TV turns off for no obvious reason
The TV seems to go for approximately 15-20 mins and just switches itself off.
The picture and sound is good. I thought that maybe it was frequency interference from an outside source.
    Sergeant:
    Champion:
  • 373 Answers
Did you check the time limit on the tv menu screen
Posted on Jan 29, 2009
Panasonic pt52lcx15 TV. Recently, after approximately 5 min. The TV turns off. Is this some sort of power supply issue? Or, something else?
Try this.
Unplug the tv. take off the back panel. vacuum or blow out the dust with a can of compressed air (@ $3 at Staples). A lot of the projection tvs had a thermal sensor which would turn the tv off if it got to hot.
That is also a good time to clean the lenses. Be careful not to move them out of alignment. My tv worked like new after I did those things.
Jun 10, 2015 | Panasonic Televison & Video
My Sylvania flat screen sound keeps going off
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/ The most probable cause is with its audio output IC itself; overheats.
May 11, 2017 | Sylvania Televison & Video
Vertical color bands take the place of the picture.
I sent my question to the "solve your problem for free" on this website, so I was expecting some "free" advice. My finances are such that I can only ask for free advice. I did see someone who had a similar-sounding problem, and there was a mention of two possible main boards that would fix the problem. I was hoping to know which board would most likely fix my problem, since the TV is less than two years old. If I take it to a TV repair person, I want to have a fairly good idea how to fix it, and what would be the approximate cost, so I do not get ripped off.
Jan 07, 2009 | Westinghouse LTV-27W2 27 in. HD-Ready LCD...
KV-27TH70 SONY TV Shuts Down for no Reason
hi there, normally bad/broken connections in the horizontal or on the flyback. hjope this helps.
Aug 04, 2008 | Televison & Video
Samsung tv turning off by itself
I had a similar problem where my 61" Samsung DLP was turning itself off very frequently I had resolved to try replacing the bulb. I called a local TV repair place to see if they had my buld in stock. The guy I spoke to actually told me how to fix my problem! There is a little blue switch behind the bulb access door. The inside of the door has a little piece that presses the switch down. The switch is supposed to work correctly weather the switch is in the up or down position but samsung forgot to take expansion from heat into account. If the switch is held in the upper position by the door and the plastic expands to a certain point, it triggers the set to shut off. This does not occur of the switch is held in the lower position. What you need to do is take the access door off and put it back on by sliding it into position from above. That will hold the switch in the down position, eliminating the problem. My set has not **** itself off ever since.
Jun 16, 2008 | Samsung LTP326WX/XAA 32 in. HD-Ready LCD...
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Sony Bravia KDL 52 keeps turning itself OFF
i had prob where my sony would switch off for a few secs thenh come back on . The solution was in menu / tv settings / sleep timer . Go into that and make sure its set to off. there are opions for off , 5 min 20 min 30 min etc... mine was set to nothing just blank.
Apr 06, 2008 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Tv powers on and off
Sound
Sounds like your bulb is nearing the end of its life span you will be needing a new bulb soon.
Jan 14, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
