Question about Goodman GDS80904BNA Open Flame Heater
Heater lights fan comes on flame goes out
I can watch the ignitor come on and it glows real good the flam lightes and 10 sec later it goues back out a min or 2 later it will start the prosses all over again
    Novelist:
    Champion:
  • 230 Answers
There is a flame sensor located in the same area as the ignitor (usually on the other end of the burners). remove the flame sensor with the power off. Then use steel wool or light sand paper to clean the silverish end. Reinstall the sensor and ToDA you are done! Best of Luck!
Posted on Jan 29, 2009
Maxx heater lights all burners for aprox 20 sec blower fan starts flame goes out flame lights again for 20 sec never blows much heat ?
sounds like its not getting gas fast enough to keep burning,that happen to me and the gas line was to long of a run for enough gas keep coming. so I up the pipe runs real good the flame keeps burning, so you know you can only go 25 ft in half inch pipe then u lose your flame
Oct 24, 2014 | Mr. Heater Natural Gas Garage Heater -...
What's your problem? goodman furnace lights, burns 10 secs goes out
Hello,sounds like you have a dirty flame sensor. This is a metal rod on the oppositenside of the hot surface ignitor. turn off power to the furnace and remove the flame sensor, then use steel wool and clean the flame sensor and reinstall. Next turn back power to Furnace.
Nov 18, 2011 | Goodman Heating & Cooling
My heater isn't blowing any heat. I hear the fan come in, and i think i hear the gas come on, but nothing comes out of the vents. The fan only comes on for a couple of minutes and then goes off.
Ok so here is a sequence of the heater lighting and the solution for your problem...
1. Thermostat calls for heat. 2. Draft inducer motor starts. 3. Pressure switch attached by a small plastic or rubber tube senses the negative pressure produced by the draft inducer and closes. 4. Draft inducer runs for 30 seconds to a minute before you hear a gas hissing sound. The ignitor did not glow, the flame sensor (a small metal probe about 1/8" in diameter, with a white porcelain base) does not sense the flame, so after 8 to 10 seconds the hissing sounds stops with no ignition of gas to heat your home. Your furnace shuts down and goes into a lock out condition until you turn your power switch back off and on again. Then the sequence starts all over again with no ignition of the gas. Solution:You probably need to purchase and install a new ignitor. I would suggest that you inspect your ignitor closely for cracks.Make sure you do not touch the ignitor with your bare hands. If you do not visually see a crack, then you could have a furnace control board problem or a limit, rollout switch problem. Please see "limits, rollout switches & furnace control boards" further down on this page. The furnace's control board might not be supplying the voltage to the ignitor. If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning. Please see the pictures below to help you identify a flame sensor.
Thanks and I hope this helps. Feedback apprec.
Jan 28, 2011 | Honeywell Electronic Programmable...
It doesn't want to shut off and we have no heat?
when you say it doesnt want to shut off i'm guessing you mean the fan. the fans run on a timer when the thermostat calls for heat it will come on 90-120 sec.later. turn your t stat down below room temp and it will shut off in 30-60 sec.your ignitor is most likly bad. turn your t stat back up and look at it. it should glow. furnace will try to light 3 times,you may hear the gas flow for 3 sec.during this cycle. if no glow good chance that is your problem and you will need to replace it.be carefull it is very brittle and breaks easy if tapped. be sure to turn the t stat down again or the fan will start running again.
Jan 26, 2011 | Coleman Propane Forced Air Heater...
Inductor blower comes on and runs then the ignitor glows flame comes up and burns for approx. 10-15 sec then goes out then fan comes on. Model number is PBKMLB12N0B0F I believe this is a goodman furnace.
I cleaned the sensor that was at the the right further most burner on my Goodman and it worked. got the answer to my problem here at fixya. My burner flame only lasted 5 secs before it shut off. Thanks to all who took the time to send me a response.
Nov 13, 2010 | Goodman Heating & Cooling
Fan comes on glow plug lights up but no flame.3 sec. fan shuts down.Have clean all lines, tips everything. Model 60 Reddy used very little in ten years.
this have a flame controler, if the flame didn't goes on in few seconds the unit automatically stops. back plug and start again, if not star after tree times check the flame control thermocuple, or get the unit in service to fix it.
Feb 14, 2010 | Reddy R60A Utility Heater
Goodman gmnt060 3b doesn't light
check for 24vac between wires on gas valve about 5-10 seconds after ignitor starts to glow. If ignitor does not glow, check for 120 vac to ignitor after inducer goes on.
First...sequence of operation..power to W, inducer motor gets 120v and starts, 10-15 seconds later, ignitor gets 120v and glows, 5-10 seconds, gas valve gets 24v and opens, after 3-4 seconds the flame sensor approves flame and unit stays on. If this is not happening, it has to be in this sequence. Which ever is not happening and you do have voltage to that component, that component is bad. If you are getting a error code on board after it tries to light, pay attention to the code. if a 1 lock out code, that just means it tried 3 times and did not recognize a flame.
Jan 06, 2010 | Goodman GDS80904BNA Open Flame Heater
Master 160,000 btu will not stay lit
pull out flame sensor and sand. Re install and call for heat
Jan 21, 2009 | Master Heaters 160-IF
Heater lights for about 5 sec and then goes out
One flash on a Ruud furnace indicates failure to ignite. There is a viewing port on the furnace where you can watch the flame. If the ignitor is igniting the burner and then 2 or 3 seconds later, the flame goes out; you most likely have a flame sensor that is dirty or not working. Check to make sure you are getting gas. Check the connections of all wires to the control board. If the sensor is not part of the ignitor, see if you can get to it to clean it with a small wire brush. Make sure there is a good ground connection between the board and furnace frame. If the flame is not traveling all the way to the flame sensor, clean your burners. If the flame burns inside the burners, you may have weak gas pressure. Good Luck.
Sep 29, 2007 | Heating & Cooling
Heating & Cooling Logo
121 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
