Question about Nokia 6133 Cellular Phone
Phone can't pair with bluetooth but is bluetooth compatible.
How do u know if your bluetrek X2 is connected or can connect to ur phone.
Well whats the problem you cant connect your bluetooth to your phone or is it not comming up on your phone? did you pair it correctly?
Posted on Jan 29, 2009
How do I pair speaker with phone
turn both phone bluetooth and speaker bluetooth off. then turn them back on. the speaker's light should be flashing indicating its searching for a device to pair with. as its flashing make sure your phones bluetooth is visible and searching. they will pair and your phone will tell you and the speakers light should quit flashiing and just remain on.
Oct 20, 2014 | Audio Players & Recorders
Have lost the manual to bluetrek and have an iphone 3 now and need to get the bluetooth working with this new phone
First, here is the link to the manual:
http://www.bluetrek.com/getfile.php?source=/download/product_download-manual63.pdf&filename=CompactClassic+Manual%2C+English&file_extension=pdf
Here are the instruction: 1. Switch on your Bluetrek and press and hold Talk button and Vol+ button for about five seconds untill indicator light flashes red and blue alternatively and you will hear a sound from speaker.
2. Open bluetooth in Iphone 3 search for bluetooth device. You will see Bluetrek Compact Classic. Click on name to pair and enter "0000" as pin code.
Bluetrek will be connected to iPhone.
Jun 02, 2011 | BlueTrek Compact Classic Ultra Slim...
I have a bluetooth headset mounted in my motorcycle helmet and I can make a bluetooth connection between it and my nokia 6727 but now I got another Nokia 3727 and when I try to pair it with my helmet - I...
It is very posible that it is not connecting, reason being: compatibility. U should get a bluetooth headset that is compatible to both ur phones n pair it, that should solve ur problem. For example I can use any of BH320, BH200, BH600 on my Nokia 6120c n other bluetooth headsets I tried wont b accepted. U can try them n c. Good luck.
May 05, 2011 | Nokia 6120 classic Cellular Phone
I don't have the manual anymore and I forget how to pair the blue trek car kit with my phone. Please help!
Try this:
1. Put them close together
2. Switch on phone and select bluetooth discover mode (make sure it's visible to other devices)
3. Switch your BlueTrek device. Press and hold both Talk and Vol+ button for about 5 seconds until the indicator light flashes red and blue alternatively and sound can be heard from the speaker.
4. The phone should then detect the Bluetrek device. Follow the instructions from the phone to accept the pairing request. If you didn't change it, the PIN code should be 0000 (zeroes).
Hope this helps.
May 04, 2011 | BlueTrek Surface sound Duo Bluetooth Car...
How do i pair my bluetrek kr1 car kit (lost instructions
Just paired mine, think I pressed all 3 buttons at same time and 1234 was passkey
Feb 22, 2011 | BlueTrek KR1 Wireless Bluetooth Car Kit...
I have anew phone and want to connect my Bluetrek X2 to it and the phone is asking for a password to connect the Bluetrek. Can you assist with the password.
Your headset's pairing code is '0000' (four zeros). By the way, if you happen to miss its user guide, feel free to download it from this location.
Hope you are able to sort your problems out soon.
Regards, Carlos
Jun 20, 2010 | BlueTrek G2 Consumer Headset
Havn't used bluetrek S2 in a while. How do I link it to my phone-can't find manual.
go to the menu on your phone select manage connections turn on bluetooth then you'll see search listen, etc. position on search don't press yet
get your ear piece ready: press the on button and hold it until you see a solid blue light (not blinking but solid) if it blinks try again until you get a solid blue light (it takes about 5-8 seconds) when that happens go to your phone and press search it will look for devices (it may find several) look for your earpiece model and select it
it will ask for a code or passkey, type 0000. Then it's going to ask if you want to bond or pair click yes and it will connect
check on the connection manager again and your bluetooth should be on and connected.
if it works for you, don't forget to rate me
thx
Jun 07, 2010 | Motorola Mobility Bluetooth Hands Free...
Need code for g2 earpeice
Pairing the BLUETREK® G2
Before using the BLUETREK® G2 headset, you must pair it with your Bluetooth® mobile
phone. Pairing is the process of linking 2 Bluetooth® devices, so that they can
communicate.
To initiate pairing:
1. Place the BLUETREK® G2 and your mobile phone within 0.3 meter (1 foot) from
each other.
2. Switch on your phone and select its Bluetooth® discover mode (refer to the
Bluetooth® mobile phone user manual).
3. When the BLUETREK® G2 is switched off, press and hold the TALK button for
about 7 seconds until the indicator light flashes red and blue alternatively. And a
sound can be heard in the speaker.
4. Once the mobile phone detects the headset, a “BlueTrek G2” message will be
displayed. Follow the phone instructions to accept the pairing. The PIN code (or
passkey) is 0000, then press “yes” or “ok”.
If pairing success, the indicator light will switch to blue and flashes slowly.
If you haven’t started the discovery mode within 5 minutes, the headset
RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 19, 2009 | BlueTrek G2 Consumer Headset
Nokia 6680 wont connect to Bluetrek G2
Just had the same problem.
But I found some bluetrek instructions on the net & it works
communicate.
each other.
Jun 26, 2007 | BlueTrek G2 Consumer Headset
Nokia 6133 Cellular Phone Logo
109 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
