I also disconnected the o2 sensors and it did nothing. The check engine light was on until we replaced the distributer cap and rotor.
SOURCE: s10 pickup after warming up truck starts missing
You might have computer problems.
Does the check engine light come on when it starts to miss?
SOURCE: 91 honda civic dx 1.5L quit running properly.
bro, check ur main relay. its under the dash. replace it, check also ur distributor(replace it). and also your ECU
Testimonial: "right answer but I received it much too late. I went to a mechanic and paid him to fix it."
SOURCE: finding truoble codes for 1994 suzuki sidekick
if you live in the states... just go to an autozone... they will scan the codes for free. you may also be able to retrieve the codes by turning the key off and on 3 times and counting the amount of times the check engine light flashes. almost like morse code... when you reach code 55 that's the end of the codes. this does not always work.
SOURCE: i have a 91 honda accord lx starts fine runs good
It may be the O2 sensor. I know it's not the fuel filter, spark plugs, spark plug wires, Vehicle Speed Sensor, Dis. cap, or TCM.
SOURCE: loss of fuel pressure on 1988 ford ranger
Some of these trucks had 2 fuel pumps. One in tank other in frame rail. Possible bad/weak pump.
