Question about Hitachi 42HDF52 Television
Hitatchi 42HDF52 only receives channel 5 and 6 on analog RF input
My Hitatchi 42HDF52 only will receive channel 5&6 using the analog RF input. This is being connected to cable TV. The same cable that was on the Hitachi was connected to a CRT TV, and all of the cable channels can be viewed. I tried to scan for channels on CATV and AIR. Secondly, I cannot receive any digital channels using the digital RF input. Scanning for channels in DTV mode results in 0 channels. I have tried with the cable from the wall as well as an OTA antenna. I hooked up a VCR to check to see if anything can be seen, and the VCR worked with no problems on channel 2 and 3. So far, I cannot use this TV as I cannot get any signal to work.
  • mwcondon Jan 29, 2009
    The vcr was hooked up via coax and worked no problem. I could believe there is a tuner issue, but the digital and analog tuner are separate on this TV.
  • 3 Answers
If you have tried autoprogramming and have found nothing it may be a bad tuner. Is your VCR is hooked up via coax or into a video input? If it is hooked up via video and is working but the coax connection direct isnt it will be a bad TV tuner. Easiest cheapest fix is to use you VCR to change channels or get a Digital Cable Terminal from you cable provider and hook it into video or compnent.
Posted on Jan 29, 2009
Trying to hook up SH-AC500D to SA-AX720 Receiver. I wanna know the right wires to use. Thank you
Connect the 6-channel analog outputs of the AC500 to the 6-channel analog inputs on the AX720 using 3 RCA cable pairs.
http://archiwumallegro.pl/technics_shac500d_procesor_surround_ddigital_dts-1215399983.html
Digital sources will enter the AC500 and be converted to 5.1 analog output.
Be advised, that input on the receiver will not allow any internal DSP manipulation. WYSIWYG.
Feb 04, 2011 | Technics SA-AX720 Receiver
Telefunken analogue color TV model MP-A2055VT-H to connect up digital decoder set-top box. The TV only has an RF input. no other plugs. Searched all 80 channels and I cannot find an AV channel on the...
The simplest solution would probably be the use of an RF Modulator. Feed the RF Mod with the A/V signals from the Conia CSTB12, set it to transmit on Ch 3 or 4, tune the Telefunken to either channel.
In most Telefunken TVs we have worked on, the A/V INput/OUTput would be on the SCART connectors as shown below.
To my understanding, a Conia CSTB12 as sold in Australia has a composite RCA (yellow) Video OUTput and L/R White/Red audio OUTputs. What would be needed would be a A/V signal to SCART adapter/converter.
If your Conia CSTB12 has an S-Video, then this may be used.
If your Conia CSTB12 has an HDMI, then something like this may be used.
Incidentally, should you be interested, there are comparable receivers to a Conia CSTB12 that has SCART OUTputs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 14, 2008 | Televison & Video
Tip
RF Modulators and cable connections
RF MODULATOR HOOKUP
For a TV with only a RF input jack, a RF Modulator can be used to hookup DVD players, DVD recorders and other devices which output RCA composite video and audio. For example, analog cable TV can be connected using a RG-6 type coaxial cable to a VCR or older DVD recorder's analog cable ready tuner RF input. Then as shown above, the output can be connected to the TV thru the RF modulator. The modulator outputs on channel 3 or 4 for the older TV so the TV is set to channel 3 or 4. Some RF modulators are built-in to Audio/Video switch boxes. These allow multiple RCA inputs along with RF input.
RF MODULATOR CLOSE-UP
The modulator converts signals to channel 3 or 4 so older TVs can tune them on their analog tuners channel 3 or 4.
RF Modulator - buy online
http://sewelldirect.com/belkin-rf-modulator.asp
on Aug 23, 2010 | Audio Players & Recorders
How to hook up to hd tv
Use the highest resolution connection your HD TV will allow. This will usually DR570's HDMI connector. Most all digital video devices have one or more. The DR570 has an HDMI OUT. Connect it to any HDMI IN connector on your TV. You will then need to set the TV's Input selection to the Input Number you connected the DR570 to. See your TV Remote or Manual.
The DR570 has three types of output connection options, in order of quality; HDMI, Component(Red/Blu/Grn RCA jacks), S-Video (circular connector), and composite (Red/Wht/Yel, where Yel is video and Red/Wht are left/right stereo audio). Red/Wht RCA Audio jack connections are required to be made on all Output types excepting HDMI.
