Question about Whirlpool MH3185XP Microwave Oven
Whirlpool microwave MH3185XP: cancel button does not work
The touchpad all works fine and the oven works but the cancel button won't work. It has a small lock next to it that is not explained in the manual. The question is how to activate the cancel key? I have tried several buttons: holding them in 5 seconds but no dice.
Thanks for any insights you can provide.
  • Anonymous Mar 20, 2014
    no buttons on board work.. only cancel button works
  • Whirlpool Master
  • 9,030 Answers
The symbol next to the Cancel pad means it would also be used to turn the Child Lock feature on and off.
But as it is, you have a failed membrane keypad.
Luckily, on these models you can replace the control panel frame with keypad all as one unit without doing any peel & stick.
Just remove your circuit board and drop it in the new frame.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
(There are 12 models which start with MH3185XP, so check the tag on your oven for the full model number.)
See reference number 3 on diagram number 3.
Whirlpool microwave MH3185XP: cancel button does n - 0677fac.jpg
Posted on Jan 29, 2009
Not all buttons work on touchpad
There will be a problem with the touchpad membrane, usually this is usually repaired by replacing the complete touchpad facia or front control panel.
Nov 10, 2013 | Goldstar MV-1515 Microwave Oven
In oven the start button is not working
see the details and fix it. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Nov 15, 2012 | Whirlpool Microwave Ovens
I want whirlpool oven mechanic in kakinada
see the details and proceed according. fix it. God bless you
Changed bulbs now the unit is dead
You likely knocked a wire loose on the door interlock switch. Also check seating of all connectors elsewhere in the unit.
Apr 27, 2010 | Whirlpool MH3185XP Microwave Oven
Ge microwave HVM1540DN1BB button control pad stopped working
I am not familiar with the Whirlpool microwaves; however, I just had the same problem with an LG over the range microwave. Several of the positions on the touchpad quit responding to touch. In our case, it was the touchpad itself that was the problem.
The touchpad on our microwave was held in place with adhesive. We pulled it off and replaced it with a new touchpad. Everything works now. The only complication is getting to the connector which carries the signals from the touchpad to the microwave controls. We had to remove and dissassemble the door to get to that connector.
The touchpad cost about $26.00.
Oct 09, 2009 | Whirlpool MH7140XF Microwave Oven
Have a Whirlpool microwave oven, model MH3185XP. Just stopped wor
In some Whirlpool models, there are more than one fuse, and two or more thermal devices which can interrupt power to the oven.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Please write back with more details if you need further help.
Feb 28, 2009 | Whirlpool MH3185XP Microwave Oven
Whirlpool microwave Model # MH3185XP No power?
I just had a problem with mine and took the panel off and did find a fuse on the inside on the top portion of the unit. Try changing it and see if it works. Hope it helps.....
Dec 29, 2008 | Whirlpool MH1150XMQ Microwave Oven
The touchpad on my microwave has quit working.
possibly a stuck button which would mean a replacement pad, do the buttons bleep when you push them do some work and others dont its quite common normally its the start button or the cancel which goes(due to constant pushing) and it causes the error alternatively its a possible logic board fault which is far more expensive to replace!
Nov 12, 2008 | Microwave Ovens
Whirlpool GH6177XPS touchpad
jm...I'm guessing you are not able to see the numbers in the timer portion but that it will accept keyboard commands. This sounds like the main board is going and the drivers are not working or it might just be that the display is bad...generally these are replaced as a unit.
Dec 19, 2007 | Whirlpool GH6177XPS Microwave Oven
Whirlpool MH3185XP Microwave Oven Logo
189 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
sonic boom...
sonic boom...
Gerry Harvey
Gerry Harvey
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
