Question about Toshiba Satellite 1715XCDS Cooling Fan (k000882360) Laptop Cooler
How to fix my Toshiba laptop in cooling system please ?
Please help me to fix my laptop witch give this messag error
Warning: A problem with cooling system has been detected
  • 1 more comment
  • themorrises Mar 03, 2009
    How do you clean it? A45-S121 Toshiba Satellite Laptop.
    Getting same error message: Turn off computer and return for service. Problem in cooling system is detected.
    Thanks!
  • drewkrotz
    drewkrotz Sep 21, 2012
    Just go to msconfig and disable all toshiba startup apps and restart the PC. It is a crappy Toshiba program that thinks the PC has cooling issues. I did this and ran burn-in on it over night and the PC has been running fine ever since. No cooling issues.
  • moistsprouts
    moistsprouts Feb 08, 2013
    Where is msconfig and how do I disable these apps?
  • 122 Answers
You probably need to clean the cooling fan...it collects dust over time, and doesn't move the warm air out as it should...its fairly accessible by removing the bottom case cover...please rate my response.....
Posted on Feb 01, 2009
When i boot up my laptop i am getting the error message, "operating system not found." Can you please give me advice on what to do to fix my laptop? Toshiba laptop and im scared i may lose the things
Your hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Nov 30, 2012 | Toshiba Computers & Internet
My cooling system keeps giving error messages
you have to service air vent and check cpu cooler fan is working.
Oct 01, 2017 | Toshiba Portege R705P35
Hi there is a toolbar coming up the whole time saying,,,,,WARNING a problem with the cooling system has been detected, please turn of the computer and return for service immediately
Try to fix the problem without taking the laptop apart first but I would recommend using a powerful air compressor instead of a vacuum cleaner.
Welcome to FixYa! Based on the error you have received, this means that the cooling fan of your laptop needs to be cleaned and checked at. This is a common problem with any toshiba laptop. I suggest checking the heatsink of your laptop. If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It's nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
  5. If your laptop is still under warranty, you can take it to any Toshiba Authorize Service Provider and fix the problem at no charge to you.
Hope this helps! Thank you for using FixYa!
Jul 27, 2011 | Toshiba Satellite 1715XCDS Cooling Fan...
My toshiba satellite L455D-S5976 Laptop says A disk read error occurred, how do i fix this, cause i wanna restore to factory settings but i have no disc for the laptop... Please Help!!!!
hi,
that error message is referring to your hard disk. Some of the sectors are corrupted and it might have to do with the part that contains your operating system or boot manger. You're advised to get a new disk, install a fresh copy of your operating system, and recover your files from the other disk by attaching it to the system like an external drive.
hope this helps
Jul 04, 2011 | Computers & Internet
Hi, I have a new Toshiba Satelite L500 laptop. From the moment I started to work with it, following message began to appear: Warning: A problem with the cooling system has been detected. Please turn off...
first you should install an independent system temperature monitor like speed fan and check if your computer temperature is ok .If the temp is ok then it is not as much of a worry but more of an annoyance if it shows the computer is hot take it back to service immediately either way they should fix the problem under warranty.
I hope this helps Andrew A
Apr 01, 2011 | Toshiba Satellite Laptop Cooler
I have bought a new toshiba A665 a week ago. I have a problem saying. ' A problem in the cooling system has been identified. Switch off ur computer and return it for service.' Cooling fan is working but...
At a week old, get a replacement or fix it right away. Fix should be free, but no computer during service.....
Toshibas run too hot, in my opinion.... so you have to keep after the fans and keep lint cleaned out of it....
Overheating will yield un stable system,
Feb 26, 2011 | Toshiba (K000831860) Cooling Fan
I upgraded my toshiba U505=s2940 from Vista to Win 7 64 bit, and got everything working except the webcam. I cannot fine any drivers on Toshiba's support page or on the internet. Can you please give me a...
most toshiba laptops will have the toshiba installer witch will have all the apps and driver files for your webcam however if your unable to find em then message me here on my gmail i have the drivers on my toshiba u505 witch will work/ supershadowxz@gmail.com
Sep 18, 2010 | Toshiba Satellite U505-S2940 Notebook
Hi,i have toshiba laptop setlitte a 205 .i dropped it few days ago.when i turned it on it was giving me error that oprating system not found .i called toshiba support they told me to do recovery but it was...
You bought a new hdd drive that seems working good, Hdd (Hardisk Drive) is connected to a port that is also connected to the motherboard, in this case that port is no longer stable possible cause of the accident, you need to replace that port to fix or to identify the problem. This hardware device is really sensitive thing, you need a personal technician to troubleshoot the problem if you're not familiar with this device
Feb 26, 2010 | Toshiba Satellite A205-S4607 Notebook PC
Toshiba Satellite Laptop Cooling Failure
The fan has failed - warranty if in the time period since purchase.
Jun 30, 2008 | Toshiba Satellite Laptop Cooler
Toshiba S2450 PS245E Laptop Heating Problem
toshiba 2450
1 clean the cpu radiator 2 make sure the fan works, 3 install toshiba common modules and toshiba chipset drivers. 4 go into bios and set devices managed by the os.
Dec 24, 2007 | GPS
Toshiba Satellite 1715XCDS Cooling Fan (k000882360) Laptop Cooler Logo
4,475 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
