Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
My washer wont work
How do I change the busher on a washing machine and how do I take the top off
  • 183 Answers
No part known as the busher, please decribe in detail what part you are referring too. Regards Engineer
Posted on Jul 30, 2007
How can I fix the LED monitor so the cycles do not change mid cycle?
It sounds like a control problem. I assume it is electronic, and if so try another control board but be sure you can return it if it does not solve your problem.
Jan 11, 2015 | Haier Hlp23e Portable Top-load Washer
The washer works in all cycles but wont drain water
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jan 16, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Wont drain water
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
If you are having problems with your front load washing machine then checkoutthis tip...
heatman101
Oct 16, 2010 | Samsung WF218AN Front Load Washer
Why wont the washer start filling ?
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 25, 2010 | Kenmore 23822 Top Load Washer
Spin cycle wont work
heatman101
Sep 23, 2010 | Roper RAS8445KQ Top Load Washer
The water in my stackable washer and dryer wont drain
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 19, 2010 | Maytag LSE7806A Top Load Stacked...
Washing machine was working fine, but leaking water from the bottom. took it to a repairman, he said pumpwas stopped up and he replaced it. hooked it up and it fills with water but it will not start, wont...
if the washer machine idetifies the levels of water (ex low middle high) means that pressure switch works
there are two things!!!!
the switch's door is not working or the switch's timer also doesnt work
if the washer machine doesn't idetifies the levels of water does the problem
CHECK ALL THIS AND CHANGE WHAT IS NECESSARY!!!!!
Oct 05, 2009 | Roper RAS6233KQ Top Load Washer
Frididaire Washer Works but wont auto advance
hi thanks for the question The problem appears to be the timer change it thanks THE APPLIANCE DOC
Aug 27, 2008 | Frigidaire CWS3600AS Top Load Washer
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
41 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
