The freezer frosts starting from the inside top rear. I though the kids were leaving the drawer open by my brother's freezer does the same thing. (Same model)
There's warm moist air entering the unit from the back somewhere. Pull the unit away from the wall and check behind there. Look closely at where the Ice Maker fill tube enters through the back. If you find the air leak, use "perma-gum" (google it) to seal it.... not silicone.
Everything seems to be working OK except mosture is accumulating and freezing in the refrigerator...
(More)
Everything seems to be working OK except mosture is accumulating and freezing in the refrigerator side on the side next to the freezer. I've checked door seals and they seem to be fine. Temperature settings are set per the manual.
I have a Jenn Air side by side fridge. Recently, I had to replace the ice maker....
(More)
I have a Jenn Air side by side fridge. Recently, I had to replace the ice maker. Installed it a week ago, and everything seemed fine. Today, it has started discharging water out the water dispenser when the ice maker is going through it's fill cycle. I get some water in the ice tray, and also water spraying out the water dispenser onto the floor. HELP!
Very similar situation where the water dispenser located on inside left side of frig, drips somewhat slowly (around one-two drops every five seconds), but essentially pours out when the ice-maker fills with water.
