Question about Dell 924 All-in-One InkJet Printer
I have just purchased and inserted two new cartridges in my Dell 924 and it continues to give me the Cartridge error #1203, any ideas?
  • 34 Answers
Error 1203 means ink overflow i think. Here are some solutions you can try:
Solution #1:
use a klennex with a few drops of water to dampen and clean off those contact on the holder. Sometimes ink is smeared on the holder where the contact panel with the catridge.
Solution #2:
place your old cartrages back in and see it if works without giving you an error code. If so, return the new ones back to Dell because they are probably defective and Dell will replace them for you.
Solution #3
turn off printer. Remove AC power cord and USB cable from back of printer for 1 minute. Replug and retry. This actually should be your first step.
Hope this helps!
Posted on Jan 29, 2009
My dell 926 is giving me a 1203 errror. I have cleaned the contacts, unplugged still getting error. help
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Apr 22, 2010 | Dell 924 All-in-One InkJet Printer
Keep getting cartridge error, 1203 but they are fairly new cartridges and cannot be empty.
or
Mar 17, 2010 | Dell 924 All-in-One InkJet Printer
Prenter 926 shows error 1203
A 1203 error usually involves some type of cartridge problem.
Did you recently change a cartridge out? If so, did you use a factory new ink cartridge by Dell?
If you did not, then that could be your problem.
Jul 15, 2009 | Dell 924 All-in-One InkJet Printer
My dell printer 924 is giving me a message 1203
From what I was reading this error is caused by the contacts where your print cartridge connects being dirty or having old ink smeared on them. Pull out your ink cartridges and use a cloth with just a little dab of water to wipe any old ink off of these contacts.
To reset the error code you should be able to disconnect the power cord from the wall. Also remove the power brick from the back of the printer for 60 seconds. Then connect everything again.
Apr 10, 2009 | Dell 924 All-in-One InkJet Printer
Trying to insert new ink catridges
I think it will do the trick for you try this.
or
Mar 31, 2009 | Dell 924 All-in-One InkJet Printer
or
It may work , worth a try
Jan 29, 2009 | Dell 924 All-in-One InkJet Printer
I am getting a message error 1203
Try this first see if it will help.
ERROR 1203 LEXMARK ERROR 1200 Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
or
Aug 02, 2008 | Dell 924 All-in-One InkJet Printer
Error message 1203
This link should have the answer for you.
http://www.dellcommunity.com/supportforums/board/message?board.id=A940&message.id=13761
Jul 27, 2008 | Dell 924 All-in-One InkJet Printer
Dell Printer 924
Please try this
or
Jun 24, 2008 | Dell 924 All-in-One InkJet Printer
HELP!!!
what i did was remove the color cartridge then close up the printer. it then gave a missing cartridge error but you can click through that so you can run with one cartridge. then everything worked fine and so i went back and put the color back in and it was good to go
Apr 26, 2008 | Dell 924 All-in-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
107 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
