Question about Procom Heating & Cooling
Getting fumes in home while heater is running
Model HL 400TYLA-0
Model is 3 years old, this problem just happened lately. I cleaned the burners, the logs, checked and cleaned the injectors, the flame is as it is supposed to be, but there are fumes filling the home. I am wondering if the problem is the pressure regulator.
Thanks for your assistance in this matter.
  • 137 Answers
The pressure regulator can very well be the problem if you had the device three years with out a problem.
Is the devise vented? if so then maybe there is not enought draft to completely combust the fuel, if it is NOT vented then it very well could be the regulator sending more fuel to the devise that it is able to combust properly.
Posted on Jan 29, 2009
Starts fine runs just about two min then kicks off and excesive fumes
Would say burners and pilot all need cleaning , blocked jets .
Nov 12, 2012 | Dyna-Glo (PPH16-LP) Utility Heater
I have a PROCOM model ML300TBA, two years old. Here is my problem: Pilot lights fine. Burner lights fine. When I go back the next morning, often times it is out. Burner and pilot are out. It will...
You could try cleaning up the thermocouple with steel wool. Some manufacturers call this a flame generator as well. Any how make sure it is clean and positioned in the top center of the pilot light for best signal. This is only speculation as these are common problems that will arise on heaters in general. This also turns the gas to the burners and pilot light so thats why to start here first. Hope this helps you out.
Dec 23, 2010 | Procom ML300TBA Heater
Have an electric Reddy Heater 55000 about 4 years old that we have been burning diesel fuel in. Laterly we have been having touble with it starting, takes many attempts, Also the fumes are so bad we can't...
It sounds like you are not getting complete combustion and need to adjust the air flow to the burner so it will have more air/oxygen to burn. You may try cleaning the fan and burner also.
Sep 26, 2010 | Reddy Heater-30-55,000 BTU Variable
Furnace filter gets black within 1 day. Electric furnace is 5 years old
I would take apart the burner and have it cleaned out thouroghly for its full of carbon
Jan 14, 2010 | RTO Home Heating Products 5.5HH240...
2 yrs old, getting a 4 flash alarm , "Open High Circuit" any help?
check for a reset able round limit switch in the burner area if fires up make sure filters are clean and no signs of flame roll-out in the burner area when fan comes on this furnace should still have mfg parts warranty left
May 16, 2009 | Goodman GDS80904BNA Open Flame Heater
Laser 56 EE6
EE 6 happens for several reasons. Most likely in your case when the stove runs for a while after you turn it back on, the code is due to and over heat. The circulating fan and cover need to be spotless. If they are then the code is due to low fuel, no fuel or dirty filte on tankor stove.
Tom Hawkins
Bethel, Alaska
hawkins111@gci.net
Jan 09, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Home Heater / thermostat isn't working
It is possible that it may happen again. I reccomend having the burners and burner compartment cleaned, including the Heat exchanger.
If you dont, mind, please rate this solution. All the others were clarificatin requests so we could be sure we found the problem. Now that we found it, It would be great if you could rate the service.
Dec 30, 2008 | Heating & Cooling
Cozy 351A 35000 btu
You might have a slight odor of gas when the burner first ignites. Some gas does escape before it completely ignites. It shouldn't smell after 2 years of use. If you can see the pilot flame burning from the top of the heater, the heater pilot assembly is pushed over too far. The pilot fumes could be escaping in the room and cause a smell.
Dec 27, 2008 | Cozy Enclosed Front Console Heater 70,000...
Delonghi "the incredible heat machine" started smoking
Hi Coyote,
I don't know about your specific heater, but, as someone who has a vast electronics background, things that heat tend to give off some fumes. Many electronic componets are LIGHTLY coated with an oil product to provide humidity protection, while the product may sit in a warehouse for years. Typically, such protection, upon being heated, will disperse in the first (maybe) hour of use. but, it could be more, I guess.
BUT, fumes should never be taken lightly. FUMES SHOULD NEVER BE TAKEN LIGHTLY!!!. FUMES MAY KILL YOU!!
How I handle it is...if the fume is noxious, so as to irritate your nose, or eyes, etc. IT IS BAD!!!
Nevertheless, if I were in your boots, I would take the unit outdoors, and let it run on 'HIGH' for about a 1/2 hour, or so. After it cools down, take it indoors and try it again. If it is still fuming, write the manufacturer a "fuming" letter.
Good Luck,
Papou1
Jan 28, 2008 | Heating & Cooling
Heating & Cooling Logo
168 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