Note, to get your Digital channels, you will need to toggle the DR570's DTV/TV button. DTV is Digital TV channels. TV is analog channels, the DR570 found on your Cable or Antenna RF input coax, after you have done the Setup/General/Channels/Scan (extended). Scan only finds analog channels. Extended Scan scans for both Analog and Digital channels found active on your Cable/Antenna RF connection.
Note also, the DR570 is not technically and HD receiver. The term High Defintion (HD) is reserved to mean 1080i or p resolution, the highest available. The DR570 is an Extended Definition (ED) 720i or p receiver. It up-converts its ED to fit an a 16:9 HD TV screen. You will hardly notice the difference on your TV, but it is the difference between watching a DVD Movie on a standard DVD player, like this one, as opposed to a full HD player like a Blue Ray.
Feb 01, 2011 | Toshiba DR570 DVD Recorder
How to connect microphone to Yamaha RX-V365 as a PA system.
Home-theatre receivers don't have microphone inputs. If you want to use the receiver as an amplifier in PA system, you need to use some kind of mic pre-amp or a mixer with mic inputs.
For PA mixer is needed anyway almost every time and all mixers have at least one mic input (with a pre-amp). Mixers have line-level output(s), which you can connect to the analog input of receiver.
Using receiver as an amp in PA has advantage that you have 5 channel amp. When using high sensitive PA speakers (as oposed to less sensitive Hi-fi home speakers), you can get good performance with the power rating of receiver. You could even use 2 separate channels for subwoofers and 2 channels for satelite speakers - but for that you would need a receiver with 5.1 analog inputs and special device called crossover which would divide the output from mixer into low-frequency signal and high-frequency signal which you would then connect to the front and rear analog inputs. But with RX-V365 you can use only 2 channels with analog input
Sep 15, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Cable company switched to digital, now my Ant A port on the vs-50603 does not receive signals. I can somewhat view the analog signals through my PIP only. other tv's in the house came back with signal 5...
When the cable company offers you digital cable, you typically need a cable box to unscramble the digital channels. Therefore you need to connect either a coaxial cable from the cable box's RF output, if it has one, or connect 3 RCA cables from the yellow, white and red jacks on the rear panel of the cable box to the TV. Analog channels only (if available) will go straight thru over the coaxial RF hookup. They are not scrambled. Select the proper input source on the TV for the cable box.
Aug 26, 2010 | Mitsubishi VS-50603 50" Rear Projection...
I have an analog tv (coax cable) and a new dvd (av plugs) player. How do I inexpensively connect them? i saw the solution posted about the rf modulator. I have a digital to analog tv convertor. Is this...
NO. An RF modulator and your digital-to-analog (DAC) TV converter are 2 different devices. The DAC will convert over-the-air (OTA) digital television signals from your antenna to analog NTSC format so your older analog TV can receive OTA broadcasts. The RF modulator converts base-band video (composite cable/RCA connector, or S-Video cable connector) to channel 3 or 4, so you can watch video/audio on your set. To use both the RF mod. and the DAC converter to the same TV, use an A/B switch for F-connector coax, or follow the directions for the RF modulator to make the correct connections.
Jun 12, 2010 | Televison & Video
Want to run my dtv receiver through new digital converter box.
You will not be able to record local station from a DTV converter connected thru a directv receiver unless there is a a/v input on the directv samsung receiver. Also check the user manual for this receiver if recording from an external source such as a DTV converter box is possible. The answer to seperating the DTV converter box from the directv samsung receiver is possible if your tv has multiple inputs. Try connecting the DTV box to the RF input and the directv samsung box to an a/v input then change inputs using the tv remote. you will need an av cable (yellow/ red/white) for the directv box and a rf jumper cable for the DTV box.
May 17, 2009 | Samsung SIR-S4040R DirecTV DTV Receiver /...
How do I set my PT-44LCX65 up to receive broadcast HDTV signals.
You should use the auto-program function in the customer menu. It will prompt you to select which antenna input you wish to program and then ask if you are on cable or receiving signals via "air" or "broadcast" mode. Allow the TV to load all the channels. You may notice that the auto program mode may move along quickly during the addition of analog channels and that during the scanning of the digital channels that it may look like nothing is happening. Patience is a virtue here. Wait until it has completely scanned both analog and digital bands and you will recieve both versions of the station's signal. If, for example, you have a local channel 5, the digital version will be 5-1, and so on.
michtech
Dec 18, 2008 | Panasonic PT-44LCX65 Television
Denon AVR-1804 6.1 Channels Audio Problem
Make sure the input setting is set to 'Auto' while on those channels and not Analog.
Jan 18, 2008 | Denon AVR-1804 Receiver
Televison & Video Logo
339 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
