was doing the same thing. Someone told me to disconnect the front menu buttons and this worked for me. The board goes haywire. You have to take off the front black panel on the bottom first then the grey front panel where the controls are. Once you do this you will see where there is a plug from tv to the panel where the control buttons are. Just disconnect. You will only be able to use your remote for TV. Its a cheap and easy fix. Just lots of screws to get the panels off and on. Good luck!
Apr 09, 2009 | RCA HD52W58 52" TV
Pioneer SD-582HD5 - screen went black, no sound, Poor remote feed
The blue tube might be leaking coolant in the high voltage area, that is the cause of the POP. This repair might not be a DIY because of the lethal high voltage surrounding the CRTs tubes.
The slow response from the remote could be because the coolant has affected the main board where the IR signal are going to the remote sensor.
Let me know if you require further assistance.
Dec 20, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Black box covering one-half of TV screen
Try turning off the text box function of the closed captioning.
Aug 02, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Black menu screen pops and hides half the tv.
that is close caption, get your remote control and press the close caption button.that's it
Oct 31, 2007 | JVC AV-27020 TV
Black box showing up while viewing DVDs
Go to your TV remote, in the menu find the closed caption or sometimes it is on the remote itself. Turn off the closed caption. this should solve your problem. Good Luck
Mar 28, 2007 | Sony DAV-C990 System
Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television Logo
121 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
