Question about Sport & Outdoor - Others
Charcoal grill to propane
Can i convert my charcoal grill to a propane grill?
  • hondaguru10 Feb 16, 2009
  • Anonymous Apr 04, 2009
    they wont sell tou the POL brass fitting with the kit. you have to order it from a grill company or take it off another propane grill. the fitting pushes into the aspirator at the end of the hose an has a female end for the male propane line.
  • 8 Answers
Shouldnt be a problem, the sell replacement kits for propane grills at most home improvement stores. Just buy the replacement kit and install it into your grill.
Posted on Feb 16, 2009
Don't know how to use my propane, charcoal and fire box grill
Did it come with any sort of manual? That is probably the best way to start. If you haven't done it yet, hook up the propane tank to the hoses on the grill. I would say that the rack under the grill is for storing the propane tank and bags of charcoal or wood. Of course, the knobs are for turning the gas on and off. In between the left most knob and the one to it's right, there is an ignition switch type button, you press it when you have the gas turned on and with a lighter, you ignite the propane. Do NOT turn the gas all the way up before it is lit though, that is a sure way to burn some hair off or actually do some serious harm to yourself. In the charcoal section, you put maybe three inches of charcoal in the bottom of the cylinder. Use some paper or dry pine straw as extra fuel to get the charcoal started. Put a bit of lighter fluid on the charcoal then drop a match on it. I'm not too familiar with fire boxes, but from what I see, you need to use wood in the bottom of it. I can't see under the fire box, but you probably can dump the ashes out after you're finished with it. Start a fire with the wood and cook your food. If I may add a suggestion about cooking with wood, don't use nasty old rotten wood to do it. Cut some good smelling wood and let it sit for a while before you burn it. It will imbue the food with a good smell and taste. Other than that, it is up to you to learn to use your new grill. Good Luck.
Mar 30, 2013 | Grilling
I have a kenmore ellite bbq model 141.16691 propane - I want to convert to natural gas, there is no conversion kit to make it but the natural gas model 141.17691 is exactly the same - just natural gas. If...
Many manufacturers make grills in propane and natural gas, but are not convertible from one gas type to another. The reason being safety. Each grill model, whether it's Natural Gas or Propane is tested and approved for that one specific gas type and that alone. Converting it would put all the responsibility on you, if something was to go wrong.
I suspect in part, the reason you want to convert is so that you want have to refill the propane tank any longer. But, you may want to consider this against convenience. Propane Gas burns cleaner and hotter than Natural Gas in an outdoor environment. Which boils down to lower high end temperatures, longer preheating times and the expense of running an approved gas line to the grill for Natural Gas. Not to mention the cost conversion parts.
But, the decision is yours to make. Thanks for choosing FixYa.
Aug 06, 2011 | Kenmore Elite 644 sq. in. Cooking Area Gas...
I have a new PinnacleTG560N natural gas BBQ and I want to convert it to propane, what can I do, or can I get a converion kit to make this work.
Unfortunately, there's nothing you can do. According to Weber, there are no conversion kits, as your grill is not convertible to propane. Like wise, a Weber propane grill is not convertible to natural gas.
Link to your Owners Manual (see page 2 - Warnings):
Apr 28, 2011 | Weber Spirit? E-310 Propane Grill
I have a masterbilt propane smoker with no decent instructions. Do I still have to use charcoal?
No, no charcoal is necessary. If you used charcoal, you'd go from low and slow smoking, to high and fast grilling. That's not something you want or can do with a propane smoker. For more information and recipes go to
Mar 20, 2011 | Masterbuilt 20050106 Propane Smoker
Does this require charcoal? Can you use charcoal if not required
Normally,it's not recommended, as it can get to hot and burn out the bottom of the pan. Use chunks of wood designed for smoking instead. They'll burn longer and temp is easier to control.
Feb 20, 2011 | Masterbuilt 20050106 Propane Smoker
There was no users manual with the smoker. do i use charcoal or lava rocks and where do i put them
I have used a number of propane smokers and your propane burner will be located at the bottom of the smoker cabinet and you should have a wood / charcoal box above that in which you can place your charcoal or wood.
I have attached a picture that shows the wood / charcoal box. It's not the same smoker but it will give you an idea.
Hope this helps.
Nov 25, 2010 | Masterbuilt 20050106 Propane Smoker
Turbo STS grill, converting to propane from natual gas, orafices arn't available from Turbo
I would like to convert my Turbo STS grill from propane to natural gas. Where can I find the correct sized orifices?
Jun 17, 2010 | Barbeques Galore Turbo STS 4-Burner with...
I want to convert a Grill Master naturaal gas
The orifices have to be changed.Should be able to get right ones from manufacturer.
May 22, 2010 | Grilling
We received a natural gas connection bbq and don't have access to it possible to convert to propane tank connector.
no all components of grill need to be converted to propane. cheaper to buy new grill. Call Manufacture and see if they sell conversion kit. Most companies don't do to liability matters,
Mar 28, 2010 | BBQ Guys BBQ400C/G42 Grill
Sport & Outdoor - Others Logo
876 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
