Question about Ducane 30400042 (LP)
I have a ng fireplace and want to convert to lp gas
On the back of unit it clearly says not to convert to lp.  Why?
I have same grill in lp and i want ng!
Posted on Apr 28, 2009
Orifice installation
Yes, you do need to change the orifice when converting from LP to NatGas. The orifice hole for NatGas is much larger than that of LP.
Sep 06, 2014 | Home
Parts gl38lkec
call me. converting a barbecue is simple; the kind of job a tech will get while still in training. The LP hole is smaller than the NG becuse of mass and air-mixture in NG so the orifices have to be plugged and re-drilled or replaced with new LP orifices.
Nov 07, 2013 | Sunbeam Grill Series 550
Need blower for model #crhfd400rt-m-m gas fireplace
PDF]BLOWER ACCESSORY - Home Depot
www.homedepot.com/.../0e104dad-8f0d-4383-aa50-11...
The Home Depotinstructions may result in a possible electric shock, fire hazard and will void ... Thisblower contains assembly instructions for the following models and item ....CRHFD400RT-M-M (Item # 0328248), BD23 series, Q stove, PCSD25RT .... andrequire no further lubrication. ... Type of gas used (Propane/LP or Natural gas/NG).
Lowe's STYLE SELECTIONS Blower Fan for Gas Fireplace ...
answers.lowes.com/answers/0534/product/3162223/questions.htm?...
... real customers have contributed for the Blower Fan for Gas Fireplace Inserts. ... Cedar Ridge 32,000 BTU Vent-Free fireplace (Model# CRHFD400RT-M-M)?
Cedar Ridge Hearth Crhqd250t - Sepeda Ontel Klasik Vector
efratoium.xyz/cedar-ridge-hearth-crhqd250t/
Feb 26, 2013 | Heating & Cooling
Is there a conversion kit for Jenn-Air Model No: 720-0061-LP to convert from LP to Natural Gas?
Matt, I am not aware of one. Nor, whether it's approved or not, by the manufacturer, Nexgril.
My best advice is to contact their Customer Support Dept @ 800-913-8999
Keep in mind, it you are able to convert it, the gill will no longer get as hot as it does with propane.
Propane burns hotter than Natural Gas in an outdoor environment.
I hope this helps you and Happy Grilling!! Thanks for choosing FixYa.
Jul 28, 2011 | Grilling
I got a GE gas range (model JGBS22) from a co-worker. She had converted it from gas to propane. I just had a plumber hook it up to natural gas but, even with the conversion manual, he couldn't change the...
There should be a set of orifices for each burner as well as the oven and broiler. When the unit was converted to propane, these orifices should have been replaced and the ones for gas put in with the conversion kit installation information. The kit should have been reattached near the pressure regulator.
If the kit was missing the orifices, then, yes, you are missing pieces. Check with your coworker if the conversion kit was missing. If you have the kit, it can be easily done by any appliance installer (or repair person) licensed for handling NG. (At least on our range, the conversion kit installation was straight forward. Every orifice was clearly labeled with the labels different for each burner and for the gas/LP kits (ABCD (NG) vs MNOP (LP)) .) The regulator is the only part that switched for LP or NG without the kit.
As I recall, the only tools we needed for the top burners were a small wrench (10 mm) and a small flat blade screwdriver. Remove one orifice and put in the appropriate replacement. Then adjust the burners so that they didn't blow out when the oven was opened or quickly turned from high to low (for the simmer burner). The oven and broiler took a bit longer. Several screws had to be removed to get at the orifices. Then the air flow had to be adjusted for the incoming gas.
I hope this helps.
(the conversion installation manual was on the counter during installation; I read it while it was open.)
Jan 14, 2011 | GE JGBS22 Gas Kitchen Range
I need to convert this water heater to natural gas. Is there a kit available to do this?
No kits are available to convert his unit to NG. This is because the LP uses copper pipe and is within code, the NG uses black pipe and each unit is specifically designed, entirely, to use the gas associated with the unit.
Feb 05, 2010 | Bosch AquaStar Propane Tankless Water...
Converting cooktop regulator from NG to LP
LP is higher in pressure than NG, so regulator spring pressure has to be greater.
Aug 06, 2009 | GE Cooktops
Uniflame gbc820w propane to natural gas adapter question
Most major hardware stores that sell grills have a universal conversion quick connect hose and gas line adapter fitting.  That.. you can probably handle.   Next you need to install a quick connect adapter from the house gas line or meter (unless one is already there for you).  Otherwise you may want to call your local gas company or fireplace/grill store to send someone out.    Last all LP to NG conversions require the orifices on the back of your grill's valves to be changed to larger holes.  (LP has more pressure thus small holes and NG must be larger.)  The trick is getting the precise numbered drill bit diameter(45-55) for your particular grill.  You can look on your manufacturers web site to provide this info.  Often times they can sell you a new set of orifices, predrilled, to the exact diameter for conversion.  Drilling out orifices is usually cheaper and pretty easy if you know where to find the bits (internet or specialty tool store).   Sometimes your local gas company or fireplace/grill shop will provide this service as well. Hope this helps, and good luck.
Mar 28, 2009 | Grilling
Vermont Casting Radiance Gas Stove (RUVSOD) NG to Propane (LP)
Unfortunaletly, due to the delicate nature of vent-free appliances, you'll find that most are not field convertable. If the vent free appliance were to lose its efficiency, you would be subjected to high levels of CO, carbon monoxide, and could likely die. Therefore, field conversion is not recommended and in this case, not possible. Vermont Castings does not provide parts to convert and if they did you would be essentially replacing the entire unit short of the outer cast shell. I wish you luck.
Dec 22, 2008 | Heating & Cooling
Ducane 30400042 (LP) Logo
98 people viewed this question
Top Ducane Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Are you a Ducane Grilling Expert? Answer questions, earn points and help others
