Question about Canon i9900 InkJet Photo Printer
I lost my power cable cord to my Canon i9900
I've lost it, its completely gone. I have a Canon i9900 and I've lost the power supply and power supply cable. Does anyone know where I can get a replacement?
  • 59 Answers
If you go to Radio Shack they will have everything you need - If not they can special order it for you. I have had to do that before. Hope this helps.
Posted on Jan 29, 2009
I9900 canon printer: does not show any power when turn on.
General NO POWER troubleshooting:
- Try a different known working power outlet (direct to wall preferred)
- Try a different power cable (may not be possible if the cable is attached to a power brick)
- Does it power on (makes some noise) but no lights display or simple no power at all,
if no power and the first two steps still lead to no power next step would be to replace the power supply and or the power plug connector (depending on the PSU)
if it makes noise when you power up but no lights the printer may still be functional but the control panel is damaged
May 31, 2011 | Canon i9900 InkJet Photo Printer
Taking a canon i9900 printer apart to get jammed paper out
If you want online customer service, then connect with us at Canon Printer Tech Support Phone Number#1877-778-8@9@6@9 anytime as you like. For further information Click:https://goo.gl/ZYjDqq
Jul 28, 2010 | Canon i9900 InkJet Photo Printer
After a brief power outage during a thunderstorm my canon i9900 will not turn on. I left it un pluged for several hours and then repluged it and still nothing. Everything else in the office works fine.
The power supply of your printer are damage due to the brief power output during the thunderstorm. Just check the fuse inside of the power supply of the printer if they have some burned or else use the Multi Tester to identify that the fuse are damage or needed for replacement.
Jun 03, 2010 | Canon i9900 InkJet Photo Printer
My old i9900 printer program is for a 32 bit intel platform only. I now have new compaq windows 7. What do I need to make i9900 compatable. Could a new printer cable work??
You will need new Windows 7 software drivers for this model and I don't think that Canon has released any. Check their website (www.usa.canon.com) and see if they are available. Good Luck . . . .
Feb 16, 2010 | Canon i9900 InkJet Photo Printer
I cannot get the power button on my Canon i9900 inkjet printer to turn the printer on. It is plugged into an active power source, but when I hit the on button, nothing happens. Does it matter that I have...
The most likely cause is the printhead has gone out. If you can get to it, you need to remove the printhead and try power again. If it comes on you need a new printhead, if you put the old one back in you could destroy the logic PCB.
Dec 30, 2009 | Canon i9900 InkJet Photo Printer
Canon i9900- absorber pad full - How do I replace ??? I Thank-You, in advance for your Time, Courtesy, and Help !!! Best Regards, Alton Davis P.O. Box 6 Centre, AL 35960 Toll Free 877-446-0393 email:...
The pads are on the very bottom under the printer engine, after removing all the upper covers there are 6 screws holding the print engine in place, and the cable from the power supply must be removed. After changing though, you must enter diagnostic mode to reset the counter for the ink absorbers.
Jun 20, 2009 | Canon i9900 InkJet Photo Printer
Canon i9900
Its either your power supply or logic board, assuming you have it plugged in to a live power source. Unfortunately in most cases it is the logic board, an expensive replacement. You may want to join me. Sledge hanmmer it and put it on Youtube. Cannon support is terrrible. Very unknowledgable people in my opinion;.
Bob
digilab@optonline.net
Mar 20, 2008 | Canon i9900 InkJet Photo Printer
I9900 will not power up at all
Make sure the power cord is plugged into a live outlet. If it still will not power up check the power supply. I have heard those power supplies go bad and they can be replaced.
Jan 21, 2008 | Canon i9900 InkJet Photo Printer
Canon i9900 will not power up
There's a new power supply available at http://www.beckscrs.com/partlist.php for $61.20, part #QK1-0311-000 or at http://www.vancebaldwin.com/products/?CAN&start=1601 for $60.70. The original power supply shows part number Canon K30212 on it. If replacing the power supply/adapter doesn't resolve the problem of the Canon i9900 not powering on at all, the part number for the logic board is QM2-1273-000 from Beckscrs.com for $225.
Sep 20, 2007 | Canon i9900 InkJet Photo Printer
Will not turn on
Very late last night our power went out for about 40 minutes. Today my i9900 will not turn on. This is the second time this happens to my i9900. The first time, I was lucky, it was still in warranty (11 months 2 weeks into it). Now its exactly 1 year 2 weeks later, and the same problem has occurred. I believe the i9900 must have a very sensitive PC board. I have the printer connected to a UPS and nothing else in my home has exhibited a problem. I tried unplugging. Connecting to a different outlet, and interestingly, when you plug the cord, you can hear a very faint click or spark noise. The last time, when Canon sent the replacement, I switched the power supply but that did not fix the problem. It seems the problem is somewhere else. Anyone has an idea on how to fix? Will it require sending to a repair center? If so, any ideas what it will cost? Thanks... cokyq
Sep 07, 2007 | Canon i9900 InkJet Photo Printer
Canon i9900 InkJet Photo Printer Logo
365 people viewed this question
old marine
old marine
