Question about Maytag Neptune FAV6800AW Top Load Washer
Groaning noise in Maytag 4000 washer
My Maytag ma4000aww washing machine started making a groaning noise as it works, each time the motor rotates, the whole tub area groans. I took the back plate off of the washer, but cannot localize then noise, it seems to come from everywhere. any suggestions? When the machine completes the spin cycle, it shuts down immediately and there is a very loud grinding whine similar to brakes on an automobile that are worn out. i.e. metal to metal
2 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: groaning noise in Maytag 4000 washer
yea probly passed warr from manu , if its rear bearing issue gonna run alot ot fix BIG JOB!
Posted on Feb 24, 2008
MY whirlpool WASHER MACHINE FILLS WITH WATER BUT DOES NOT WORK AFTER THAT. IT DOES MAKE SMALL NOISE LIKE MOTOR BUT DOES NOT WORK.
Maytag LAT3600A Top Load Washer
1 Points
Nov 27, 2012 | Maytag LAT3600A Top Load Washer
Model mah4000aww
Sounds like the main bearing on the back of the drum assembly has gone and needs replacing, the drum has moved out of alignment or the electric motor has burnt out. Best to have a Maytag repair tech or someone who is qualified to look at it.
Nov 05, 2012 | Maytag Washing Machines
What else besides a belt would cause a dryer not to rotate
Motor, start capacitor, If its making a buzzing noise and the motor wont start most likely its the start capacitor.
Feb 21, 2012 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag Neptune. 10 years old.Slow drum rotation
The problem may be with the bearing of the washing machine is spoiled due to leak please try to change two inner bearing along with the washer it will work for another ten years
Dec 24, 2009 | Washing Machines
I have a neptune washer that makes a buzzing type noise when I hit the start button? from motor area. The belt and pulley into the unit turns freely. I did get it to start and the barrel did rotate then...
The buzzing noise is probably an electrical relay that controls the motor. They have a spring assembly on an arm. When you energize it it creates a magnetic field and pull the arm down into contact and starts the current flow to the motor. If it's buzzing, the relay is probably bad and need replaced.
Oct 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Kemore 110.26912690 will agitate won't spin, makes noise
You need to replace the coupling that goes between the motor and transmission
Jul 14, 2009 | Kenmore 22422 Top Load Washer
My MAH 5500B washer has a squeak when fully loaded at the start of rotation in both directions.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
if still the problem then ,Motor is kicking on and off making that noise....so far for us this has been a motor issue 9.5 times out of 10.
May 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Feb 23, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Maytag washing machine
When the washer fills up, first thing that actuates is the diaphragm switch under the control header. This is directly connected into the timer. The diaphragm switch starts the timer motor listed on the diagram as TM. Check the timer motor. If its working you can see something rotating in a little window on the motor. The motor operates all the internal cam switches.
Apr 16, 2007 | Maytag PAV2300 Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
344 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
