Question about Bosch WFMC 3200 Front Load Washer
Bosch 500 series Front Load Washer Door hanging a bit lower than when purchased
Bosch 500 series Front Load Washer Door Issue? Washing machine I have a 500 series front loader washing machine. It is about 6 months old. A very heavy machine. I notice the door is heavy as well. It appears that over time this door has sagged a little. Therefore when closing the door, it does not close as easily as before. I suspect this will get worse and may be due to the hinge being weak, where the hinge attaches or the door simply being heavy for the components involved. I am the only user of this machine and have NVR leaned on the door or put any weight on it. Anyone else notice that if they push the door closed it hangs a little lower than it should and doe snot close as easily as when you bought it? This is under warranty and I have an extended warranty as well, so I am not real concerned but would be if this is a re-occurring issue. Thank you Peter
  • 183 Answers
Even if you do not realise it most people lean on the door as they open it, to rectify with the door open but almost in the closed position lift the door by pulling up on the door catch end, this will straiten the hinge, very common problem Regards Engineer
Posted on Jul 30, 2007
Bosch 500 series wfmc3301 bosch washer does not stop running the water during a cycle . even will do it with the spin and drain cycle. Even attempting to turn the washer off it will still run and then once...
You have a bad water supply valve which is struck in the on position-this valve is mounted inside the machine right where you attach the supply hoses-cheers Denny
Oct 24, 2013 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Front load washer Bosch Vision 300/500/DLX will not drain getting a code of E27 can you help. Can't find the code # in the booklet that came with it.
A code E27 means a problem with the door lock. Try unpluging the machine for an hour and see if it resets the lock.
If not remove the cover on the lower right corner you will see a white plastic pull cord. Pull the cord and pull open the door. If that doesn't reset the door lock you will need to replace the lock.
Nov 22, 2012 | Bosch WFK 2401
Door will not open bosch nexxt 500 series
Hello, Welcome to FixYa.
Hopefully the info below will supply you with the assistance to get the door open for now at least...and a little more with some luck.
The door typically locks as a result of the unit failing to drain, so....
**Unplug the washer from the wall or turn off the breaker before attempting any repairs**
  1. Locate the round door on the front of the machine (about 6" in diameter, lower right corner) macmarkus_26.jpg
  2. Find a drill bit or small screwdriver that fits in the hole in the round door.
3. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges are very sharp so be careful).
4. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand or with the aid of pliers.
**NOTE - you should also see a ring attached, if you pull this the door should unlatch, but getting the water out first if present is usually a good plan
Once the door is open and you've removed the items you wanted. Unplug the washer for 20minutes or so and then plug it in again, to see if the control "resets".
Let me know if you require further assistance and if not and this solves your problem, please rate the solution I provided accordingly.
Thank you for coming to "FixYa" and good luck.
Regards,
Macmarkus :)
Apr 15, 2011 | Bosch Nexxt 500 WFMC3301 Front Load Washer
We have a Bosch Nexxt 100 Series Washer. The door lock is stuck and will not unlock. We have a load of clothes in the washer but are unable to get the door to unlock. I have tried unplugging the unit,...
Getting the door open is the easy part. Finding out why it won't open might take a little doing -- though replacing the door latch is also easy. To get the door open, Take an awl or something pointy and place it in the hole on the small round cover in the lower left front of the machine. Now use this to turn the cover, unscrewing it from the machine. Once the cover is off, you should see a plastic rod hanging down. Pull this rod and it will unlock the door. You can now remove your wet clothes from the machine and investigate the cause of the problem.
Jan 31, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
I am replacing the lock, what does the plastic rod hanging down from it do and does it need to be attached to anything
It attaches to a pull strap. The pull strap is in case the switch fails it can be pulled to get the door open. Most bosch pull straps are located behind the drain filter cover (lower right).
Oct 16, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Washer leaks when it isn't packed full of clothes.
check your door seal if leaking in the front if the back its probably one of the water lines leaking
Feb 24, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
BOSCH washer, the door won't unlock and is reading E:04
I used a thin screw to release the lock through the access hole and this released it after rotating the round panel a bit. The manual release on my Bosch is a nylon deal that hangs down from the top. Just pull down lightly and open door. You may have to reach up past the drain to get a hold of the nylon string. The access opening is fairly sharp.
Dec 05, 2008 | Bosch Nexxt 100 Series WFMC1001UC Front...
500 WFMC3301 Bosch Front Loader
The door for this model of washing machine cannot be changed to open from the left.
Jul 07, 2008 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch WFMC 3200 Front Load Washer Logo
432 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
