Question about Siemens HE2416U Electric Kitchen Range
Siemens HE2416U slow to preheat
My oven takes well over half an hour to bake preheat to 350. It works faster in convection bake mode
4 Suggested Answers
fridgetech
  • 473 Answers
SOURCE: bake part of kenmore not working seems to take to long
Chances are the oven ignitor will need to be replaced.  Look and see if it glows.  If it does then it is weak and not opening the gas valve to lite.  Let me know what you find.
Comment by fridgetech, posted on Oct 20, 2007
Should be able to remove the bottom drawer and unplug the ignitor from below.  Or you can cut the wires on the old ignitor and splice the new one in using ceramic
Posted on Oct 20, 2007
SOURCE: KitchenAid gas range superba not reaching/registering right temp.
kitchenaid superba electric double oven "takes too long to heat up"
Posted on Dec 06, 2009
SOURCE: seimans HD 2515 Oven stopped working
I have this same problem. Any resolution on the others' problem?
Posted on Apr 18, 2010
The oven preheats, but then "cools down" before I
Most likely the problem is your bake element. When the oven is preheating it uses both the bake and the broil element. When it's done preheating it uses only the bake element, so the broil element is heating it up, and since the bake element is not working the temperature drops until it starts preheating again.
Jan 30, 2011 | KitchenAid KERS807SSS Electric Kitchen...
What is the best setting for my viking on a 14 pound turkey, bake or do i use the convection broil?
Use the regular bake setting.... run the oven at 350.... the 14 lb. bird will take about 4-5 hours.....convection moves air and can tend to dry out the bird...
heatman101
Nov 25, 2010 | Viking 30" Professional Select Built-in...
My Kenmore Elite oven will take over an hour to preheat to 350 degrees and never does get done preheating.
There's a few things that can cause this.
1. Check to see if the both that Bake and Broil elements (burners) are heating up. Check the Broil element in Broil mode.
- during pre-heat the Broil element gets cycled on and off for short time durations to speed up the heating. If the Bake element is not working, then the oven will heat, but very slowly and never reach high temperature.
2. If the elements are both working, then it's possible that you have a bad temperature sensor.
- this is a temperature dependent resistance device that should measure 1080 ohms at 70 deg F (room temp).
3. If #1 and #2 are ok, then the problem is with your oven clock/control unit. We rebuild these at fixyourboard.com.
Aug 14, 2010 | Kenmore Ovens
When set to bake eg: 350 degrees the audio alarm will indicate it's reached temp but the oven is 50- 75 degrees lower. Must wait another 15 min for it to reach the proper temp. Have tried to adjust the off...
If you are monitoring the oven temperature with an analog style thermometer you may actually be ok, but seeing the thermometers slow reaction time.
Some newer ovens actually do pre-heat beep prior to reaching temp in an effort to conserve eelectricity.
A good home test is to try your oven at several different temps to see if there is any variation in internal temperature. Try it one day on 300, the next at 375 and another day at 450. Give your analog style thermometer time to catch up (usually just about 15 min) and leave it on for a half an hour to see if the temp maintains.
Also Beware of aluminum foil AND THE NEW OVEN LINER MATS as they can alter oven performance bay absorbing and blocking the ovens natural heat radiation and convection air flow currents that happen in all ovens, not just convection models.
Another interesting fact is that older ovens used a thermostat in them that operated much like your thermometer and was very slow to react making the oven typically about 100 degrees hotter than where the customer set it. This was just a fact of life before the advent of electronic temperature management and became noticeable when people began trying to bake older "hand me down" recipes in the newer ovens with less than stellar results.
You can mimic the older oven performance by preheating the oven about a hundred degrees higher than called for and after it reaches temp, re-set it to the correct temperature and put the items in right away.
If you find your temperatures fluctuating ask your servicer to replace first the temp sensor and as a last resort the control board as this part is usually pretty expensive.
Good Luck with this!
Jun 14, 2010 | Ovens
Seimans HD 2515 Oven stopped working
Mar 11, 2010 | Siemens HD2515U Stainless Steel Dual Fuel...
My dacor oven model ECS130SBK is very slow to heat. Sometimes reaching the desired temp. after a long wait. Sometimes it never gets there.
I found the bottom element was not getting any power by using a volt/ohmmeter and a test method described elsewhere. (Shut off power, hold down COOK TIME while turning on power. then within 30 seconds press each mode you want to test and only that element/fan/etc will turn on. Cancels by itself after 30 sec.)
I traced the wire back to the relay (wire checked good) and there was no power getting through the relay although it clicked. Removed the relay board to replace it and found a cold solder joint on the "out" terminal with obvious past arcing carbon. Cleaned and soldered the pin and the oven now works normally.
WHY THE SLOW TO HEAT? The oven turns on all the elements to preheat faster and when it reaches your set temp it beeps and now only turns on the element you selected to maintain the temperature. (Bake or Convection) Our malfunctioning ovens would then cool since the element is not working properly and it must go back into preheat and keep cycling.
BY THE WAY- Don't ever use 4 hours on self clean it kills the boards and/or display. I also put a house fan in front of the oven and blow it into the lower grill to take away some of the heat on the two boards. Learned the hard way!
Jun 08, 2009 | Dacor ECS130 Epicure Electric Single Oven
Magic chef gas range; oven takes about an hour or so to preheat.
most common issue, and it sounds like what your experiencing here, is a faulty ignitor, replace the bake ignitor ( located under teh oven floor, attached to the burner bar)
Feb 27, 2009 | Magic Chef CGR3742 Gas Kitchen Range
Amana Convection oven not controlling temp
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
Siemens HE2416U Electric Kitchen Range Logo
169 people viewed this question
Top Siemens Kitchen Ranges Experts
R.A. Ellis
R.A. Ellis
Bill Boyd
rpar
Are you a Siemens Kitchen Range Expert? Answer questions, earn points and help others
