Question about Garden
Ariens snowblower THe auger turns when you engage it then the engine starts to die and you have to release the handle for the auger to keep it running. It ran fine the first bad snow this year and towards the end of cleaning it started to sputter and tht is when it all started. The choke is on high.
  • 1 more comment
  • ldpayne89 Jan 29, 2009
  • ldpayne89 Feb 01, 2009
    If the choke is off it would die
  • JERRY ABELL
    JERRY ABELL May 11, 2010
    cannot pull up request please redo thank you
  • 70 Answers
SOURCE: Ariens 926LE snowblower won't engage
First thing I would check is to make sure the traction drive belt didn't fall off or break. To do this remove the plastic shroud between the engine and the snow chute. The traction belt is the one closest to the engine.If it isn't broke Make sure it is on the upper and lower pulleys.
Posted on Dec 22, 2008
HW_Dude
  • 87 Answers
SOURCE: snow blower starts right up but dies once i engage the blades?
it is possible the engine is starving for fuel, so essentially it is a carburetor problem with fuel mixture.
Check and see if your carburetor has mixture adjustment needles, there may be an adjustment possible to fix this problem.
Also, sometimes a tiny vent hole in the carb caseing gets clogged causing the engine to run rough or stall.
Does your engine seem to run better if you close the Choke ?
Hope this helps you.
Posted on Jan 11, 2009
SOURCE: Craftsman 247 88190 0 snow blower auger frozen
my auger and impeller froze too. fixed by clearing all snow, ice,stone build up behind impeller it works fine now.. hope that helps
Posted on Jan 19, 2009
  • 49 Answers
SOURCE: honda snowblower engine hunting
Sounds like you are hitting the governor. Watch the arms at the carb when you move it to full throttle. The arm should hit a screw. Turn this screw clockwise, until the reving stops.
Posted on Feb 03, 2009
  • 398 Answers
SOURCE: Honda snowblower problem
yes you can adjust the throttle cable, did you leave gas in it over the season, if you did this is definitley the problem, dump out the gas and pour new.
Posted on Feb 26, 2009
I have a ariens 3 yrs old snowblower.the auger doesn't engage, the shear pins are good,belts seem to be fine
Does the drive pulley on the engine work. I feel there has to be a broken shear pin some place. Start the engine and shine a good flash light on all the working parts with some one holding it in gear at an idle. You should be able to see if something is slipping.
Just be safety minded.
Dec 16, 2017 | Ariens Garden
Both augers turn when not trying to clean snow,as soon as I try to use it and snow gets to the augers,only one auger moves on my ariens 520 snowblower
It sounds like the auger always turning is the auger engagement handle/line/connections are not adjusted correctly. They/it is too tight causing the auger to engage before it should. It may be up at the handle where you loosen a jam nut, screw in or out a threaded shaft, and retighten the jam nut. (If you have ever adjusted a bicycle brake it is similar.) (I have a craftsman, made by MTD, and I think I saw MTD also list Ariens.) Or it could be an adjustment somewhere else (but I'm not sure where).
As far as one auger moving and the other not, you may have a shear-pin (shear bolt as the manual calls them) on each side of the auger's shaft (my craftsman has one on each side), and the one on the side that stops turning is sheared off. (It moves without snow present due to the driveshaft inside the outer auger shaft turning, but it won't turn under load (snow).) You may confirm a sheared-pin by turning the machine off and try to turn the auger blade. If it turns somewhat easily, that's a bad shear pin. Remove the old shear pin. If the old one is as long as the new one, that aint the problem. The shear pin in the image is one kind. Mine appear as a straight bolt (no grooves), threaded the entire length. You will have to rotate the auger blade until it aligns with the hole in the shaft. Use a nail that fits and rotate the blade until the nail goes in. Remove the nail and screw in the shear bolt:
The auger clutch control up at the handle looks like this:
25398197-u3i4ko1tk2s0xlbbi4fvvtzj-2-2.png From my manual
Auger Control
  • To check the adjustment of the auger control, push forward the left hand clutch grip until the rubber bumper is compressed. There should be slack in the clutch cable.
  • Release the clutch grip. The cable should be straight. Make certain you can depress the auger control grip against the left handle completely.
  • If adjustment is necessary, loosen the hex jam nut and thread the cable in (for less slack) or out (for more slack). Recheck adjustment. Tighten the jam nut when correct adjustment is reached.
Here's another view of that:
I hope the above info helps you take care of both issues.
Feb 03, 2015 | Ariens Garden
Start my new snowblower auger keeps turning
Belt is a bit too tight. If it's NEW it will probably stretch a bit and be OK
Dec 23, 2014 | Ariens 72023 Snowblower Drive Belt 1/4 X...
932 ariens shuts engine down as clutch is engaged to throw snow
Your problem would be in a safety shutdown switch.
some Ariens blowers have a two handed safety switch whitch is located on back of blower right lower side (inside of body)
You have to remove 4 transmission pan bolts to see it.
The other location is under the metal face plate between the handle bars.
Some of them have a third handel on right side of handle bars that has to be depressed to run auger .
Mar 01, 2014 | Ariens Garden
Fix ariens snowblower 520 dies when engaging the auger lever
Your front end is jammed. Its either frozen or there is a rock or something jamming it up. Before you start engine reach down chute and turn back impeller that throws the snow out of blower. Should turn freely. when its free its fixed. You will probably need a new belt.
Feb 17, 2014 | Garden
Ariens snowblower impeller not throwing snow
Sounds like you have a broken or partially broken shear pin in the auger.Check along the auger[machine off]and see if there is what looks like a bolt anywhere along the auger shaft.If there is [and there will be] remove and inspect it and you will see why the auger is not working.Next time,never clean out a chute or auger while the engine is running,people loose limbs this way.
Feb 13, 2010 | Ariens 34 In. Zoom Series Riding Mower
How do I change ariens snowblower belts
on some blowers you have to remove the front auger sya in order to change the belt. it a pain. look down from the top to see if you have room to slid the belts throw, if not remove the front auger
Oct 12, 2009 | Ariens Garden
Engine Dies When Auger Engaged
Bough Sno-Tek 24 in. Two-Stage Electric Start Gas Snow Blower - under 2 feet of snow and engine dies when Auger is enagaged! Hope someone can help.
Jan 28, 2009 | Garden
Ariens snowblower auger wont turn
Just finished repairing my ariens, 6 years old with aluminum gear box. Same problem encountered. The problem turns out to be the BRONZE gear driven by the worm shaft. Shear bolts did not shear and bronze gear broke about 5-6 teeth. This is why you can move the auger a half turn or so, there are no gears in one area of the gear and as the gear turns to engage the worm drive it will stop. The fix: the cast iron replacement from ariens! About $200 including shipping, got mine from Jack's Small Engine (MD). Fairly easy repair if you are mechanically inclined. Buy yourself a set of roll pin extractors ($20 from Sears), new roll pins, new woodruff key for shaft. You will also probably have to press 2nd stage impeller from shaft with hydraulic press & heat (took mine to my local auto garage). What stinks is ariens seemed to have admitted the design problem with the aluminum gearbox, yet won't help with repair cost! Anyways, I learned a lot about my snowblower for future repair (belt replacement)!
Dec 21, 2008 | Garden
Garden Logo
103 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
