Question about Dell HK395 Computer Speakers
HK395 Speakers/Subwoofer Cable
I have the HK395 speakers/subwoofer and the problem is that I lost the 'satellite cable' to connect the woofer to the speakers and I can't seem to find it online anywhere. Does anyone have a solution for my problem or a link to where I can find this cable. Thanks.
  • 4 more comments
  • docs151 Nov 19, 2007
    Already tried radio shack. they don't have a match. Is there anywhere to buy a replacement for the right side control speaker?
  • fernando219 Aug 03, 2008
    I broke a conector cabel of HK395 and I don´t know where to buy one in Brazil?
  • Anonymous Feb 28, 2009
    I have lost this cable as well and have never seen the same "satellite output" cable on any other subwoofer.
  • Anonymous Mar 03, 2009
    HK 395 Speakers /Sub has broken pins on orange cable connector to the tower. Dell advised no replacement offered
  • Karman K-28
    Karman K-28 Jun 04, 2019
    Hola amigos tengo el mismo aparato pero no tengo las bocinas quisiera saber si alguien me ayuda como conectar a un dispositivo bluetooth ya que yo mo tengo ni idea pero megustaria hacerlo gracias
  • Karman K-28
  • 64 Answers
Harman kardon HK395 pinout diagramHK395 Speakers/Subwoofer Cable - 8_7_2012_7_23_11_pm.jpg
Posted on Aug 07, 2012
    New Friend:
Hi
jfouylgvllljkovftgoudl
Posted on Mar 14, 2011
Hi All,
Need help if anyone have the schematic drawing circuit. I lost the cable too.
Posted on Jun 07, 2008
    New Friend:
I have these speakers. The cable that goes from the satellites to the subwoofer is hard wired in to the right hand satellite. The one that could possibly get "lost" is the one that goes from the computer to the subwoofer and it's a very standard 1/8" mini to 1/8" mini exactly like you would use to connect an MP3 player to a car's auxiliary input. Very common cord!
Posted on Nov 11, 2014
If you know the connector needed you could get Mapan or Radio Shack to make them for you.
Posted on Jul 26, 2007
SOURCE:
How to use hk395 subwoofer without satellite speakers
System power is controlled by a switch on the right satellite speaker ON/OFF VOLUME control, therefore you would have to connect a separate switch to control power. However, you may be able to get a satisfactory result by turning the satellite volume control completely counter clockwise and adjusting the WOOFER VOLUME control to the desired level.
Jan 21, 2015 | Audio Players & Recorders
What cable connects a Dell PC to a Harmon Kardon HK395 sub woofer?
3.5 m/m. Normally it is color coded green. The pink connects the subwoofer to the speakers. Any color will work. Just mark both ends of wire jacks.
Nov 16, 2014 | Dell Harman/kardon Hk395 Computer Speakers...
I have harman karden subwoofer but i dont have any
hmmm....does the subwoofer have any controls on it or are the controls on the speaker that came with the sub?
Jul 30, 2013 | Dell HK395 Computer Speakers
Ihave hk395 subwoofer..but i dont have the satellite and a two speakers..it is possible to use it...if not were i can buy..
U can use the sub-woofer by plugging it separately with a normal 2 stereo speakers.. or ..use 2 speakers attached on it ..be sure they are powerfull enough to make a match ..(usually it is enough 10 watt )
to plug t separately ..just take a look in the speaker configuration option of the driver..and change it in such a way that will allow you multiple out ..(you will see which one will be what ...even on a normal sound card with only 3 plugs ..The configuration you have to choose is probably 3=1 or so ...and will leave your pink for a microphone ..and the line in will turn in a out-let for the woofer ..
Or if the woofer have inlets for the speakers and has a amplifier built in ..you can attach any speakers..
In this case you can use teh normal speaker out ..and get the signal for the other speakers from the woofer ..
In case they were separate ..and the woofer was only connected with the central ..use like I say ..a configuration on the sound manager (speaker configuration ) in such a way that you will be able to connect the speakers in normal green out and use regular 2 stereo ones..and attach the sub-woofer in the plug specified in the diagram ..usually for 3=1 or 4=1 it will change the blue line in into woofer out ..and will work
In this case the speakers used in the green out have to be amplified separately (or have a built in amplifier like computer speakers have ).please ask if you didn't understood the procedure ..and please rate my answer
Dec 25, 2011 | Dell HK395 Computer Speakers
Can i use my hk395 with only the speaker inside on my computer. thank`s
DID YOU SOLVE YOUR PROBLEM? IF NOT, I NEED TO BUY THE CABLE THAT CONNECTS THE SUBWOOFER TO TEH SPEAKERS IN CASE YOU WANT TO SELL IT,IM INTERESTED
[email protected]
Jan 02, 2011 | Dell HK395 Computer Speakers
How do i fix my sub woofer?
U just remove subwoofer and clean it with a piece of cloth, then fix it ur computer it will wirk. If not, pls make service it.
Nov 02, 2006 | Dell HK395 Computer Speakers
JVC RX-809V
Go to the following website www.servicemanuals.net where you can get the service manual for $17.00, unbelieveable, don't you think? The service manual should help you sort out your hookup problems. Good luck.
Jun 10, 2006 | JVC RX-818V Receiver
Dell HK395 Computer Speakers Logo
5,475 people viewed this question
Top Dell Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Steve Mason
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
