Question about GE JVM1860 Microwave Oven
WHEN PRESSING COOK TIME OVEN CLICKS ON FOR ONE SECOND AND RESETS CLOCK
I have the XL1800 Spacesaver oven. When pressing express cook or any other cooking time, the oven comes on for one second, shuts off and the clock resets. I can reset the clock with no problem. It's only when I try to heat something that the oven light comes on, shuts off immediately and clock is reset without any heating. What could this be? Is service necessary? Thanks!
  • Anonymous Feb 08, 2009
    I have a National oven, on any setting, grill, heat, bake whatever.. it functions for about 28 seconds, and then turns off atuomatically. The oven is brand new.. used for a couple of months only :(.
    And I cannot find a solution to this problem.
Try unplugging the unit for 30 seconds, which resets the control board.
Posted on Oct 15, 2008
Same issue exactly with my JVM1860. JJAY481, did you find a fix?
Posted on Jul 27, 2008
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 37 Answers
Please try on some other power point as if there is loose contact or sparking in point which cause to switch off as soon as you start because of heavy current drawn by oven and clock also resets. If not solved even then must have some short circuit or over loading in timer circuit or magnetron. in this case you have to call for a service engineer.
Posted on Aug 03, 2007
SOURCE:
Can I disable the express quick cook feature of Emerson MW8997B?
That feature may or may not be on your microwave oven. GE has quick cook options of 30 and 60 seconds (not a keypad selection).
Aug 15, 2018 | Emerson Microwave Ovens
GE Spacemaker XL 1800 turns on for 1 second and then resets. The display shows PRESS CLOCK.
Sounds like your losing power, have you tried it on a completely Different circuit??? Either that or bad fuse or connections inside of microwave.
Sep 08, 2017 | GE Microwave Ovens
My microwave GELX1800 is not heating... when the express button is pressed it opens the vent lid and the plate turns around but is not heating. The vent lid should not be open when the cooking buttons are...
Try a hard reset first: Unplug the oven or turn off its breaker for a minute or so, then set the clock & try it again.
If it still fails, did the cooktop lights go out recently?
It may need circuit board repair, which is usually economical.
Oct 27, 2013 | GE XL1800 1100 Watts Microwave Oven
MY GE SPACESAVER MICROWAVE MODEL JVM-1653-SHO-1 SHUTS DOWN AND TELL YOU TO REPROGRAM THE CLOCK BUT YOU RESET USING ALL INSTRUCTIONS I INSTALL COOK TIME PRESS START IT WILL COME ON FOR 3 SECONDS AND SHUTS...
This is magnetron-related.
See
this FixYa solution (solution #2) even though your model number is different.
Jun 19, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacesaver xl1800 microwave. Unit comes on, but no heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
agf
Jun 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Model JVM1650WH02 will shut off about 2 seconds or less into cook time. everything else works such as light and clock and sometimes the wave will cook.
magnetron is leaking internally, do not use until magnetron is replaced. the mag creates interference with the control board and resets it
Feb 05, 2010 | GE JVM1650 1000 Watts Microwave Oven
I have Emerson Microwave #mw8999sv which has the Express Cook option- cooking 1 - 6 minutes. How do I cook for 1 minute 30 seconds, etc.? Thank you.
The owner's manual is here. On page 10 we find:
COOKING IN ONE STAGE
1. Press the POWER button; the Microwave and High
Cook indicators will light and “PL 10” will light in the
display.
2. Press the POWER button different times to set the
desired power; the display will show the percentage
you chose. If selecting power level 70%-10%, the
Low Cook indicator will light instead of the High
Cook indicator.
3. Press number keys to set the desired cooking time.
OPERATION(CONTINUED)
4. Press the START/+30SEC. button to start cooking;
the Microwave and one of the Cook indicators will
blink and the display will countdown the remaining
cooking time in minutes and seconds. It will beep
five times when cooking is completed.
Sep 08, 2009 | Emerson Microwave Ovens
GE Spacesaver XL 1650 microwave shuts off after a few seconds
this would be the digital control board that would need to be replaced
Nov 27, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
How do i set clock for time of day
You can download your owner's manual free here.
From the manual:
SETTING THE CLOCK - When the microwave oven is plugged into an outlet, the oven will display " 0:00 "
1. Press the CLOCK button; the hour digit will blink
and the clock indicator will light.
2. Press the number keys to set current hour.
3. Press the number keys to set current minute.
4. Press AM/PM to choose AM or PM.
5. Press the CLOCK button again; the display will
show the present time. After the clock has been
set, the time will appear with blinking colon,
unless the oven is cooking or defrosting.
NOTES:
- To reset the present time in the display window when the oven is off, press the CLOCK button and
reset.
- If you make a mistake when setting the time, press the STOP/CLEAR button.
- To recall the actual time while the oven is cooking or defrosting, simply press the CLOCK button
and the display will show the actual time for three seconds.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 03, 2008 | Emerson MW8107WA Microwave Oven
GE JVM1860 Microwave Oven Logo
514 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
Jimmy
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
