Question about Bushnell Field 78-3001 Tripod
I am missing one of the screws that holds one of the legs on
Can you suggest a place where I could find a spare screw that holds the leg on the tripod? The other ones look like a screw that goes into a hollow tube with a phillips head top. Where can I find a replacement as I seem to have lost one of them?
    Sergeant:
    Champion:
  • 373 Answers
Camera shop
Posted on Jan 29, 2009
How do I replace a leg release lever of a manfrotto 190XB? One of the three leg release levers is missing. I ordered a spare part (R190,304), but I don't know how to put it in place.
Hi Stefan
Possibly some bad news for you..., the Part #R190,304 you ordered is not made for the #190XB tripod..., it is for a model several years older (though it MAY fit)..., (see link for correct parts diagram)!!!!
http://www.manfrottospares.com/download/pdfs/190XB_20061025.pdf
To easiest way to replace one of the top leg castings is to first remove the centre column and then support the tripod in such a way that the (3) legs are not touching the ground (i.e.: all the weight is supported by the casting through which the centre column would normally mount. You will then need to undo the (3) screw (allen key style) that pierce this casting...., (the reason for wanting to support the tripod via the bottom of this casting is that all the small parts SHOULD stay in place when the top casting is separated from the lower casting. Once this has been done..., carefully remove the leg with the damaged top casting...., replace it (making sure the new one is facing the right direction) & then reverse the procedure.
Hope this helps
Peter
Aug 12, 2014 | Manfrotto (190XB,128RC) Tripod
Table broken leg
You need some kind of screws/bolts to hold the broken pieces in place before you can apply glue. At the end of your video, you showed the bottom view of the legs. If you can drill some holes at good positions, you should be able to put bolt and nut to hold the legs in place. Then, you can use super glue to keep the surfaces smooth.
Apr 11, 2014 | Furniture
Hooker Furniture Leather Recliner, how do I attach the legs?
typically legs in furniture are screwed in with a lag screw and lag bolt which the chair itself should already have a t-nut in place to accept the leg.....
Aug 27, 2013 | MBWFurniture.com Omega Blackberry Merlot...
Wind top AE1900 AIO MS-6638. how to replace hard disk
To remove back leg: pull off round end caps where leg connects to back (pressure fit). Then remove black stickers covering screw holes at base of leg. Under stickers are 4 screws - remove and lift off leg assembly.
Remove back cover: remove 7 black screws from back (one hiding under warranty sticker). Lift back from bottom edge (pressure connections on top edge). Back cover will catch on cd/dvd tray door - bend slightly to get around.
Under back cover is metal cover. Remove screws from around edge holding back cover on (note that most screws you will see in pairs - only remove the one holding the metal cover, not the one holding the chassis). Lift off metal cover.
You should now see hdd. One screw holding in position - remove screw, slide out hdd (it will have a metal frame around it). HDD is a 2.5" laptop style.
Swap out hdd from its frame, then re-assemble.
Oct 13, 2011 | Office Equipment & Supplies
I want to wall mount a FX2490HD and cannot remove the base I have remove the screw form the back but the base will not move
Hi, there are two screws underneath the legs of the stand and one other screw to hold the attachment that the legs connect to. If you have removed all three screws then try swiveling the legs.
Feb 12, 2011 | Samsung Televison & Video
How do you stabilize a kenmore dishwasher not to move
Greetings,
open the door and there should be two brackets that screw into the counter to hold the top. I would remove lower kickplate and you will find legs that you can move up or down,...I would set your d/w in place and scew the legs up to desired position...Then, screw brackets into top above d/w..this will hold d/w into place..if your happy with my answer. please let me know....thank you,
..........................Bruce Denton Master Appliance Technician
Dec 28, 2010 | Kenmore Dishwashers
Reassembling telescopic sections for a 676B monopod
Each leg lock has a leg locking lever and a screw that hold the clamp assembly tight to the leg. Unlock the leg lock lever, loosen the screw above it that holds the clamp tight to the leg. The legs should fit into each other sice each leg is slightly larger or smaller then then next one. Slide the clamps in the approprite places and tighten the screw enough to hold the clamp assembly tight, but do not over tighten it. Over tightening will damage the 679 tubes.
Dec 25, 2009 | Manfrotto 679B Monopod
Snapping monitor into stand
You slide in the 2 bent legs, then it doesnt snap. there are supposed to be 2 screws that hold it into place on the top portion of the stand. Find the correct screw size and your stand should keep your monitor up.
Aug 29, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
Bushnell Field 78-3001 Tripod Logo
111 people viewed this question
Top Bushnell Photography Experts
pontelemon
pontelemon
Are you a Bushnell Photography Expert? Answer questions, earn points and help others
