Question about Maytag Atlantis MDG7400AW Gas Dryer
Dryer makes a whining noise when drying
The noise is like a high pitch whine.
  • 1 more comment
  • handy-gary Jan 29, 2009
    We have a similar problem.  Runs okay for 2 or 3 minutes, but then starts to squeal.  Could it be the belt stretches a bit after it gets hot?
    Our model is LDE7334ACE.
  • tbailey56 Mar 09, 2009
    My Maytag Atlantis gas dryer has begun squealing. What parts do I need to replace? Will replacing rollers (including bearings) fix the problem? Is there another part I need to consider replacing?
  • handy-gary May 11, 2010
    Thanks!  But why would there be a delay?  It seems like something changes after it get hot.  Would the rollers do that?
    Gary
  • 117 Answers
The belt is not the problem but more likely the drum rollers or drum bearing will need to be replaced.
Posted on Feb 26, 2009
High Pitched Whine
A high pitched whine like that indicates a bad bearing. Water pump, power steering pump, accessory belt slipping, alternator bearing, or in the worst case scenerio, Transmission pump.
Dec 12, 2013 | 2001 GMC Yukon XL
Whining noise on 2002 chevy tracker, comes and goes
Could be your alternator or a bad idler pulley. Is the transmission good? It may be the tranny or your differential whining.
Feb 18, 2013 | 2002 Chevrolet Tracker
03 nissan altima high pitch whine from engine
I assume that you have a 6cyl engine, noise came from both worned secondary timing chain tenssioner shoes, just replace those two and while you have them all apart, also replace main tenssioner and guide, then all noises will go away. Good luck!
Oct 13, 2012 | 2003 Nissan Altima
Dryer making a louder than normal noise when drying
Possibly the roller, I would have to hear it to be sure, but if it sounds like a clunking noise, it is probably a roller, if it is more of a high pitched whine, or a sound like a penny in a vaccum you probably have something stuck in your blower.
Dec 18, 2009 | LG DLE5932S Electric Dryer
High pitched whine/sometimes TV won't turn on
The power supply on this model will whine when it is shorted or overloaded - the set would have to be brought in to determine exact cause.
Oct 23, 2009 | Televison & Video
Constant high pitched whining noise. Increases
you could be low on transmission fluid check that and make sure it registering properly on the dipstick.
Oct 20, 2009 | 2003 Toyota Sienna
Same problem: a high pitch whine after extended driving
Sounds like a dry/failing bearing or power steering pump noise. You first need to try to track down where the noise is originating, and the most likely place is at the front of the engine.
I would start by listening with the hood up while parked with the engine running and the noise present, and seeing if it is coming from there. If so, the most likely cause is something connected to the belt - e.g. AC compressor clutch, tensioner, power steering pump, or generator. Can also be caused by the belt just slipping (warn out belt, tensioner not working properly).
Mar 31, 2017 | 2001 Chevrolet Venture
Weird noises in drive and reverse
The high pitched whine in reverse sounds normal for a honda. Ever honda I have had makes a similar noise while in reverse. The spinning, scraping noise in drive is not normal. You might want to see a mechanic about that.
Apr 30, 2009 | 2002 Honda Civic
Papaer will not feed
High ITConsult And MarkoP
The high pitched whine and the paper stopping just before the fuser (the hot) unit is a known issue on the C3000 and C4100. If you are still searching for the solution to this issue, let me know, as I now have a working fix for the problem.
Reply to this post for further info.
Jul 10, 2008 | Epson AcuLaser C3000 Printer
Maytag Atlantis MDG7400AW Gas Dryer Logo
703 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
