Question about Philips PA1035 Mouse
Keyboard and mouse won't connect
Just plugged in a hewlett packard pc - the hard drive light is on, monitor on displaying a symantec message to (update info etc. click OK) so the problem....keyboard and mouse aren't functioning. They aren't connecting to the screen. Lights blink on when I push the connection to the usb port. Not able to click on the screen. Tried clt alt del....tried maneuvering the mouse, cleaned the ball, somehow it seems to be locked?
  • 34 Answers
Usually the best and easiest solution to this is to just wait. I've been given this problem MANY times from friends the 99 out of 100 times when i tell them to just wait, after about a minute or 2 it works. See the thing is since this is a usb device sometimes when it is connected to the pc it has to install the drivers. Alot of times at start-up you won't be given a msg that it is doing this. As for the lights when you plug in the mouse, that's a good thing means it's powered up. No lights, no power, no good. So my suggestion to you would be to boot up and wait. Give it atleast 5 mins to be safe.
Feel free to get back to me for other measures if this doesn't work.
Hope this helps!!
Posted on Jan 29, 2009
  • 59 Answers
You might need to re-install your old unit and go to the manufactures website and download the drivers. Sometimes the hardware you install requires you to download the driver. I purchased a new mouse and had to go to the manufactures website to install the actual driver to get it to work properly.
How do i fix my scrollomg problems!
Wireless Keyboard-Mouse (890552559985) is not listed anywhere as an actual model number so it's hard to say what it even looks like.
Is it a "scroll wheel" in the middle of the mouse? Are you sure it's not the properties or configuration of the mouse in Windows Control Panel?
If you can take a mouse apart, rubbing alcohol on a Q-tip rubbed on sensors as well as a wheel could help.
Feb 08, 2015 | HEWLETT-PACKARD Hewlett Packard Compaq...
Monitor won't change from power save mode and keyboard won't light up. Checked connections and it's connected. Was working 2 days before.
If both symptoms started at the same time, I would suspect your motherboard has gone bad. Have you tried the monitor and keyboard on a different computer?
Jul 07, 2014 | HEWLETT-PACKARD Computers & Internet
Hp p6530z desktop will not boot
It could be the monitor. Try a different monitor. Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 02, 2014 | HEWLETT-PACKARD Hewlett Packard Pavilion...
Scroll and caps lock light up but laptop will not open
Could be a number of things.
Could be the Hard Drive ( 320 Gb )
Could be stuck key or water damage on Keyboard/ mouse pad.
If you have the savvy to explore, remove the battery, Hard Drive and Memory.
Blow out the cooling fan area and re-install all that you removed.
Sometimes, just reseating things like memory , CPU and Hard Drive
can make the difference.
Hope this helps
Apr 14, 2014 | HEWLETT-PACKARD HP G56-122US Notebook
Monitor, mouse and keyboard suddenly stopped working.
There could be several issues. 1) if they are wireless the connection may need to be reestablished. Also, check the power source for all of the items, possibly the electrical cord came out of the receptical.
Dec 10, 2013 | HEWLETT-PACKARD Hewlett Packard Pavilion...
Monitor mouse and keyboard suddenly stopped working
Hi, Dixie, What have you tried to do so far?
IF you've move the machine to a different spot, and have disconnected the cables, maybe you have the cables in the wrong spot?
IF you have power to the computer, and the fans on the "box" works then try a different monitor, IF that part works then try a different keyboard and mouse.
Hope this helps.
Hp G56-129wm won't boot. Powers up but doesn't show any screens, and then dies!
2 Suggestions:-
1) Did you tried to connect External Monitor? Tell me the status
2) Remove all Power Adapters and battery. Push the Power Button for 15seconds. Again Connected the battery and Power Adapter. Check if its working or not. If not then Must be Motherboard Problem.
Jul 24, 2012 | HEWLETT-PACKARD G56-129WM Laptop PC
Windows Boot Manager message: Windows encountered a problem communicating w/a device connected to your computer. Error may be caused by unplugging a removable storage device such as an external USB Drive...
Make sure there is nothing attached to the laptop,remove all devices like keyboard,mouse, flash drives and retry. If still having same error flip the laptop over and remove the battery and open up the 2 other compartments that have a screw holding them. One holds the memory modules and the other the hard drive, check and re seat all connections, then try again. If you still have the same error your hard drive is most likely failing,
Thanks for using FixYa
Jul 23, 2011 | HEWLETT-PACKARD Compaq Presario CQ60-615DX...
Philips PA1035 Mouse Logo
650 people viewed this question
Top Philips Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
