Question about Coleman Cable Power Inverter PMP1200
Cannot find location of the spade fuse
I have a Coleman pmp1200 power inverter -- received a bag of spade fuses, but do not know where you would use them -- would I have to disassemble the unit?
I have an older pmp1200 and NO, you don't have to take the back off. Those spade fuses are for an empty RV power buse position where you will connect the inverter to fuse the DC side. The PMP 1200 has pertection circuts inside for overload, but if a short on DC input were to occure it would not pertect your buse (and of course the battery) from causing a posible fire situation. Since the DC cable size needed for the maximum curent draw on this unit is so large (4 gage), I would recomend a direct battery conection fused via a fuse holder that can handele the max current (10 amps). Check with your local battery stores for such items. Warning: don't use fusing over this 10 amp rating because if the unit happens to short, it could start the battery to over heat and cause a fire or battery explosion.
Posted on Jun 03, 2009
Where can I get a fuse for a Vector 350?
Hopefully you are actually referring to a Vector VEC060 Power Inverter 175/350 Watt DC/AC as I cannot find a listing for a Vector 350 in the flashlight or spotlight listings.
The external fuse for the Vector VEC060 Power Inverter is a standard 30A spade type fuse available at any auto parts store. If you would prefer to purchase online, here is a link to them on Amazon:
http://www.amazon.com/Automotive-Truck-Plug-Blade-Green/dp/B00CJCS1V2/ref=sr_1_1?ie=UTF8&qid=1432440778&sr=8-1&keywords=30+amp+spade+fuse
May 08, 2015 | Vector Camping, Backpacking & Hiking
How to remove fuse from Coleman thermoelectric cooler
Unscrew the chrome circle at the tip and it will come out.
Nov 28, 2014 | Coleman Thermoelectric Cooler 12v...
Where can I buy a replacement 45 amp fuse that goes in the Schumacher 750 watt power inverter?
According to the Schumacher 750W power inverter manual it can take two 40 or 50 amp spade type fuses which can be found on ebay with the link below.
40 amp spade type fuses
Sep 03, 2014 | Electronics - Others
Can I back feed through my inverter from a generator to charge my batteries?
What does it invert?Higher voltage to lower or what?Either way,with 1200 watts being inverted,it is not a good idea to charge a battery with that kind of power.Batteries need to be charged low and slow.We are talking milliamps for hours.Fast charging a battery results in a very good chance of explosion,which is never good.Acid from the battery will go everywhere.
Aug 04, 2010 | Coleman Cable Power Inverter PMP1200
Inverter beeps when I plug in extension cord. Nothing else
it is possible the alternator's power is higher than that of the inverter ,that is overload
Nov 17, 2009 | Coleman Cable Power Inverter PMP1200
I attach my inverter with custom battery cables and it powers up. As soon as I plug in an extension cord (any cord)it starts beeping. I don't even have anything plugged into the other end.
please check the voltage of the battery may be the voltage of battery is low or use the multi meter and check DC volts before conneceting the battery and after conneceting once more check the DC volts it could slove the problem
the beeping sound is due to battery low voltage
what is the DC input of the Inverter check the battery hook up if the inverter is of example DC 24 volts please check what is the input
Power going up and down
An incandescent lamp that is cold takes approximately 10 times the running current initially. The inverter MAY not be able to start the 500 watt lamp if its protection circuits sense the very low starting resistance of the lamp.
Test the inverter on some other device first.
Jul 26, 2009 | Coleman Cable Power Inverter PMP1200
No power from inverter
There are some fuses at the output. plus the protection on the AC panel. Start at the Inverter output and check fuses and power there, then work your way out.
Jun 06, 2009 | Coleman Cable Power Inverter PMP1200
Coleman Cable Power Inverter PMP1200 Logo
321 people viewed this question
Top Coleman Cable Electronics - Others Experts
Are you a Coleman Cable Electronics - Other Expert? Answer questions, earn points and help others
