Question about Konica Minolta magicolor 2300DL Laser Printer
I have a white or faded streak down the left side of my prints
This is pretty consistant but sometimes there will be a streak down the page as well.
I had this problem once as well. Open the side door and remove the waste toner bottle. Behind it you'll find a little blue tab. Pull it out and you'll have a long strip with a window in the middle. I solved my problem by cleaning that window. I hope it works for you, too.
Posted on Feb 03, 2009
I have Minolta 2300W Laser Printer and it folds the first page only about 3 to 4 inches down makes a nice one inch fold but take that out and print page printing with two wide...
The is blocked by dust on the side of the paper on the image unit that would have color associated with the print. Remove all the image units and clean all the laser glass. Replace those image units also if streaking as for the paper ensure correct paper side and media type.
Jul 12, 2010 | Minolta magicolor 2300W Laser Printer
Line down one side of page.
One of the ink nossels are blocked you can use benzien or hot water to unblock them
Oct 09, 2009 | Office Equipment & Supplies
Balck and white streaks on left side of paper
Usually if there are streaks you need to change the pcu that is the same color as the lines. If the streaks are gray it also could be the fuser, but i would think it is the pcu.
May 18, 2009 | Ricoh Aficio CL3500N Laser Printer
Faded-out streak
check your ink levels. if its the ink that came with the printer it is probable running out of ink. they do not give a full cartridge with printers, only about 3rd full. also try cleaning the heads. and try changing your printer settings/prefrences to less ink, more drytime see if that helps.
Apr 26, 2009 | HP LaserJet 1018 Printer
White out on left side of printed page
Have you tried another cartridge? Also shake the cartridge to possibly redistribute the toner in the cartridge. Sometimes it collects on one side of the cartridge.
Jan 26, 2009 | HP LaserJet 1300 Printer
Black streaks down left side of printouts Epson Aculaser C2600
I had exactly the same problem. Luckily we have 3 of these printers. Swapped the photoconductor and it solved the vertical streaking, even though the photoconductor was only half way through its life.
Dec 02, 2008 | Office Equipment & Supplies
Ricoh Aficio CL 2000N printing problems
If the colors are good and solid with no fades, only black streaks, then black is the culprit. I suggest replacing the black cartridge.
Feb 20, 2008 | Ricoh Aficio CL2000N Laser Printer
White Streaks down left side of page.
Shake the toner hard and try again. It should work.
Dec 11, 2007 | Samsung ML 2010 Laser Printer
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
Konica Minolta magicolor 2300DL Laser Printer Logo
206 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
