Question about EliteGroup L7S7A2 Motherboard
Microphone does not work on elitegroup l7s7a2 board
Elitegroup mainboard K7 l7s7a2 chipset Sis746/Sis963L
I have loaded drivers, from control panel I see driver as SiS7012 wave using control panel and going to Audio and Voice I dont see Advanced icon and test hardware is not able to record the voice at all.
Running Windows XP SP3
Please advice if microphone is supported and if yes how to make it work, Sound is working fine.
Ujyhththhtht
Posted on Jan 29, 2009
Need drivers for ECS Elitegroup GF6100-M754 AMD
Hello here is the homepage:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=854&MenuID=24&LanID=9
Here is only drivers for windows xp.
AMD is the cpu socket 754, and have nothing to do with the chipset drivers, or mainboard drivers.
This means that the chipset on the mainboard is nvidia based.
Amd/ati does not make chipset drivers, they only make graphic drivers, for a graphic card.
If you need the driver for a external graphic card, you have to seach here:
http://support.amd.com/us/gpudownload/Pages/index.aspx
By selecting the graphic card number, and your windows system.
I would not recommend to use other 3rd part drivers, than then from the homepage, because they will not fit the mainboard.
Good luck
Feb 17, 2013 | ECS Brand ECS GF6100-M754 Elitegroup...
DOES K7SOM MOTHERBOARD UPGRADABLE?
http://www.ecs.com.tw/ECSWebSite/Downloads/Downloads_Driver_Detail.aspx?MenuID=61&LanID=0&detailid=79#Download-2
And the + versions:
http://www.ecs.com.tw/ECSWebSite/ECSSearch.aspx?menuid=0&lanid=0&keyword=K7SOM+
I would say no because the cpu does not exist anymore.
The only thing you can upgrade is the harddrive and the ram module.
The mainboard uses SDram and DDR ram in there own seperate block.
Sdram is hard to find and expensive.
DDRram can still be bought.
The specifications:
PROCESSORS
462 pin Socket A supports the AMD K7 processors
Full series of Athlon XP/Athlon/Duron processors
CHIPSET
SiS 740 & SiS 961/962 Chipset
SiS 740 Host/Memory controller with high quality 3D graphic accelerator
SiS 961/961B/962 MuTIOL Media I/O
Integrated USB 2.0 host controller in SiS 962
LPC I/O -ITE8705F
LAN: MAC integrated in SiS 961/961B/962 and PHY on board
AC97 Audio Codec: Compliant with AC97 2.2 specification
SYSTEM BIOS
AMI 2MB Flash EEPROM
Supports Plug and Play 1.0A, AMP 1.2, Multi Boot, DMI
Support for ACPI revision 1.0 specification
MEMORY
2 DDR DIMM Sockets and 2 DIMM sockets support (can not be used simultaneously)
Two 184-pin 2.5V DDR SDRAM (DDR266/200) or
Two 168-pin 3.3V SDRAM (PC133/PC100)
Maximum: 2GB (DDR SDRAM or SDRAM)
I/O INTERFACE
Hope this was helpfull
Nov 29, 2012 | EliteGroup K7SOM Motherboard
What version of intel graphics accelerator is compatible with my EliteGroup P4M800PRO-M v2.0
Updating your graphics does not increase your performance.
Versions are not fixed they changed from time to time.
If you want to download then you should download the driver of this chipset "S3 UniChrome Pro 2D/3D Graphics" this chipset is installed in your board
or u can check go to RUN type Dxdiag then press enter Click Yes
go to Display tab u will see your model chipset.
It will work. Good Luck
Nov 25, 2009 | EliteGroup P4M800PRO-M Motherboard
Audio drivers proble
You donot mention here the exact mother board model no of murcury, But still in giving you one link from where you can download the drivers Here you will find three model no mention below. Pls choose the exact model no. from here to get the exact model no , check *********** board box or bill. if still you you donot get the exact model no . then pls try all three model drivers on by one. One will be right driver. It will not take mch time to try all one by one.
1. KOB KT266a FDSX - AMD K7 (Socket A) Mainboard w/ VIA KT266A
2. KOB KT266a FSX - AMD K7 ATX Mainboard w/ VIA KT266A chipset
3. KOB KT266a FDSUX - AMD K7 (Socket A) Mainboard w/ VIA KT266A
the link is :- http://www.mercury-pc.com/downloads_list.php
Sep 10, 2009 | Mercury Electronics KT266A Motherboard
USB Port not recognized
you have to enable the usb support settings in the Bios setup,
how to do it?
step 1.
restart your unit.before the windows logo appear press the del or F2 to enter to Bios setup utility,
step 2.
in the chipset, look for the usb controler ,make it enable then save the changes and restart your unit.
Apr 01, 2008 | EliteGroup L7S7A2 Motherboard
Elitegroup P4VMM2 ATX mainboard
You can't fix it. I'm afraid it's a dead board.
erch.
Mar 17, 2008 | EliteGroup P4VMM2 Motherboard
EliteGroup L7S7A2 Motherboard Logo
166 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
