Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Green or black and white retangle checks no piture
Got up in the morning turned on tv and i had no tv just small checks on the whole screen. set is only 2 1/2 years old just had something repaired in december and repalced the bulb last year.not to happy with this set Mitsubishi.if any one has any ideas please help
  • linda delfing Aug 22, 2007
    thank you so much for you help. it was the fomatter board.i already got it fixed i could not wait any longer with no tv.
    Genius:
  • 1,153 Answers
. Check for proper seating of connector DB between the DM PCB and Signal PCB. 2. Suspect the FMT PCB part # 930B924002
Posted on Aug 22, 2007
SOURCE:
Sharp tv has small black and white image in black and white and half screen pink
Sounds like your LCD Control board went bad. Very small chance it is your main board since you said you cant bring up a menu.
Apr 11, 2012 | Sharp Televison & Video
Picture settings
settings are not likely to resolve a "yellow" looking screen.
Go to an unused video input or turn color all the way off----the screen should be gray or black and white looking.
What this really suggests to me is a total or partial loss of blue--the set has a red, green, and blue picture tube---a loss of blue means red and green=yellow.
You can peek inside with the set on and see if all 3 lens for the tubes are lit equally bright.
Let me know what you find (press make comment on this page) and depending on what you find I may be able to suggest something to try)
Mar 24, 2012 | Panasonic Televison & Video
Re-gas plasma tv were can i buy it from
hi i hav a problem with my tv.if i switch it on i have a black screen dats fades away after a while with small black dots on the screen but da piture is clear
May 26, 2010 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Screen turn green tv is 57 rear projection
Good Day,
It appears that you may have a green drive issue. Try adjusting the Sreen Control it is located in the front of TV.
1) Remove Speaker Grill (it just pulls off) start at one end, 2) Remove cover (5-6 screws), 3) Adjust control. The control is located on lower right side towards bottom. A small black device with 2 rolls of controls, adjust the center control on bottom row counter clock wise, until you get a black and white picture.(adjust with color control to min).
If this does not work you light bulb (CRT) is bad about a $750.00 repair.
Good Luck, Big Irish.
Dec 07, 2009 | Toshiba 57H83 57" Rear Projection HDTV
Screen goes blank after being on for a while
if it goes black but the light is still working the dlp chip is failing this is like a small lcd screen that the light use for the piture to work looks like this http://www.fixyourdlp.com/2012/04/24/the-affordable-solution-to-white-dot-syndrome-on-your-dlp-tv/ hope this help you.
Jan 30, 2018 | Samsung DLP HL-P5663W 56" TV
My screen turns green and then turns off
you need to adjust the screen voltage. behind the front grille and inside cover. a small black box 6 adjusters protruding from it. only adjust the the color counterclockwise that matches the problem in this case it's the green so look for the knob with "G" marked by it. there are 2 with "g" marked by them the row across the top of the box are for focus don't adjust. back the knob off untill the raster is blank with your input set to an inactive input, the picture should be blank and black.
when it is you have the adjuster close to where it should be, now change the input to an active signal and turn the color off so that you wil have black and white picture. adjust that knob untill you do have a truely black and white picture not too green or red or blue. go back to inactive video input and check that there are no lines of any color on the screen. repeat if needed. always adjust these knobs slowly the set will be watching you ! if your autofocus won't work now you have the adjustment set too low. check this function before putting back together again. these adjustments can be real touchy so be patient
Feb 20, 2009 | Sony KP-57HW40 57" Rear Projection...
Color adjust
Greetings!
Adjusting the picture tubes is a scary proposition, but since you have already done it...
The easiest way to balance the gray scale is to turn the color all the way down on the set. The next part is easier with two people if the screen controls are on the back of the set. This is the part you saw that has six small knobs on it. There are control for the focus of the red, gree and blue and for the screen level of the red, green and blue. You will want to adjust the screen controls in an effort to get the picture black and white (this is why you turn the color down), hence the term "gray scale". Just make slight adjustments, take your and be patient. It will take some time, but you will get your picture balanced back out in time.
Hope this helps!
Rob
Jan 15, 2009 | Philips 50P8341 50" Rear Projection...
Red , Green And Blue.
Heres the best way to set a phillips screen controls. Go into the picture controls and set picture or contrast to roughly 75%, then set brightness to 50% and then set the color level completely off. Then adjust the screen with the 3 color controls untill you recieve the best black and white picture as possible. If you are unable to achieve a good black and white picture change the coolant in the green and blue tubes. But if you can get a good black and white picture stop there then turn your color level back up and the picture should be correct. Let me know if you need further assistance.
May 22, 2008 | Televison & Video
Screen now has 3 small boxes in middle - one red, one green, one white
Its easy to fix and cheap. Check www.magnavoxhelp.com for chip kits.
Nov 28, 2006 | Philips 9P5534C 55" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
41 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
