Question about ArcMedia JavaScript Source Code 3000 Pro (gar448) for PC
Factorial how i can make the program that solve the factorial problem
  • 68 Answers
Function to calculate factorial would be:
function fact(n){
if (n<=1) return 1;
return fact(n-1);
or nonrecursive
function factnr(n)
var f=1;
for(i=n;i>1;i--) f=f*i;
return f;
In both cases n must be an integer
Posted on Feb 03, 2009
I had some kicker 6x9 cs693 installed in my 2002 camry rear deck and when they returned the car the spearkers are not producing much sound or bass. I am using factory stereo and also the factory 6x9 on...
first check to see that the fader is not programmed to the front speakers fading it rear might solve your problem, second if your stereo has a 4 ohm load requirement at the output and your new speakers are 8 ohms this will cut the power output in half, your best bet is to get an amp if these do not solve the problem.
Feb 27, 2015 | Kicker Car Audio & Video
The tablet keep saying, unfortunately launcher has stopped
Usually this means that some program has corrupted the system files. A factory reset (which will erase all of your data and programs) may solve the problem.
Mar 17, 2014 | Proscan 8" Tablet with 4GB Memory
Factory reset lexmark x203n
I do not think resetting to factory defaults will solve this problem, anyhow this is how to reset the X203 to factory defaullts. Turn it off, Kepp press?d keys "check mark" and "right arrow". Turn printer on, wait until some dots show in the panel and release the buttons. Enter CONFIG MENU, browse right/left until you reach Factory Defaults, press Select / Check mark. Done.
Sep 24, 2012 | Lexmark black toner x203n/x204 return...
My old A45-S120 has gone 'blue screen' and something has corrupted ( I assume from some of the messages) a Windows root file. I have the factory recovery disc and am happy to just get back there but I...
Those are HDD problems, I solved that problem using a program called HDD regenerator, you can download it or buy it here, create a flash drive using this software and boot to your flash drive, follow the instructions and wait until the program finishes, this procedure usually solves these problems.
May 03, 2011 | Toshiba Satellite A45-S120 Notebook
No capture driver in ulead DVD movie factory 6
Repair the program by going to Control Panel --> Add Remove Programs --> Ulead MF6 --> Change/Remove --> Repair.
You must have the original instal disk in you optical drive for this to work. This solved the no capture driver error message for me. If this doesn't work I would uninstall and reinstall the whole program.
Sep 09, 2010 | Ulead DVD MovieFactory for PC
HI, I am am having problems with my Philips GoGear Flash audio player SA2625. When ever I turn it ON, all it says is "Philips" then it turns off. When ever I plug it in it says "OK to disconnect", the...
I found a restore fix by pressing the return button while plugging into a PC with philips device manager open - the MP3 player then was restored to factory defaults :-)
Jun 16, 2010 | Philips GoGear SA2625/37 MP3 Player
What cases the transmission to stay in one gear when it is cold
2 things. low fluid level and sometimes factory programming.
fluid expands as it heats raising the level and increasing line pressure.
sometimes factory program things like overdrive lockout until trans temp reaches a certain level. defin check your fluid level though that should be done once a month at least
Nov 19, 2009 | 1996 Ford Windstar
DigitalPersona Personel Fingerprint reader not detected, HP Pavillion dv6706tx Vista 32, DigitalPersona Vers. 4.11.3805. All drivers up to date. In device manager cannot find Personal too. Any idea how to...
To install DP4.11 first uninstall all previous versions on your system and turn off authentec and biometric services in Windows Services so you can then delete the digital persona folder in Program Files (assuming dpagent was running) and uninstall fingerprint driver, then delete Fingerprint sensor folder in Program Files reboot and system will find and install fingerprint driver then double-click to execute and install DP4.11 setup program. (Note: all previous saved passwords for websites will still be listed in digital persona - you will not lose any passwords from your previous installation)
Oct 24, 2009 | HP Pavilion dv6000z Notebook
Hi I have error message file:///C:/Program%20Files/Dell%20Support%20Center/sscommon/common/snapins/shell/ss_shell.htm?config=..%255c..%255c..%255c..%255cgs_agent% how to solve the problem
You can remove the Dell support from your add/remove programs. This support is installed on all Dell systems in factory. Once your warranty runs out, it is pretty worthless because you still have to pay for support.
Go to start, control panel and click on add/remove programs.
Look for Dell Support or help and uninstall it. Reboot computer and the error message will go away!
Oct 21, 2009 | Dell Inspiron 530 Desktop Computer
Casio - tk 7000 FE rr 26
Hai, Major board problem. Usually requires a dealer to send the board in to the factory for repair. If you didn't have your program backed up you will have lost it.Can be costly.
Aug 07, 2009 | Casio TK 6000L Cash Register
ArcMedia JavaScript Source Code 3000 Pro (gar448) for PC Logo
106 people viewed this question
Top ArcMedia Computers & Internet Experts
Computer Links
Alun Cox
Robin Hill
Robin Hill
Are you an ArcMedia Computer and Internet Expert? Answer questions, earn points and help others
